I've been googling for 5 hours now, and I find that many people have problems with this boards SATA, but not the same as me.
I really hope that some of you gurus can help me out.
Ok, here goes:
My setup is:
MSI K8N Neo2 Platinum
AMD 64 3000+ 939 (doh)
2x512 Crucial BallistiX PC4000
Aspire 550W (Very good)
2x 36.7GB Raptor
2x 200GB WD Caviar
My ideal setup is the 2 raptors in RAID 0 for windows, and the 2 200GBs for storage.
I connected Raptors on sata 1&2, 200gb on 3&4.
Could not install windows.
Disconnected 3&4, only raptors on 1&2
Installation smooth, and the machine is working perfectly.
Updated BIOS to 1.5 and all the nvidia drives (latest) and connected the 200gbs on 3&4.
The problem begins. My computer hangs exactly at the same spot every attempt, as the first graphical windows-logo is fading in at bootup, when it's still vary vague. Same spot every time.
I disconnect the 200gbs, and the PC is acting completely normal again.
I try to run just the raptors again, but this time on 3&4- no boot, hangs at the very same spot, and even a reinstall don't work (the install itself hangs at the point just befor where you choose where to put the installation).
So i figure it's a problem with sata3&4, at the point where windows is trying to access the disks, because they are detected by BIOS.
I would also point out that I have tried every combination of BIOS settings there is.
DMA access off/on
RAID enabled/disabled with and without making fake arrays
You name it.
Therefore I assume:
All my drives are OK
I am not a noob
The problem has to do with SATA 3&4, with any drive
I can't figure this out by myself.
Notes:
I am not overclocking,
The system is brand new,
It's working perfectly (100%) when I lay off sata 3&4
Can anybody help me?
Edit: LOL my sig is outdated. Been a while since I've been here.
