Page 1 of 4 1234 LastLast
Results 1 to 25 of 97
Thread: Critical Design Flaw Found in WD Caviar Green HDDs
    Registered User Hawk-NGO's Avatar
    Apr 2010
    It has come to our attention that Western Digital's Caviar Green HDDs suffer from a critical design flaw caused by an aggressive power-saving feature. Western Digital has developed a new technology called Intellipark (aka Idle 3 mode) and it is designed to reduce power consumption, in part by positioning the HDD's heads in a park position and turning off unnecessary electronics after 8 seconds of inactivity.
    According to an in-house investigation and user reports', some software and operating systems are incompatible with the Intellipark feature causing endless head parking movement as the HDD continuously goes in/out of idle mode. This abnormal behavior creates stress on the HDD and that could lead to the following issues:
    • Loud clunking/clicking/buzzing noises every few seconds.
    • Artificially increases the number of load-unload cycles in S.M.A.R.T.
    • Possibly shortens life-time of the HDD.
    • Possibly reduces performance of the HDD.
    Read more: http://www.ngohq.com/news/19805-crit...reen-hdds.html
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    strange that wd didnt notice this while testing
    When i'm being paid i always do my job through.
    Aug 2004
    Sweden
    This has been going on for a long time. Not saying that it has been posted here before tho, but end users have been changing these settings for years.
    Jan 2007
    this has been going on with WDs green line for quite some time now...actually if i remember right it was introduced with the switch to 500gig platters at the time ...
    or to put it another way ever since they introduced this feature in the green drives theres been problems.
    they should just remove it entirely
    "Generally speaking, CMOS power consumption is the result of charging and discharging gate capacitors. The charge required to fully charge the gate grows with the voltage; charge times frequency is current. Voltage times current is power. So, as you raise the voltage, the current consumption grows linearly, and the power consumption quadratically, at a fixed frequency. Once you reach the frequency limit of the chip without raising the voltage, further frequency increases are normally proportional to voltage. In other words, once you have to start raising the voltage, power consumption tends to rise with the cube of frequency."
    1st
    CPU - 2600K(4.4ghz)/Mobo - AsusEvo/RAM - 8GB1866mhz/Cooler - VX/Gfx - Radeon 6950/PSU - EnermaxModu87+700W
    2nd
    TRUltra-120Xtreme /// EnermaxModu82+(625w) /// abitIP35pro/// YorkfieldQ9650-->3906mhz(1.28V) /// 640AAKS & samsung F1 1T &samsung F1640gb&F1 RAID 1T /// 4gigs of RAM-->520mhz /// radeon 4850(700mhz)-->TRHR-03 GT
    3rd
    Windsor4200(11x246-->2706mhz-->1.52v) : Zalman9500 : M2N32-SLI Deluxe : 2GB ddr2 SuperTalent-->451mhz : seagate 7200.10 320GB :7900GT(530/700) : Tagan530w
    Nov 2005
    Where the Cheese Heads Reside
    Really so this is in all Green drives.... Wonderful. Got 2 1TB WD Green's, that I've been using in my server. Might not be much but the data on the 2 drives is quiet important and don't need it failing because something that slipped QA years ago :/
    -=The Gamer=-
    MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
    8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
    Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
    BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
    -=The Server=-
    Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
    3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
    Heat
    Xtreme X.I.P.
    Nov 2002
    Shipai
    As I've said before, a feature that can't be disabled is not an advantage and not progress ...
    And this is what you end up with Ts Ts Ts
    Nov 2006
    Wasn't this the reason you couldn't run these drives in RAID? I could swear users were aware of the direct cause of this issue before, interesting to see that WD is just now acknowledging it.
    Xtremely Hot Sauce
    Sep 2007
    New York
    Hardly surprising about the design flaws. These things have been getting a bad reputation for high failure rates for months or years. At the moment, the only good and cheap drives are Samsung Spinpoints.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Xtreme Cruncher
    Jan 2005
    England
    Quote Originally Posted by WangChung View Post
    you may well be right
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    Oct 2009
    Quebec, Canada
    We've had so many of those green fail us at work, I'm not surprised in any case.
    Main : i7 920 D0 @ 4ghz on Rampage II Gene - H2O - 6gb XMS3 1680mhz C9 - GTX 580
    Sossaman : Dual Yonah @ 2.0ghz
    Server: 1055T 6 core @ 3.6ghz - air cooled - 16gb KVR1333 - 8 x 1TB Caviar Black
    HTPC : i5 760 @ 4ghz on Maximus III Gene - H2O - 8gb KVR1333 - GTX275 - 80GB X25-M G2 + 4 x 2.5" Caviar Black 500GB @ 7200RPM
    chrunching for our future
    May 2004
    AB. Canada
    I have 5 of them in Raid6, No problems with them what so ever
    "Great spirits have always encountered violent opposition from mediocre minds" - (Einstein)
    Sep 2010
    US, MI
    Yep, known for along time now.
    They park there heads every 5secs.
    Which causes alot of stress.
    Older ver's of the drives you could mod with 2 dos util's.
    One util was to change the idle config, the 2nd to enable some sort of raid command/s that the green drives didn't have but the blacks did.
    My 2 drives were among the last models to support those apps.
    The newer drives, the 1.5tb and above, can't use those 2 dos apps.
    Really a shame though, greens are the way to go, nice after they are modded.
    They are slower by 10megs compared to the blacks but there temps and wattage requirements are awesome.
    I would not buy a green unless you could mod it.
    So essentially I would never buy another green drive again ^^, sucks.
    But that's just how things are, unless westerndigital wants to re-open the ability to mod them.
    I completely disabled idle on my 2 drives.
    Still uses way less power then the blacks.
    I think the 2 apps were called:
    wdidle3_1_00
    WDTLER
    Code:
    // Copyright 2005-2008 Western Digital Corporation
    // RESTRICTED RIGHTS LEGEND
    // Use, duplication or disclosure by any commercial industry (public
    // or private), private individual or by any Government Agency without
    // an expressed written consent of release from Western Digital
    // Corporation is subject to restriction set forth in paragraph
    // (b)(3)(B) of the Rights in Technical Data and Computer Software
    // clause in DAR 7-104.9(a).
    // Manufacturer is:
    // Western Digital Corporation
    //   20511 Lake Forest Dr.
    //   Lake Forest, CA 92630
    //   1-800-275-4932
    WDIDLE3 Version 1.00 for DOS
    DESCRIPTION
    - DOS Level utility to setup or report the idle3 value.
    FEATURES
    - Scan for all drives. Non-WD Drives shall only show the model and serial
      numbers.
    - Uses a Vendor Specific Command to set or get the idle3 timer.
    - Timer can be set from 100 ms to 25.5 seconds, in 100ms increments.
    USAGE
    WDIDLE3 [/S[<Timer>]] [/D] [/R] [/?]
    where:
    /S[<Timer>] Set timer, units in 100 milliseconds (1 to 255). Default=80.
    /D          Disable timer.
    /R          Report current timer.
    /?          This help info.
    DOS ERRORLEVEL
    0     No error
    1     Drive problem
    254   Internal program error
    255   Invalid command line argument
    The other prog I think is the raid timeout modder thing.
    Edit:
    Just realized, Hawk-NGO and his/her website... in the news again.
    Ohwell I guess lol.
    Xtreme Guru
    Apr 2005
    Finland
    Is Samsung really the only decent reliable manufacturer atm? Oh wait not for long...
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    May 2005
    TLER is the big issue with breaking the raids on higher capacity drives, parking/unparking the heads should be consistently fast enough not to break a raid.
    Work Rig: Asus x58 P6T Deluxe, i7 950 24x166 1.275v, BIX2/GTZ/D5
    3x2048 GSkill pi Black DDR3 1600, Quadro 600
    PCPower & Cooling Silencer 750, CM Stacker 810
    Game Rig: Asus x58 P6T, i7 970 24x160 1.2v HT on, TRUE120
    3x4096 GSkill DDR3 1600, PNY 660ti
    PCPower & Cooling Silencer 750, CM Stacker 830
    AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
    2x2gb Patriot DDR2 800, PowerColor 4850
    Corsair VX450
    Xtreme Supporter
    Jan 2008
    USA
    Quote Originally Posted by highoctane View Post
    Not to get off topic but is TLER required for RAID10? I'm trying to figure out if I have to go with the RE4 drives (which support TLER) for my future RAID10 setup with 2TB drives. Thanks.
    Jan 2007
    Dorset, UK
    Quote Originally Posted by D749 View Post
    Ask yourself why you are building a RAID 10. You want reliability - that's the mirror part. RE class drives are an order of magnitude more reliable (bit error rates). You want speed - that's the stripe part. RE4 drives are intrinsically faster than standard greens. And they are designed to run properly in RAID.
    OK, you are going to pay more for that reliability, but surely that's worth it long-term (less disk replacements) if you're considering such a setup? So if you're not looking for an as-cheap-as-sh*t RAID solution, but you want the speed and reliability you expect from this setup, why on earth would you NOT want the RE4s?
    Quote Originally Posted by Particle View Post
    Software patents are mostly fail wrapped in fail sprinkled with fail and sautéed in a light fail sauce.
    Mar 2005
    i have this drive and it has the same symptom as described. it's annoying as it would affect my gaming. time for me to move files to another drive, yikes.
  18. #18
    Jun 2002
    Ontario, Canada
    That's why I never buy any of that power saving garbage. I'd rather use full speed, "all the time" drives. I don't care about the few watts per drive I'll save.
    As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
  19. #19
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    That sounds about right. "Green" drives are really good for bulk data only... eg. media, not your OS disk. As long as you use them that way they're fantastic... of course it's just about impossible to convey that to the general public.
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
  20. #20
    Xtreme Mentor
    Jun 2008
    France - Bx
    I'm not suprised ... Plenty problems at work with this green series ...
  21. #21
    Jul 2008
    US
    Greaaat. Glad I just stuck one of these in my HTPC for TV recordings... :-/
    Maybe they can patch it with firmware updates?
    --Matt
    My Rig :
    Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
  22. #22
    Feb 2009
    Montreal
    Quote Originally Posted by Serra View Post
    Quoted for truth. I'm using my green drives for a flexraid array for archives and the files are split so that the usage pattern spins only one drive per cluster of activities.
    Quote Originally Posted by dng View Post
    I'm afraid you didn't purchase the proper drive for your application. The green drives are not meant to be system drives.
    Quote Originally Posted by freeloader View Post
    This guy probably doesn't have 25 drives idling 90% of the time
  23. #23
    Aug 2008
    WD aknoledges the problem with the models: WD20EADS, WD20EARS, WD15EADS, WD15EARS, WD10EADS, WD10EARS, WD8000AARS, WD7500AADS, WD7500AARS, WD6400AADS, WD6400AARS, WD5000AADS, WD5000AARS
    Then, it directs you to download the wdidle3 as a fix. BUT they didn't updated the wdidle3 page to reflect those new models:
    This utility is designed to upgrade the firmware of the following hard drives: WD1000FYPS-01ZKB0, WD7500AYPS-01ZKB0, WD7501AYPS-01ZKB0.
    CAUTION: Do not attempt to run this software on any hard drives other than what is listed above.
    One WD representant said that this information is outdated, and that it would be changed.... 10 months ago: http://community.wdc.com/t5/Desktop/...ght/true#M1113
    So, if something goes wrong when I'm trying to fix their drives with their tools, I might have problems with the warranty... even thought it is reported working by lots of people, even by an WD representant.
  24. #24
    Sep 2010
    US, MI
    System incompatible lol...
    Linux or windows, it's gonna idle every so many secs regardless of what you got your software setup to do.
    The only way to fix it is to mod the firmware.
    It's funny I think, they must of known that it will kill performance.
    In the back of there mind they must of thought about reliability, but figured it would be ok anyways.
    Well I guess not, if these drives are dropping dead left and right because the head parking is to aggressive...
    I mean come on, the idle timer should be set to something like 5mins.
    Any lower just doesn't make any sense to me unless it's use for storage only.
    Anyways I'm forced to buy the blacks.
    Otherwise I would buy the greens again, only if they were modable.
    I like the idea of not really needing a fan to cool them, even though I use one anyways, it doesn't need to be anything special, a 0.1x amp fan will do.
    And they are pretty quiet, plus they use maybe 5watts of power, I forget, but it's around 2-3x lower then a conventional drive.
    Edit:
    WD10EADS are the model's I'm using I think, and yeah they are definitely affected, originally they were anyways.
    I ran wdidle3 long ago before I raided them, 2nd day I had them after I verified them ok the day before.
    I did alot of research before I bought the 2 drives...
    Anyways I've got v1.00.
    I think there was one more ver slightly above that but it was buggy and didn't work.
    The one they are talking about now is probably a completely new ver or maybe that one ver that didn't work for my drives.
    They should put out the correct ver for both wdidle3 and wdtler...
    Let the user do decide what they are gonna do...
    Quote Originally Posted by Manabu View Post
    I wouldn't worry so much.
    Just make sure the system you do this is on is 100% stable, and that you don't use raid mode to run these util's on.
    I set the value, then reset and checked the value to ensure it was actually set.
    Then I took the drive out and did the other the same way.
    After modding I raided the 2 drives and partitioned them.
    Been all good since.
    The smart data power on off count or whatever it was is no longer counting up like mad.
    Oh, and since these are sata drives, better make sure you use good cables before you attempt.
    Hate to have the cable go out in the middle of a thing like this.
  25. #25
    Feb 2007
    this is why i stop using their green drives. one flat out died on me in less than a year. the other one i got to replace it still works but makes a ticking noise almost constantly. lets just say i dont use that drive anymore
