XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 03-07-2005, 04:41 AM   #1
kayl
-100C Club Member
kayl's Avatar
Send a message via MSN to kayl
kayls Autocascade rev2
well this one is going to be smaller.
will test it with 1/2Hp for now. i know how to use co2 now after playing with cascades.
im going to stick with the old hx
just insulate it properly.
i plan to be making a 40mm evap and maybe a 30mm evap for testing cpu the gpu cooler. i cant wait.
one hx is done i will only have to insulate dd evap suction line and maybe about 30cm of suction line. i like this design, very little losses.
kayl is offline   Reply With Quote
Old 03-07-2005, 05:45 PM   #2
f00t
Send a message via MSN to f00t
cant wait to see it. i'm just waiting for some co2 to get here so i can charge my autocascade. it's also nice and small.
f00t is offline   Reply With Quote
Old 03-07-2005, 08:44 PM   #3
WindStorm
Nice heat exchanger. Is this going to be the same principle co2 chamber that Jan is also using? This will make really cool gpu cooler.
WindStorm is offline   Reply With Quote
Old 03-07-2005, 09:32 PM   #4
kayl
-100C Club Member
kayl's Avatar
Foot cant wait to see ya autocascade. Co2 will bring ya some fun.
windstorm Im not sure exactly how jans hx works, but assume it similar to other hxs being designed for autocascade. I have 3 sets of pipes in there.
Co2 condenser pipe, shell r290 boils in and I also pass the suction line through there.
It’s the one out of the first autocascade hx,
I just attacked it with a pipe bender to make it smaller, will insulate it the same way as I did the cascade.
Old 03-08-2005, 05:03 AM   #5
Scout255
good work man, looks great!
Scout255 is offline   Reply With Quote
Old 03-08-2005, 01:46 PM   #6
f00t
i'll post some pics when i get hold of a camera, just for you Kayl
Old 03-08-2005, 03:19 PM   #7
gkiing
gkiing's Avatar
hey kayl, that looks pretty small for a 1/2hp compressor, what make is it? might just be the perspective though.
I'm working on finding a used rotary compressor so I can fix my autocascade.. 1/4hp doesnt cut it with co2.
__________________
AMD 1700+ @ 2850Mhz 1.95v (24/7 Setting) || ABIT NF7-S v2.0 ||2x256MB KHX3200 || 120GB Seagate 7200.7 SATA/80GB 7200.7 IDE|| 9800Pro || R22/R170 (Ethane) Cascade -80C Loaded
I reject your reality and substitute my own
gkiing is offline   Reply With Quote
Old 03-08-2005, 03:24 PM   #8
kayl
-100C Club Member
kayl's Avatar
thanxs scout55, foot l like pics i cant wait.
gkiing it is small very quiet. would make a perfect cooler, if i can get it to run autocascade.
i wish i had 2 of these compressors, could have 2 side by side.
Brand: L'unite Hermetique
Modell:CAE2420Z
Cyl Volume: 12.50cm3
Capacity at -35: 257w
Capacity at -30: 349w
Low temp R404A @ -10c suction it will move 2000 Btu.
Weight: 13kg
im starting to like pipe benders
Old 03-08-2005, 11:12 PM   #9
reject
reject's Avatar
Send a message via MSN to reject
looking good kayl, wat other gas will be used, bbq propane or hc22/502?
__________________
Originally Posted by bh2k
sorry m, OI'm a bit drunkz!
Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
reject is offline   Reply With Quote
Old 03-09-2005, 03:31 AM   #10
Tonic
Tonic's Avatar
kayl, should you shot a few good photos of compressor? My looks identically as your,
but, according to technical document, it has ~12ccm motor's displacement and 1/3HP..
It make me unsure, why 1/3HP, not 1/2HP? Model name - CAE2410A, as I remember correctly
Whatever, I love this compressor, it has massive shapes, electricity device
looks nice and loudness level is low
Tonic is offline   Reply With Quote
Old 03-09-2005, 08:53 AM   #11
WindStorm
Kayl...very compact system. Nice receiver you made. What size cap are you using to cool the hx.?… Man you rock you just started this two days ago and it looks complete
Old 03-09-2005, 09:43 AM   #12
G H Z
anti-eraser crew
G H Z's Avatar
What is an auto-cascade?
__________________
Originally Posted by saaya View Post
is it just me who is distracted big time by those super gay white latex pants the guys are wearing?
G H Z is offline   Reply With Quote
Old 03-09-2005, 10:51 AM   #13
Tonic
Tonic's Avatar
It's a phase change unit, where is one compressor, phase separator and two gases - one gas cools second gas
First gas evaporates between -30*C and -40*C, second stage evaporates between -50*C and -80*C
Old 03-09-2005, 11:56 AM   #15
G H Z
anti-eraser crew
G H Z's Avatar
So a single compressor pumps a gas mixture that is seperated somehow, then these individual gasses are used like in a typical cascade?
__________________
Old 03-09-2005, 12:09 PM   #16
illmatik
Does the HX act as a subcooler in a traditional system, except that a compressed 1st stage gas will cool the condensed 2nd stage?
I'm still kind of learning about basic stages here, so please correct (and forgive) my ignorance. From my knowledge so far, in a subcooler, the suction line gas will cool down the liquid line to give the system a little bit of a boost? Or are you using a 1st stage liquid that is separated to cool a 2nd stage liquid prior heading to the evaporator?
illmatik is offline   Reply With Quote
Old 03-09-2005, 12:30 PM   #17
Cra$h 0veride
Cra$h 0veride's Avatar
I believe its the 1st stage condensed refrigerant that cools and causes the 2nd stage refrigerant to condense (usually CO2) then the CO2 moves on to the evap on cpu.
Cra$h 0veride is offline   Reply With Quote
Old 03-09-2005, 01:10 PM   #18
Tonic
Tonic's Avatar
G H Z, bingo
illmatik, 1st stage gas is condensed. 2nd stage gas is desuperheated (it's cooled by
condenser, but it doesn't become a gas, he's still in gas phase). Condensed gas
evaporates and cools 2nd stage gas.
It isn't subcooling
Cra$h 0veride, you're right
Old 03-09-2005, 02:48 PM   #19
G H Z
anti-eraser crew
G H Z's Avatar
How is the gas seperated?
Sorry bout the jack kayl, just trying to understand exactly what your doing here so I can honestly say Nice job!
__________________
Old 03-09-2005, 04:02 PM   #20
kayl
-100C Club Member
kayl's Avatar
for testing I always use bbq r290, normal single stages I always use hc22/502 cause they only take about 4sec of charge, the autocascade and cascade would take a lot of hc22/502 and I only got a few kg’s left.
If I build a autocascade im gonna keep I will use hc22/502.
But im always changing things so that’s a while off, unless this is a good gpu cooler
im really not exactly sure, a while back I posted this, and ppl said it was 1/2Hp, might be a 1/3Hp
Have you a link to that spec sheet talking about.
http://www.xtremesystems.org/forums/...04a+compressor
thanxs once I start I have a hobbit of brazing until finished
no receiver used in this one, capillary line is 0.028” about 1.8m 1st stage and about 2.3m 0.031” secondstage.
That’s cool, after the gas leaves the compressor passes to the condenser, then it enters a map gas cylinder about 1/3 way up bottle. At room temp and this pressure r290 will condense into a liquid and collect at the bottom of the cylinder. It then feeds via capillary line to hx (1st stage) -30c.
Back to the map gas cylinder now, at room temp and this pressure c02 is a gas and exits the top of the map gas cylinder as a gas. It is then passed through the hx where its cooled and pressure is reduced and it is able to condensed into a liquid and the fed by capillary line to 2nd stage dd evap to freeze -70c –80c hopefully.
Old 03-09-2005, 05:24 PM   #21
illmatik
So when you are tuning/experimenting, are you guys reclaiming and refilling the system each time you need to say, do a cap tube adjustment? I would assume flares need to be brazed/soldered each run due to the psi in the system, no?
Old 03-09-2005, 05:35 PM   #22
bh2k
Xtreme Hardware Killer
bh2k's Avatar
flares don't need to be brazed or souldered if you do them right. In the us we are required to recover any refridgerent.
__________________
Level 80 UD Death Knight on Murmur (Beta)
bh2k is offline   Reply With Quote
Old 03-09-2005, 05:41 PM   #23
illmatik
Wow that's good to know (flaring. knew about recovery laws). So it should make cap tube adjustments much easier to do when tuning these pre made units like vapos. I'm trying to go thru this Tomczyk Refrigeration & AC coursebook and lab guide in between work and mba work in the evening, hoping it shows how to do quality tooling and stuff.
Old 03-09-2005, 07:27 PM   #24
kayl
-100C Club Member
kayl's Avatar
yeah when making capillary line changes etc ya have to vacuum again and regas, takes alot of time.
flairs would be about the same amount of effort really. still have to vacuum and apply the appropriate sealant to the thread so it doesn’t leak and tork it correctly.
flairs main use for things like txv etc that dont like to be heated (ie brazed), all other joins i prefer to be brazed.
some ppl have their dd blocks on flairs so can swap, i like them brazed, just another thing to leak if done incorrectly.
propane and co2 releasing into the air isn’t illegal, but other refrigerants should be reclaimed. another advantage to using r290 and co2.
no need to reclaim.
Old 03-09-2005, 07:37 PM   #25
gkiing
gkiing's Avatar
no need to reclaim.
Yeah, not needing to reclaim gas is a big advantage
You dont need to put sealant on flares if you use a copper gasket, it gets compressed and makes a gas tight connection. Use two wrenches to tighten the flare nut too.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
