XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 03-13-2005, 04:56 PM   #1
Arkangyl
Arkangyl's Avatar
Need a semi-budget Power Supply
I have an X-Connect right now which is working fine, but the thing just pisses me off to no end with its frickin huge plastic connectors, stiff cables and low rails. Also I'd like a REAL 24-pin connector because I'm thinking that nForce 4 is in my future.
Preferably I'd like the new PSU to be under $100 but thats not set in total stone, just a baseline because I know the OCZ Powerstream, PC P&Cs are great and all but they're just waay out of my budget.
Anyways, here are the PSU's I'm looking at, right now it seems to be a real toss up betweent them so I'm hoping for some opinions and suggestions, on to the list
Tagan 480w
Enermax Noisetaker 485w
Fortron Source 550w
Zippy 500w
Antec NeoPower 480w
CoolerMaster Real Power 450w
OCZ Powerstream 470w
so thats the list I've come up with of good PSU's in that price range, any ideas?
__________________
i7 920 @ 3.7ghz || Bloodrage || 6gb Pi Black || GTX 260+ || Xonar STX || 300gb VRaptor || U2-UFO
PA 120.3 & MCR-220 || DDC-3.2 XSPC || EK LT|| XSPC FC GPU
Arkangyl is offline   Reply With Quote
Old 03-13-2005, 05:10 PM   #2
KoolDrew
I'd go for the OCZ Powerstream. A very good PSU.
KoolDrew is offline   Reply With Quote
Old 03-13-2005, 05:21 PM   #3
Dissolved
XS Local
Dissolved's Avatar
Send a message via AIM to Dissolved Send a message via MSN to Dissolved
id look around the forums and see if anyone has one of those fortons 450w with adj rails..
Directron had them on sale last year for 20+shipping, and ive seen a few people rid of them lately in the classifides for cheap. there soild, and you got pots in them.
__________________
Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
DFI SLI-DR Expert 11-25 Bios
G-Skill 1gb GH UTT @210 2-2-2-5
BFG 7800GT OC 485/1170 NV 5rev3
74gb Raptor 300gb Maxtor 500gb Hitachi
OCZ 520w SLI 3.46v 5.16v 12.64v
Thermaltake CL-P0114 Big Typhoon
3dmark01 3dmark05
Heatware
Dissolved is offline   Reply With Quote
Old 03-13-2005, 05:58 PM   #4
Disposibleteen
Xtreme Guru
Disposibleteen's Avatar
Send a message via AIM to Disposibleteen
rock solid rails too, that'll be my new one when i get one.
Disposibleteen is offline   Reply With Quote
Old 03-13-2005, 06:45 PM   #5
k0nsl
k0nsl's Avatar
Send a message via MSN to k0nsl
Yep, I'd go for OCZ Powerstream too, that or their Modstream.
-k0nsl
k0nsl is offline   Reply With Quote
Old 03-13-2005, 06:47 PM   #6
SLaY3r07
SLaY3r07's Avatar
Send a message via AIM to SLaY3r07 Send a message via MSN to SLaY3r07 Send a message via Yahoo to SLaY3r07
-k0nsl
If you want looks get the modstream. But if you want performance over looks (Which the powerstream looks sexy anyway) get the Powerstream.
__________________
Got news? Post it HERE
SLaY3r07 is offline   Reply With Quote
Old 03-14-2005, 12:26 AM   #7
Squid_Spit
Squid_Spit's Avatar
Send a message via MSN to Squid_Spit
i agree go for the powerstream
__________________
A64 X2 3800 @ 2.75ghz
DFI Lanparty UT NF4 Ultra-D
1024mb Team PC3200 BH5
eVGA 6800GS 550/1255
1x 36GB Raptor, 80GB WD SATA, 320GB Seagate SATAII
Enermax Noisetaker 470w
LR Cascade, MCW50, Double HC, Swiftech MCP650
Dell 2007WFP
Squid_Spit is offline   Reply With Quote
Old 03-14-2005, 10:12 PM   #8
Arkangyl
Arkangyl's Avatar
I'm suprised there's no ecouragement for the Zippy, I thought they were very good PSU's
__________________
Old 03-14-2005, 11:27 PM   #9
evetS-
evetS-'s Avatar
http://www.newegg.com/app/ViewProduc...104-934&depa=1
Fortron 500W Blue Storm. A lot of people from ocforum say its pretty good. If I didn't get my powerstream I would have probably picked that up, but I bought my OCZ from someone for 80 bucks
__________________
Chip:
Intel E6320
Hardware:
DFI P965-S (fried)
Gigabyte GA-P35-DS3R Watercooled
BFG 8800gts
2x1GB Crucial Ballistix
Corsair HX620
evetS- is offline   Reply With Quote
Old 03-14-2005, 11:34 PM   #10
ArcTan
how about that versus the superflower 500w
which would be better?
ArcTan is offline   Reply With Quote
Old 03-15-2005, 08:01 AM   #11
Xerxes
id go with the fortron or zippy. or if you want something on the quiet side the seasonic 430w s12. on a side note the fortron and seasonic are rated in continuous power (not sure about the zippy)
Xerxes is offline   Reply With Quote
Old 03-15-2005, 11:47 AM   #12
isp
isp's Avatar
I thought the 470 was discontined...
I think you'll have to go 420. I'd go for the powerstream though, adjustable rails right out of the box is convenient.
__________________
Heat
isp is offline   Reply With Quote
Old 03-15-2005, 01:13 PM   #13
charlie
THE GENERAL
charlie's Avatar
Rosewill 550W... great SPEC's and looks similar to an OCZ PStream??? Maybe made by e-power????
http://www.newegg.com/app/ViewProduc...182-010&depa=0
__________________
xtremespeakfreely.com
charlie is offline   Reply With Quote
Old 03-15-2005, 01:24 PM   #14
enzoR
XS Intel News & DČOL enhanced
enzoR's Avatar
Ocz
enzoR is offline   Reply With Quote
Old 03-15-2005, 01:29 PM   #15
KoolDrew
The LED's lead me to think it would not be a very good PSU. I am just assuming, but I have not heard any good nor bad things about their PSU's
Old 03-15-2005, 01:54 PM   #16
sjohnson
X. I. P.
sjohnson's Avatar
TTGI 520, http://www.directron.com/tt520ss4fanb.html
At $55, you can't go wrong. Built like a tank, adjustable (internal) rails.
__________________
The plural of "anecdote" is not "data."
sjohnson is offline   Reply With Quote
Old 03-15-2005, 02:11 PM   #17
Arkangyl
Arkangyl's Avatar
Thanks guys, I'd go for the TTGI but I want the ATX 2.0 spec and I dont see that supported anywhere.
So it's down to the;
Zippy 500w
OCZ 470w
FSP 500w 'Blue Storm'
Rosewill 550w (nothing about it anywhere thus far)
thanks for the help guys. Also, does the Zippy have voltage pots?
__________________
Old 03-15-2005, 02:17 PM   #18
KoolDrew
I'm sticking with my original suggestion. The OCZ
Old 03-15-2005, 02:26 PM   #19
alexio
The Blue Dolphin
alexio's Avatar
The Tagan 480W has better rails (higher amp) than the OCZ Powerstream 470W.
I'd go with the Tagan, I've got one too and the rails are really rocksolid.
__________________
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
alexio is offline   Reply With Quote
Old 03-15-2005, 02:40 PM   #20
sjohnson
X. I. P.
sjohnson's Avatar
IIRC the PSU I linked to has the 24 pin connector. But, if you still want to consider the TTGI, check out http://www.directron.com/tt520ss.html
At $88, it's the same PSU and has the 24 pin, guaranteed.
__________________
Old 03-15-2005, 03:53 PM   #21
JDizzle
JDizzle's Avatar
I'm about to make the same decision as you Arkangyl. Right now I'm leaning towards the Fortron Blue Storm 500W. I've only read good things about them and own a great FSP PSU right now, I just need something with a 24pin connector. The specs on the Rosewill do look good but I have not heard one thing about them so that alone makes me shy away from them. The Zippy 500w is a little expensive, might as well get the OCZ 520W Powerstream if you're going to spend that much.
__________________
Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
Gigabyte DS3 C1 F8i
2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
Asus EN6200 8 pipes enabled
250GB Hitachi T7K250
Antec P180
JDizzle is offline   Reply With Quote
Old 03-15-2005, 04:36 PM   #22
Xerxes
rosewills are generally made by atng (also deer and leadman). if that one is also (id say most likely) stay away from it
Old 03-15-2005, 04:59 PM   #23
Iggk
i have the FS blue storm it's a great PSU with "good" rails there is a pot inside that controls the 12v and 5v rails with 1 pot dont think there is an adjustment for the 3.3v
.i dont know how the 12's are split or even if they really are when testing load on any 12v point i would see a drop on all other 12v's i dont think this should happen with the ATX2.0 2x12 spec's.
has anyone else tryed anything like this on any 2x12v rail psu?
__________________
DFI Ultra-D
3200 Winnie 310x9
PDP TCCD
X850XT 620/620
3DMark 05
3DMark 03
3DMark 2k1
Iggk is offline   Reply With Quote
Old 03-15-2005, 05:07 PM   #24
Arkangyl
Arkangyl's Avatar
where are you measuring each 12v rail? I think you need to measure from a molex and the ATX cable to get both readings, any sort of monitoring proggy will just offer the ATX voltage.
Alexio, thanks for the praise of the Tagan, you just made this a little harder :p I really like what I've heard of the Tagan, big fan of the quiet elegance here...
Iggk, when you say "good" rails I'd like to know what that means; is good in "" just because of the question about the dual rails or beacuse they fluctuate under load? If it's the latter I might as well just get the FSP-550w and nab the extra 50w.
__________________
Old 03-16-2005, 01:16 PM   #25
Iggk
good because the 5 and 12 were sligtly low (4.96/11.92) but verry stable under load (voltage actualy came up about .02v)and i was able to bring them both up with the 1 pot.
the 3.3v is still allitle low (3.28 idle, 3.29 load) and i dont think there a pot for it.
and all measurements are from wires not bios or a monitor.
__________________
DFI Ultra-D
3200 Winnie 310x9
PDP TCCD
X850XT 620/620
3DMark 05
3DMark 03
3DMark 2k1
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
