Page 2 of 6 FirstFirst 12345 ... LastLast
Results 26 to 50 of 134
Thread: chipset cooler dfi ulltra d sli
  1. #26
    Xtreme Recruit
    Jan 2005
    Quote Originally Posted by Dani
    My Team mate dargness has Artic Cooling Freezer 64 modified for chipset, very nice
    http://www.short-media.com/review.php?r=280
    Pic1
    Pic2
    That is a very ingenious idea.
    How are the temps doing? Also I am guessing it won't work in SLI mode.
    current computer aresnal
    A64 3200+ / DFI "LANPARTY nF4 SLI-DR / 1Gig Gskill LE / 6800GT / watercooled (custom radiator/Maze4 gpu/TDX/AquaExtreme50Z)
    a64 3200+ / MSI K8N Neo2 / 6800gt agp
    a64 3200+ / MSI K8N Neo2 / 6600gt agp
    AthlonXP 1700 file server (almost 1 Terabyte)
    3DMark2001 3DMark05
    xtrmeme workbench
  2. #27
    Phenom™
    Sep 2002
    Quote Originally Posted by Nubius
    hmmm...how is it more accessible at the top? Seems just fine over on the right where most socket A boards had them IMO
    I dunno, I read it somewhere
  3. #28
    Mar 2005
    Pic1
    Pic2
    Wow- that's great. Any temps?
    Thanks,
    CJ
  4. #29
    Mar 2005
    San Jose, CA
    Pic1
    Pic2
    That...is ridiculous. And I want one!
    Seriously, I've been looking for a viable replacement for the chipset fan on my Ultra-D, so this thread is great. The stock cooler isn't bad as they go, but the NF4 just runs hot as hell and that inevitable whining noise really brings out my OCD. I don't want to add any more restriction to my cooling loop (Eheim 1250 driving a TDX, Maze4 GPU, and a 2-199 already), but thanks to the layout I've got virtually no options for an aftermarket hsf cooler.
    That Iceberq really didn't work out, eh?
    -aMp-
    165 @ 2.9 @ 1.45V | 2x1GB G.Skill HZ | NF4 Ultra-D
    MSI X1900XTX | G500 21" Trinitron
    X-Fi Fatality | Z-2300s | Little Dot MkIII | Beyerdynamic DT770 Pro
    TDX | Maze4 GPU | DDC Topmodded | BIP3
    Stacker STC-T01
  5. #30
    Nov 2004
    Boston, MA
    the iceberq didnt work well at all but i think the iceberq4 will do alot better. does everyone that has high chipset temps have a huge video card cooler that blocks the airflow or pushes hot air at the chipset cooler? I ask this because that is why my temps are so high. I installed a zalman vf700cu on my video card and my chipset temps dropped about 7-8C.
    **Georgia Tech Grad, I am an Electrical Engineer with a specialization in RF IC design and Analog circuits.**
    Intel I7 3770K Delidded
    Gigabyte Z77X-UD5H
    2x4gb Gskill 7-8-7-16
    EVGA GTX680 Signature OC
    Crucial M4 256gb
    Seasonic X-750
    Watercooling Loop: Raystorm Acetal, EK GTX580 Full Cover, MCR420, MCR320, MCP35X2 & 7 x AP-15 Gentle Typhoons
    Heatware: gte460z
  6. #31
    Oct 2004
    Quote Originally Posted by s7e9h3n
    That one will work, I've used that one b4. I actually installed a new one last night:
    I believe it has the same dimentions as the Vantec Iceberg VGA cooler, but I had to dremel out a bit to avoid an ic on the board.
    were exactly did you dremel it? if is not to much to ask.
    looks great thx.
    >> Lian-Li PC 7077<<<
    >>Amd 4800x2@2700 storm G4::: Dfi nf4 sli-d<<<
    >>Crucial ballistix 2gb 270x10<<<
    >>ati x1800xt oc@750/800//maze4/ramsinks<<<
    >>seasonic s-12 600w<<<
    posted by:EvilCloudStrife
    "Wow, nice dual 16x! MSI? no thanks"
  7. #32
    Phenom™
    Sep 2002
    I had to dremel here to clear the crystal. Otherwise, the hsf wouldn't make full contact with the chipset.
  8. #33
    Apr 2005
    Long Beach, California
    what r u guys using? ASC5 or AS paste? I have both, I'm assuming the paste would be better for long term so I dont have to keep re applying ASC5... I wanna apply some before I even start to oc
    Opteron 64 165 CCBBE 0617 FPMW 3ghz
    TT Big Tyhpoon cooled
    DFI Nf4 Ultra D AA0
    1gb G.Skill 4800 LA
    XFX 7800 GT
    OCZ Modstream 450W
  9. #34
    Phenom™
    Sep 2002
    Quote Originally Posted by Seriola
    I use AS5. It's thick enough that it sticks the hsf to the chipset relatively well. BTW, what AS paste?
  10. #35
    Apr 2005
    AS paste comes with their HSFs... its silicone compound paste, not sure if it even compares to the AS5... but they say to apply it for their HSF
    DFI Nf4 Ultra D AA0
    1gb G.Skill 4800 LA
    XFX 7800 GT
    OCZ Modstream 450W
  11. #36
    Phenom™
    Sep 2002
    Oh, ok. It doesn't even come close to AS5, but it is better than nothing Use AS5 if you've got it, but if you don't then that stuff will do. Oh, btw, I'm pretty sure that's Arctic Allumina - their value stuff
  12. #37
    Jan 2004
    UK
    Quote Originally Posted by babalouj
    Well I have just tried the Vantec Iceberq and the result was temps about 3-4C higher. Its kinda disappointing because the vantec cooler looks much better than the dfi one. Also, the Iceberq (not iceberq 4 or the spire look alike) needed some alteration to the mounting holes to fit the dfi. Maybe I will try the Iceberq 4 if I can make it out to fry's this weekend.
    Weird, I had no problems fitting the Iceberq to mine although it is a tight fit when pushing the pins in, you must make sure they are in the inner recess of the mounting holes. I've got no regrets about using the Iceberq here.
    £58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
    Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
  13. #38
    Jan 2005
    Northern VA
    That is sweet....any more pics? and what- no fan? I want to see pics of his mount..thanx
    that is insane, and I am highly considering doing that!
    is the center just hacked out? or is there more modification than that.
  14. #39
    Mar 2005
    Montreal, Canada
    Anymore water blocks for that DFI nF4 chipset besides the one in Germany?
    Mine is running dang hot!! 45C @ Tambient 20C, at idle (close case).
    A new chipset fan cooler and HS is no option for me with 2 6800 Ultras exhausting hot air over it.
    CPU Intel i7 930 3001A125 @ 4.0 GHz HT
    Mobo Asus Rampage III extreme 1208 BIOS
    GPU Asus GeForce GTX 770 DirectCU II
    RAM G.Skill Ripjaws F3-16000CL9T-6GBRH DDR3-2000 (6x2GB)
    SSD Corsair Force GT 120GB SATA3
    HDD WD Caviar black 1.5TB SATA3
    HDD WD Caviar blue 1.0TB SATA3 (2x)
    HDD WD Caviar 250GB SATA2 (2x)
    HDD WD Raptor 74GB SATA
    Storage controller IBM M1015 SATA3 RAID controller
    CPU Block Koolance CPU-370
    Radiator Phobya G-Changer 360 (3x Panaflo FBA12G12U 120mm)
    Radiator HardwareLabs Black Ice GT Stealth 420 (3x Yate Loon D14SM-12 140mm)
    Pump Swiftech MCP650 (2x)
    Case MountainMods Pinnacle 24
    PSU Enermax Evo Galaxy 1050w
    Sound SB X-fi titanium Fatal1ty
  15. #40
    Oct 2004
    i had to dremel too there, thx! with the iceberq4 my temps went down 5 degrees...
    >> Lian-Li PC 7077<<<
  16. #41
    Nov 2004
    Boston, MA
    well that settles it then, im gonna go to frys and get a iceberq4 and return the crappy iceberq.
    Gigabyte Z77X-UD5H
    Crucial M4 256gb
    Seasonic X-750
    Heatware: gte460z
  17. #42
    Apr 2004
    Helsinki / Finland
    Quote Originally Posted by CJ4
    Thanks,
    CJ
    Temps are here, dont know if he use fan on it...
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
  18. #43
    Mar 2004
    Toronto, Ontario Canada
    How much did you have to dremel? Could it maybe be done with a metal file?
    Quote Originally Posted by thelostrican
  19. #44
    Oct 2004
    very little, dont really need a dremel, you could use a drill, or a nibbler...
    >> Lian-Li PC 7077<<<
  20. #45
    xtreme energy
    Oct 2004
    Europe, Latvia
    I don't like noise very much, so I did something similar to this:
    Chipset temps are ~41C idle
    P.S. One side of my case is always opened
  21. #46
    Nov 2004
    Kenmore, NY
    Anyone find any other chipset waterblocks that will work with this board? Perhaps one with 1/2" fittings? I really don't feel like downsizing my tubing for the one that someone listed here.
    ~MadMikeSS~
    Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
    P5B Deluxe 1236 BIOS
    HIS HD4850@750/1100 - AX MP-1 cooled
    Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
    FSP 700W PSU
    Lian-Li PC-V2000B
  22. #47
    Mar 2004
    Thanks man, i just ordered an iceberq4
  23. #48
    Mar 2005
    Montreal, Canada
    Quote Originally Posted by HKPolice
    HK, from where?
  24. #49
    Nov 2003
    Any other ready-made sinks that would still fit dual graphics cards (both with big coolers)?
    The Zalman NB47J mod doesn't work with big coolers (I've tried) and with dual long PCI-E cards.
    Iceberq and the stock DFI fans both whine annoyingly.
    Any other options?
  25. #50
    Mar 2005
    Quote Originally Posted by kiwi
    Hey thats mine! You'll get a huge temp drop with some decent airflow, mine idles around 30 degrees.
