Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: Cm-haf-xl
    Aug 2010
    netherlands
    Cm-haf-xl
    Hi there, greetings from the Netherlands
    What better place to start my new build, with a very nice case "The Haf X"
    Called the CM-HAF-XL
    I started this build begin december, and i am half way now, so i wanna share it with you guys.
    But before i start, i wanna thank some sponsors
    Mister Freddy from Highflow.nl
    And
    Mister Ruud from Coolermaster.nl
    Want to thank you for the trust and products
    Coolermaster has send me a very nice case, and a beautiful psu
    The HAF X and a 1200W Silent pro gold
    The hardware that i'm gonna use:
    - HAF X
    - PSU Coolermaster Silent pro gold 1200W
    - EVGA Classified E759
    - I7 930
    - 6x 2GB Corsair DDR3
    - Tripple GTX470
    - Aqua-computer Aquaero
    - Sony Optairc AD-7670
    - 2 x SSD Intel 160GB
    - 2 x 1 TB HDD
    De components are gonna be cooled wih EK blocks and:
    - 2 x Swiftech MCP 355
    - 1 x EK Radiator XT360 (maybe 2 x instead. the 240)
    - 1 x EK Radiator 240
    - Tygon slang clear. 1/2
    - 3 x EK GTX470 waterblock acetal/ nickel
    - Bitspower Fittingen Black
    - EK-FB EVGA X58 Classified
    - EK Supreme CPU block Black
    - 3 x EK Link Geforce
    - EK Bridge serial tripple
    - 2 x Aqua-computer cover MCP355
    - 3 x EK Backplate GTX470 Black
    for the reservoirs i have more options, but still hasn't decided
    - 2 x EK-Multioption RES X2 - 150 Advanced (Round 60mm)
    - 1 x EK-Multioption RES X2 - 250 Advanced (Round 60mm)
    - 2 x EK-Multioption 250 (Round 50mm)
    - 2 x EK-Spin Reservoir- plexi
    some pics, before i take the case apart
    the package from Coolermaster
    The big one from Coolermaster
    Inside beautiful black
    Enough space for the components
    Sata dock, always easy
    A lot of space for the reservoirs or radiators
    What i really like for modding is the air duct for the gpu's
    For so far the case. Also there was a nice psu, the 1200W silent pro
    Enough cables for my tripple gtx setup
    Gonna be a lot of sleeving
    Next step is to take the case apart, and fit some components
    The Haf XL, sad to see him like this.
    Yesterday i had a little brainstorming session, I will reveal you some ideas
    A 360 rad in this case is almost impossible, except for the top, but for the top I've got other ideas,
    now it,s going to be 2 x 240 rads
    Both sides 2 x 120 mm fan
    For the top a have some nice ideas
    Here comes 2 x EK spinbays
    I'll have to do some grinding for the spin Bays
    Gonna make 2 x square / octagon 3 mm plex fan bays, which will be the lid of the spin Bays
    Like this,
    In the cover is coming a aquaero, and in the flat side i,am gonna make a slot for a slimline DVD-RW
    i Am not sure where and if i place the airduct voor the gpu,s
    The last idea for now., Gonna make a hood from the front to the back of the case over the psu, on top of this 2 x MCP 355 pump, all in sight
    Under the hood i gonna place my hdd, s
    Hello again, new update
    Cut 2 holes for the 240 rad
    removed some plastic
    Cut a piece of uv-green plex
    Drilled the holes for the screws from the spinbay
    And installed the spinbay, only need to order 2 black impellers
    Yes, it fits
    One to go
    The color for this mod is black/green
    some Umzug von der Familie MDPC
    Sata and small green sleeve
    Black for the sata and psu
    The total family package
    heatshrink
    Heatshrink for the sata en small
    Black rivets, ad to drill a lot when i took the case apart
    Mdpc M3 screws
    Some special parts from mdpc, countersunk Black-Oxide screws
    And snap-caps, nice for over some ugly screws
    The second spinbay
    Put it all togheter
    Did some small grinding, to make it fit
    Sawn some little pieces of uv-green acryl.
    Gonna be sanded and polished
    The idea is to put smd led strips behind them
    pics in the dark
    nice effect
    Dec 2010
    Brisbane, Australia
    wow, very nice mate. kinda did something similar to the top, but a 260 rad and a res. looking forward to seeing whats possible with the dvd bays.
    Dec 2008
    Jerusalem, Israel
    so far so good,
    keep up the good work!
    [SIGPIC][/SIGPIC]
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
    Aug 2010
    netherlands
    Update !!!
    Received some nice stuff from Highflow.nl and EK
    To begin with tje black EK impellers
    Always nice to receive a package
    Pump number 2
    The third nickel block
    with three times a nice black backplate
    put everything togheter with a tripple bridge
    and three Link force,s
    An extra 240 Radiator
    And 4 beautiful Nanoxia 120mm Fans, uv green, same color as the green acryl i used
    +1 140mm fan
    To control the fans and pumps i'm gonna use a Aquaero VF display.
    And some small stuff to try out some nice ideas
    2 nice fillports from Danger den
    And 2 shiny nickel tops for the Mcp-355 pumps
    Put them together
    Think it,s gonna be perfect in this case
    And the first Bitspower fittingen
    Impellers already placed, looks better like this. Fillports coming up
    I have made the midplate from a piece of mesh panel, gonna be painted black and some nice ideas in it
    Made the radiator bay
    The first thought was to put the in/outputs of the rads turned to the inside, like this
    But i want the pumps in one line
    That's why i,ve turned one radiator
    Putting al together
    I love the color of the fans, really nice
    Other side
    Painted the bay and fitting it together
    flip side
    Made the fillports into the spinbays
    And in received a package from Coolermaster, some beautiful flatcabels. The idea is to
    sleef the psu cables and to use flatcabels for the gpu.
    Coolermaster thnx!!!
    bought myself a new cpu block
    EK-Supreme HF - Acetal+Nickel
    Replaced the red plexi cover for the black acetal for the classified
    EK-FB EVGA X58 Classified - Acetal+Nickel
    Looking good i think
    A new set of rams, 6x 2 GB
    placed on the board
    Also looks nice. And i bought my third GTX 470, Nickel block placed on it
    And the backplate.
    Conected all together with the EK tripple bridge
    I'm in love, but it,s real heavy now
    Backplates really nice like this
    I think i need to make something for the weight, but that,s for later
    Have played with the Aquaero, and was real happy with the color of the display, with the green filter it was even better
    Perfect, just the right color for this build
    Started with the top, and placed the display in it
    Little test
    Had sawn a small plate of acryl, need to polish it, but looks good for now
    Again little test
    And again, the green filter placed back
    The place where the usb and other stuff was is now for the buttons for the aquaero and some other nice ideas i have. But this is for the weekend, so.... be continued
    Greetings to you all.
    Dec 2008
    Jerusalem, Israel
    very nice update and parts you got there - keep it up - again!
    [SIGPIC][/SIGPIC]
    Feb 2010
    Wisconsin
    Oh baby this is sweet! The first post was somewhat nice, but this new update made my jaw drop!
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Aug 2010
    netherlands
    Thnx, this is my first build on XtremeSystems, hope you like it
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    awesome buddy, first hafx ive seen modded like tis, subb'd
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Aug 2010
    netherlands
    And another Update
    For the aquaero buttons the idea is to place them vertical and place two extra buttons for the power and reset
    In the past i had destroyd an aquaero, what is now very handy for spare parts, sawn the two buttons out of the old one. For the power and reset
    Different sizes from the old and new aquaero
    drilled and sawn a piece of acryl
    And placed the two extra buttons
    the pushbuttons at the same height
    And we have a " X "
    Removed the frontcover
    Sawn a piece out of the case
    Horizontal mounting is not an option, because the aquaero is to long and i want the " X " in the middle, thats why vertical
    Fits nicely between the 2 radiators
    Gonna light up the buttons with green uv acryl
    Covered this with black acryl. I need to make this black acryl over because the holes aren't that good, but just for the idea
    And light it up
    Tried some things today, and i removed the black acryl. Instead of this i have placed a sticker and cut out the stripes
    Better like this
    And some shots by night
    Have replaced al the rivets and screws, before the hardware is placed
    have made a solid tube between the reservoir and the Ek bridge
    From Reservoir to....
    Ek Bridge.
    Connected
    Placed the green nanoxia-140mm
    Back of the case is not finished yet
    The Msi bracket is gonna be replaced
    From the gpu to the pump is gonna be a solid tube also, and the same for the pump to the radiator
    The right shape
    The curve is for to get the right angel for the tube but also for the flatcables of the gpu,s
    Just like this, the tube between the pump and gpu needs to be longer, but just to give you an idea
    And the last thing i do this weekend, pimping the fans. Nanoxia sticker has to go
    Made my own stickers
    The famous snap-caps
    All fans are finished
    I hope i,am not going to fast. Like i said in the beginning, started this build begin december
    so i have about three more major updates, before I am on today,s level.
    If you guys like it, i can place the three right away, or place them in a later stadium.
    Grtz.
    barfastic
    Guest
    amazing.... i lvoe your dieas, and craftmanship!! Good job on everything!
    Aug 2010
    netherlands
    Update-------------------Sleeving, sleeving and more sleeving
    This week it's sleeving time. The Silent pro is an easy psu to sleeve i think. Lots of space
    The original flatcables had a bridge in it, really ugly so that has to change
    sleeving meets flatcable.
    2 x modulair pci-e
    And 2 x non-modulair
    Placed the flatcables but need to straigt it, just for the idea
    Nice green sleeve, same color as my Nanoxia fans
    Green is finished, now it's time for the black sleeve
    Ready to plug in
    Had to make the cpu cables longer
    These wil be black
    split the green and black as much as possible
    And finished
    Placed in de Haf.
    Green color of the sleeves are really the same as the fans
    Cpu cable black sleeved 4 x 4 pins
    Nice curve in it
    And a total shot with flatcables and sleeved cables. Need to straigten al the cables
    Also made a mesh cover for the front panel out of a ceiling plate. This ceiling plate has a filter glued on it, so perfect for this purposes
    The ceiling plate
    Filter on the inside
    Beautiful mesh i think
    After some sawing and bending
    And the filter on the inside
    Placed a light on the inside to show you the filter
    And this little project is finished
    Greetings and till the next update
    Xtreme Guru
    Jun 2010
    Nice sleeving done mate oorah , How hard was it to sleeve the PSU? I noticed when opening mine the same way you did i can never get the dam thing shut lol because the sleeving combines are quite big..
    barfastic
    Guest
    Amazing work... and the colour of your sleeving is amazing!
    Aug 2010
    netherlands
    Quote Originally Posted by Johnny87au View Post
    Thnx mate,
    I must admite, this psu was the easiest one i have ever done
    the opening is larger then the one from Corsair or a Be quiet
    the secret is to stack all the cables one by one and push it
    leave no space between them
    Aug 2010
    netherlands
    Update-------------------Recycling
    A friend of mine has given my a broken Logitech G15. The idea was to use it for the lcd screen, but when i dismantel it i saw the small plex for the illuminated board
    Idea !!!
    Used a bigger piece for the cover
    Sawn a piece out of it and drilled 3 holes for the bitspower fillport
    The three Bitspower fillport
    Swan the acryl from the G15
    testing with a green ledstrip
    Looks like the matrix
    Put a black vinyl sticker over the transparent acryl and cut small pieces out of it
    Place it in the haf
    Shot in the dark
    3 fittings installed
    Everything is gonna be replaced for black fittings and solid tubes
    And a little Sponsor Update
    Today a nice updat for the sponsors (and you offcourse)
    First i wanna thank the people from Letterop Ijmuiden, who had made the perfect sticker.
    Letterop Reclame uw specialist in de IJmond!
    And i wanna thank mr. D hard, he also made this update possible
    Logo number 1
    HighFlow Computer Cooling Shop - Uw shop voor PC waterkoeling, luchtkoeling, modding, behuizingen en gaming!
    Logo number 2
    Cooler Master
    The sticker
    Sawn a piece of uv-green acryl, and made a slot for the slimline dvd-rw
    Very carfully placed the sticker and cut the sides
    To have a nice illuminated cover, Mr.D. Hard has given my 2 nice glowpads
    Color is blue, thats why i had placed the uv-green
    You can cut the glowpads any shape you want
    placed on the back of the cover
    Illuminates Highflow
    Illuminates Coolermaster
    And illuminates the hole cover, nice effect i think
    Placed back in de Haf
    The front almost finished
    In the dark............
    Grtzzz.
    I am Xtreme
    Dec 2008
    France
    Some very interesting ideas here... I look forward to seeing the final result. Keep it up!
    Donate to XS forums
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Best HAF mod I've seen....good work so far
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
  18. #18
    Xtreme Guru
    Jun 2010
    wow brow those pads look rad, Where exactly did you get those? I've seen similar AC ryan's one but dont look as good as these!!
  19. #19
    Aug 2010
    netherlands
    Did have this question a lot lately So i've did some research to find a shop.
    But there,s not much info about these Recom gloplex pads.
    I've send an email to Recom.nl and they told me that they can deliver these pads. So if you want the gloplex pads, you can contact Recom.nl
    And a new update....
    Update: Speed modding
    Did some nice things these days. Finally received my Acryl and aluminum panels
    1mm black aluminum
    and the panels i was waiting for Uv green 3mm
    And 5 mm
    A little idea i had, drawing a mold
    Then cut out some cardboard
    Shapping the cpu
    And the Corsair memory
    The gpu's
    and the mold is finished
    And now the nice part, when i screw this up, i have a big problem, this came out of a hole panel, so really cant screw this up. But with same patience it came out very well, i think
    Cut out some openings for the cpu cables and motherboard cables
    And the cover is finished
    there,s gonna be black stickers on it, and cutting these for a green outline
    Some places have bubbles, so need to rub them out
    And the I/O blocks (or how do you call them?) also black
    Smd strips where ordered today, and iam very curious how this looks
    Ordered green smd strips, smd Uv strips and some other led strips to test
    The whole thing...
    By the way, there's gonna be an airflow behind the acryl and the motherboard, so dont wurry
    grtzzz.
  20. #20
    Mar 2009
    Holy
  21. #21
    Feb 2010
    Wisconsin
    Freaking perfection in a case you've got there. If anything, maybe darker acrylic?
  22. #22
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    awesome idea for covering the mobo
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
  23. #23
    Oct 2010
    Canada
    Simply awesome.
    Personally though, I think you should go with the black bitspower rotary fittings instead of the sliver, the mix just doesn't clash well in my eyes.
    Other than that bravo
  24. #24
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by SaFrOuT View Post
    Agreed, the build's getting better each day!!
    Donate to XS forums
  25. #25
    Xtreme Guru
    Jun 2010
    holy , looks amazing man!! For a seconf i thought you were gonna use the cardboard plate hahaha
