DFI nF3 UT = yes ( 3.6volt ive tested ) , but with 2 DS sticks its unstable cuz the booster dosent fit in slot3
DFI LP 250GB = Ok, 4.1V in Booster -> 3.93V from mosfet -> 3.87V in SmartQuardian
- Team Skootterit
- SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
Just got the Booster. Working great on MSI Neo 2 Platinum mobo.
Able to push my BH-5s.
(long time no post, in this thread)
well, its time (for me) to move on to 64s... anybody have a booster running in a Abit AV8 939 mobo? (which slot & how high? :banana4: )
thanks!
PS nice Storm WB htkm1 !!
JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe - - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master - - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
works fine - NF7-S with 3,6v.
http://lepclan.com.br/webfile/sandra260fsb.jpg
hi guys, i got the EpoX 8rda+ Rev2.1 ..and read that the booster isn't working on that mobo.. but i've just recieved one 8rda+ rev2.1 but Limited Edition, i noticed that the voltage regulator chip differs from that on the regular 8rda+rev2.1 , i'll be so happy to know if the booster works on the Limited Edition of the board.. and one last question: Is it dangerous for the board if i try without knowing if it will work or not.. and is there a chance that the booster will burn my mobo if it doesn't works?
I know that the title of this thread is motherboards that the OCZ diagnostic thing works in, but here is one that most definately doesnt.
DFI Infinity athlon board. Have a booster and thought what the hell give it try (yeah I know the site sand list in the box says not to use it on the lanparty nforce board, but I stupidly thought, it might work on the infinity). Put it in and then decided to ramp up the voltage a bit - turned knob to 3.4V and machine crashed - electrical burning smell!
Board will not boot at all, no matter what memory config I use the wee led beside memory no longer works. I hope to god that the OCZ ram is OK and the Radeon 9800pro and the XP-M 2500 are OK
What an ass I am!
lol that sounds bad so i'm not going to try it with my new limited edition 8rda+ before i got 100% confirmed information that it works ..
I am also on Epox 8rda3+ rev 2.1,and i have a booster but it all depends on what psu you got,best is a 450w or above.Originally Posted by bug
I run it with a chieftech psu 360w rightnow and cannot come above 3.1v with the booster,with 520w psu it will be easy over 3.4v and higher.
Asus P5K<*>OCZ 450w<*>E6600@4.0ghz@9x445@1.450v<*>TeamXtreem DDR2-800 cl3 2x1gb<*>Sapphire 3870 512mb DDR4
Asus P5E X48 DeLuxe<*>OCZ 700w<*>E8600 E0@4.6ghz@1.350v wc<*>Corsair Titanium DDR2-800 4x2gb<*>Sapphire 2x3870 2x512mb DDR4 CF
i make this at 3.4v
Originally Posted by htkm1
3.6?? .....when I put more than 3.4 the msi reset........why??
Just ordered this for a GB k8Ns Ultra 939. the xp works to 3.7v so I'm going to assume it works with this board too.
anyone tried with abit AV8??
put your finger in the mouth, laughing crumbs keeps your youth... :banana4:
this is a post in the "S939 mobos - known bugs, tweaks and fixes" thread:
well, i just grew balls (or REALLY need to sleep...)Originally Posted by Rauf
OCZ DDR Booster is in and running on my AV8
DDR @ 3.0V and DDR VTT is tracking (reads 1.54V)
upping on the fly...3.3V but VTT is still 1.55...3.4 but 1.5...
upped (in bios) DDR to 2.8 (max)...booster@3.2V VTT@1.66
could be bios setting could be reboot...
not real stable or "Mushie 222 rev 2"s ("new"? TCCD) dont like >3.0V...
be ready to get a fan on your MEM...pups got HOT!
So it does work with AV8... Could this be that the Motherboard even ADDS its own VTT and the voltage coming form the booster, so it gives the ram ~6 VOLTS??
are u able to get the board stable with the booster in it? is anyone able to get it booster - stable?
huh?Originally Posted by burnhead
VTT should be 1/2 of VDIMM (+/-)
i should be able to get some better stats today (after my 4 hour nap)
aahhh... i see... then it could be, that the board doesn´t read it out EXACTLY.... this little differences...
what a 4 hour nap?
i put the booster in at like 5:45am and gave up and went to bed @ 7:45am and now its 11:30 - 12
EDIT:
ok i can now say that the VTT tracks after a reboot.
this is still @ (BIOS) setting DDR 2.8V (max) ... havent tested other settings
tested as high as 3.3V (VTT went to 1.70V)
id say we have a winner
PS geting a higher FSB with 3.3V vs 3.0 (Mushkin 222 V2)
pardon? what does "VTT Tracks" mean???
what do you mean with "we have a winner"? is AV8 best board ever for clocking or what?
as much as id like to say look it up yourself...
some mobo's (Abit NF7-s) dont "track" (keep VTT at 1/2 VDIMM) above the mobo's standard setting
and thus dont work well with the DDR Booster.
this mobo does... thus the "we have a winner"
PS doing some MAX mem tests (with 3.3V and relaxed timings) and the G-Skill "seem" to respond better than the Mushkins...
8rda+ rev2.1 Limited Edition .. not 8rda3+Originally Posted by RocKer
my psu is 450w..
the only thing i know is that the voltage regulator chip differs from the regular 8rda+ rev2.1 and 8rda+ rev2.1 limited edition.. and the thing works on 8rda+ rev1.1 .. that's why i want to know if it works on the LE...
Any1 tried the booster in Shuttles SN95G5 Barebone?
Shuttle SN95G5
Joe Camel:
I got the same combo.
I'm a bit currious.
Which dimm socket are you running the booster in?
Does it work with ASUS SK8N motherboard?
Hey guys,
Well given that no one has posted about the EPOX 9NDA3+ motherboard I will :
DO NOT TRY THE BOOSTER IN THE 9NDA3!!
It ain't pretty what happens. It will cause MOSFET to explode. We all know what happens then. The board has been added to the official list on the OCZ website as incompatible.
