geeze
04/14-3
300*9 not even 1.475/1.5/1.525v
am i doing something wrong here ?
geeze
04/14-3
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
Ive got "LBBLE0517GPHW", never heard of this GPHW before
Intel Core 2 Duo E6600 @ 3.5Ghz w/
Tuniq Tower 120
ASUS Commando
OCZ 4GB PC2-6400 XTC Platinum Rev2 @ 4-4-4-15, 438Mhz
eVGA 512mb 8800GTS @ 830(Core) / 1030(Mem) / 2025(Shader)
Sound Blaster X-Fi XtremeMusic
2 x Western Digital 250GB SATAII 16Mb (RAID 0)
Antec P182 Case
Tagan 480w PSU
Windows Vista x64 Ultimate
Hi people! first post
Somebody recommend me some new RAM to replace this please.
Wont go much higher even on a divider and lower multi. Budget is £150/$300
e2140 @3.1Ghz Crucial Ballistix pc2-5300-C3 Gigabyte 965P DS3
ok, this is in my shuttle SN95G5 Nforce 3 ultra chipset xpc...HTT maxes out at 280 in bios, and i needed a divider on my crappy ram, but....
Venice 3000+ retail from newegg
LBBLE 0515FPDW
motherboard is definitely holding this cpu back, no doubt. if i could raise HTT higher (maybe with clockgen i can) i bet it will go higher. rig is silent as well...
EDIT: here is the link to my validation screen:
http://valid.x86-secret.com/show_oc?id=19844
Clockgen will let you go above 280 with the SN95G5.
i hit 300 with clockgen with stock voltage and then 30 sec. later it reboot. i will try again later with more vcore.Originally Posted by BadlyDrawnBoy
I got a new stepping, 3500 LBBLE 0517 APOW. Just set it up and ran a couple 1m pi. Running at 2.6@1.37v and 29C. I wish the temp would stay down there when it gets a little voltage. I have pic when I get on other comp. Also got a 3500 LBBLE 0515 FPAW. Have not tried yet.
8 hrs Prime @ 4500 (9x500) DDR-1200
9.59 32m Pi @ 4810 (8.5x566)
9.59 32m Pi @ 4gb DDR 1248
700 Club @ 7 x 585 CPU-Z Val
Prime @ 542 x 7 (4 hrs 1.28v)
32m 5006 (9.48)
OC Formula 3770k-dl G.Skill 2666 C10 Galaxy 660Ti 3gb Apogee HD PlextorM5P xfx p850
MVF 3770k Team 2600 C10 xfx 7850 2gb xspc RayStorm HyperX 3k Hyper 730
Gigabyte EP45-UD3P e8500 Crucial 8500 khx9600 evga 9800gtx PCP&C 610 H20 by Coop
3200+ 0517BPDW
2700mhz 10x270 @ 1.36v air cooled XP-90 2-2-2-5
these new Venice cores (IF I could get a good one) are really starting to tempt me away from my beloved 2.8c M0
lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
Apparently the 0517 make very good work. It is at least much improves that my 0516EPEW that does 2.8@1.75v.
Somebody knows of where are dispatching the new weeks but in U.S.?
"Please excuse my English, as its not my first language. But I am always learning so until I get better, thank you for your patience."
I think I'll drop by Monarch tomorrow and see if they are still on the 0516s or if they have moved on to the 0517s
is it heat my problem i can't get it to run 300*9 ?
i have zalman 7000b alcu
i can run it easily 280*9 at 1.375v
I am no expert regarding Venice but your cooler is certainly not classified as being "high end" such as the Thermalright XP90 or XP120Originally Posted by TEDY
i know :P but my old winnie did ran 300*9 at 1.55v just fine
So no one knows anything about my GPHW? I dont have a clue what this can do and i see everyone with differnt ones..
I might sell and get a better stepping one?
Ill wait to make my conclusion next wek when my PC4000 arrives...
Tuniq Tower 120
ASUS Commando
Antec P182 Case
Tagan 480w PSU
Hey Sobo, nice work to put this list together. Now how about to sort this out by stepping AND week so we can see the progress of new batches...
Intel E8500 Q813A248; Asus Rampage X48; TRUE 120; 2x1GB Mushkin XP2-8500; EVGA 8800GTS 512MB; 2x320GB Hitachi P7K500 Raid 0; Zeus 850W; Lian Li PC-60BPlus; Samsung 226BW; Saytek Eclipse; Logitech G9
Aint problem for me, i have such sortings in docs but i though that public 3 differ sorting will be big flood,especialy that the list is large now and might be eaven bigger.
i3770K@ 4.4 - 1.25v - TR120 Black+ Scythe GT AP-14
Crucial Ballistix Tracer 4x4096 DDR3 1866Mhz
Asus P8Z77-v Deluxe
PowerColor HD R290 moded to X
Samsung SSD 256GB 840 Pro
Samsung HDD 7200RPM 2TB (2x1TB) SA(N)TA
Corsair HX 650W
Antec P182 +3x Scythe -800-1200RPM
Asus 27" VN279QLB
Logitech G100S, CM Storm Quick Fire TK
Win 8.1
Flashed to 5/10-3.
So far 285*9 at only 1.35v (1.31v windows)...I know just set 300 and try....well i'm the kinda guy which progresses step by step......next 290...295...etc...hehe
update on my LBBLE 0515FPDW
300HTT at 1.4 volts ran 3dmark and superpr and about to run prime95 with aquamark...
validation:
http://valid.x86-secret.com/show_oc?id=19909
please post voltage as set in bios not in windows....all mobos undervolts...please put into consideration :=)
so where is the right volt? BIOS or softwares?
well, i left the voltage at stock in BIOS (3.5 vcore) and raised it using clockgen. my rig is stable so far at 280HTT with stock voltage. i raised it by .5 volts in clockgen, so i assume it is at 1.4 vcore, but i can raise it in bios instead later when i decide to reboot.Originally Posted by TEDY
that makes sense then
yupiiiiiiiiiiiiiiiii
290*9 works now at 1.375 bios...1.32 windows
damn 04/14-3 ... viva 05/15-3
ok guys, I'm getting the CBBLE 0512DPBW one^^ i'll post my results when i get my 2x512 OCZ el platinum rec.2 from RMA!
Venice 3000+
MSI K8N Neo2 Platinum
2x512 OCZ EL Platinum Rev.2
Powercolor x800 pro ViVo @ XT PE 16 Pipes
OCZ 520W PSU
high-end watercooling
I bought two week17 3200+ Venice today:
- LBBLE 0517BPDW 0963
- LBBLE 0517BPEW 0057
I set BPEW under Zalman 7700cu and first boot to the CPU@251*10 1.4Vcore and straight to StressPrime2004
- 3200+@2510MHz, did 24min and then I went to job...
If everything is ok, SP2004 should be working on 5h30m now
- Team Skootterit
- SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
