I got a little problem with my Prometeia Mach II. Problem is that it starts at once when i plug in the power cable. The relay on the circut board isn't burned and it also reacts when i give the unit 230V. It doesn't boot if I disconnect the thermo sensor, so that seems to work just fine. Someone with any suggestion on what the problem may be?
