Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 86
Thread: CT-479 mounting tricks?
  1. #26
    Nov 2004
    DK
    Quote Originally Posted by Fzero
    sadly enof i looked at a couple AMD shims and there only .6mm thinck can you use a heat spreader off a p4?
    Post #11 in this thread has an idea...
  2. #27
    Mar 2005
    germany
    great job
    I am dröfl/conspectumortis from the other Forums.
    You help us (german forums) much with your Information
    It ist incredible that so many people are interessted in the Asus CT479, go on
    Sorry for my very bad english
    Gruß
    P.S: our two german ASUS CT 479 Threads
    click me
    click me
  3. #28
    Apr 2005
    Without any words :-) It's works great!
  4. #29
    May 2004
    uk
    where did you get those round mounting poles? i tried 2 fit my zalmon on 2day and i ave the block type mounting version.
    also wat mobo is that?
  5. #30
    Apr 2005
    Motherboard is Abit BH7, only used for mechnical testing. The round mounting pole belongs to a VapoChill PE. Works great on Asus P4GD1.
  6. #31
    Jan 2003
    Australia
    Quote Originally Posted by TigersClaw
    Good to know that my Vapochill PE should work on it then too.
    Gotta wait till my uni exams are done, but i should have it all up and running by end of June (Vapochill PE, P4C800-E, CT-479 and Pentium M 750).
    Athlon XP-M 2500+ @ 2.9GHz, Abit AN7, 2x 512mb Corsair XMS 3500, Gecube 9800pro Extreme, 120gb WD 8mb cache HDD and PC Power and Cooling 510W Deluxe PSU.
    CPU cooled by a Vapochill PE (Titanium)
    GPU and NB cooled by Eheim 1250, BIX, dangerden Z-chip block (for NB) and Swiftech MCW50-T (for GPU)
  7. #32
    Nov 2004
    DK
    Might be useful?
    Just some mushy sticky stuff...
Name:	Tape around the core.jpg
  8. #33
    May 2005
    MY mobo P4P800 how OC with BANIAS 1g4 code SL6F8
    Vcore Vid MULTI no change
    perhap i have must mode Vcore
  9. #34
    May 2005
    Denmark
    Very interesting, although I would rather have seen a solution on how to mount my Vapochill evaporator head on it
    I have the same metal studs, obviously, but I definitely need a shim before putting the evaporator head on.
    Never Argue With An Idiot. They'll Lower You To Their Level And Then Beat You With Experience!
  10. #35
    Aug 2004
    Milan,Italy
    simply use 1mm neoprene and you are ok
  11. #36
    May 2004
    Stockholm, Sweden
    I'm not sure if it has been mentioned in the other Dothan threads but I tested using a creditcard as a shim and I must say it has the perfect height (assuming the height of the dothan is the same as for the celeron mobiles). Try this! I will most likely use this method this on my upcoming dothan.
    (Note: Ofcource, don't use cards that are not 100% flat, some can have leveled digits.)
  12. #37
    Admin
    Dec 2003
    Hillsboro, OR
    Two ideas I've got; caulking and rubber bands. Not sure which I'll go with.
  13. #38
    May 2005
    Denmark
    Quote Originally Posted by nCrusader
    I will look into this later today, who knows - it might work
  14. #39
    May 2004
    Stockholm, Sweden
    Quote Originally Posted by Pressure
    Good luck, and don't forget to report back since the height of the dothan core perhaps is a tad higher than the celeron's.
  15. #40
    Mar 2005
    notts uk
    Why not just remove the foam from the base of the ct-479 cooler and put it on the dothan chip it's working ok for me with a xp-90 mounted on it.
  16. #41
    Nov 2004
    DK
    Quote Originally Posted by leejsmith
    Thought of that, but I find it hard to get off without ripping it.
    Any tips?
  17. #42
    Mar 2005
    Connecticut,USA
    A blow dryer or heat gun would work to loosen the adhesive on the other side.
  18. #43
    May 2005
    Denmark
    Well, it worked but I couldn't get good enough contact with the core. So I removed the evaporator head and I am now running with the supplied Asus cooler. Guess I will have to try another way but think I will save that for my next Dothan. This one is going into a backup system heh.
  19. #44
    Jul 2003
    SoCal
    FYI, the Dothan core is .82 mm above the silicon.
    <----- REST IN PEACE, KIT. 1993-2007.
  20. #45
    Mar 2005
    notts uk
    I used a sharp knife to life a corner and slowly pulled using the knife with any tricky bits.
    guess i got lucky
    Quote Originally Posted by stryg
    Any tips?
  21. #46
    Jun 2004
    south of heaven
    Quote Originally Posted by uclajd
    So 1mm neoprene should be just right. The type that is used for wetsuit.
    Asus P4C800ED P-M 730@2.8 7700Cu
    2X1GB OCZ - ATI X800XT AIW - OCZ PS 520W
  22. #47
    Jan 2003
    Manchester, Uk
    Is it the p4 skt478 head kit thats needed for the mach 2.
    Still need to wait for a decent board for pci-e as the p4gd1 doesnt seem to good.
    Theres an aopen one coming out but can see it being pretty poor on options
  23. #48
    May 2005
    I have my CT-479, but I'm still waiting on the P4C and 730. Since I have some time to kill I thought I'd replace the floppy pins and solder on a molex as well as get rid of the jumper pins.
    I have been reading a lot of posts regarding this, but there is so much to sift through at this time that I don't know exactly how to do this. Am I do heat up a soldering iron and just slip them off? Or is it necessary to just break them off?
    Thanks in advance!
  24. #49
    Aug 2003
    el segundo, ca
    How bout this for a quick and dirty mod ?
    pic 1
    Pic 2
    Pic 3
    Pic 4
    Just a couple of 3/8 bolts slotted, drilled and tapped to 4mm
  25. #50
    Nov 2004
    DK
    Quote Originally Posted by walaka7
    pic 1
    Pic 2
    Pic 3
    Pic 4
    Looks dirty allright! Thats a Thermaltake Typhoon right?
    Hows that one helping out your overclocking? Significantly higher clocks than on stock?
