Page 31 of 90 FirstFirst ... 21282930313233344181 ... LastLast
Results 751 to 775 of 2226
Thread: i5-2500K/2600K batch number and o/c results
  1. #751
    May 2006
    Philippines
    Quote Originally Posted by jcniest5 View Post
    Shows how unlucky I am. I've had the chance to grab that B243 and a B208, chose the latter, and I'm not sure, it's either the chip sucks at OCing or my board sucks at OCing. Both of my chips max out at 5Ghz with 1.50V. Could just be the board, really don't know the real answer at this time since I only have one board to test the two CPUs.
    Nice all we need now is one that hits 60x!
  2. #752
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by Dumo View Post
    This L042B243 XXXXA1174 is a monster when freezed. My single stage calm and cool. Too bad Biostar board somehow stuck @ bclk 99.7
    58X - 1.57Vcore bios - LLC disabled
    You're the first person I see with 58x multi! Awesome batch, everyone get this one!
    Donate to XS forums
  3. #753
    Aug 2008
    Atlanta
    Jcniest5, heres..
    L042B208 53X(2 pcs)
    L042B291 52X
    L045A998 52X (2 pcs)
    L037B224 52X
    L042B243 53X (1 can run 58X)
    LO50A853 53X
    Now I believed that its the cpu, most walled @ 53X and a few out there that can go >54X easy. Batch # not a factor. For me is 1 out of 9 2600Ks
    Problem is...no good mobo on sale
    I agree ... but still congrats on finding that special chip! and your other sample with the same batch walls at 53x?... Batch hunting isn't easy. I've tested six 2600K to date and would like to find one that will do 55x (or better).
    Ryzen 9 on the test bench... Sometimes older generation/tech as well.
  4. #754
    Mar 2006
    Sydney , Australia
    What does it do without freezing and where can I get one? I havent seen one very good one yet here in Aus, on our forum our best cpu does 52x....
    Has anyone tried L051A954 and L051A964 yet?
    Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
    Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
    PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
    AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
  5. #755
    May 2007
    Calgary, Alberta. Canada
    Looking at HWbot, batch L042B074 has 7 entries with the lowest clock being 5188. Bet I won't find one of those at my local store today.
    Rig 1
    CPU: i7-990X. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS Rampage III Formula. RAM: 12GB Mushkin DDR3 1600 CL7. GFX: EVGA GTX 580's x 2. SLI. HDD's: 1.5 TB Seagate, 1TB WD Sata III. Monitor: Samsung 25". PSU: Corsair AX 1200W. Win 7 64 Bit
    Rig 2.
    CPU: i7-2600K. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS P8P67 Deluxe. RAM: 4 GB GSkill Ripjaws X DDR3 1600 CL6. GFX: EVGA GTX 580. HDD: 1TB WD Sata III. Monitor: Samsung 23". PSU: Corsair AX 1200W. Win 7 64 Bit.
  6. #756
    Nov 2005
    Germany
    http://img201.imageshack.us/img201/8...enshot011t.png
    really nice CPU
    this is actually the max clock of my CPU (boot from bios)
    1.625v 75% LLC in Bios (idle 1.632 / load ~1.61v)
  7. #757
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    x58 is a really good one
    Maybe these CPUs are unlocked after all
    ASUS P8P67 Deluxe (BIOS 1305)
    2600K @4.5GHz 1.27v , 1 hour Prime
    Silver Arrow , push/pull
    2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
    GTX560 GB OC @910/2400 0.987v
    Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
    CM Storm Scout + Corsair HX 1000W
    EVGA SR-2 , A50
    2 x Xeon X5650 @3.86GHz(203x19) 1.20v
    Megahalem + Silver Arrow , push/pull
    3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
    XFX GTX 295 @650/1200/1402
    Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
    SilverStone Fortress FT01 + Corsair AX 1200W
  8. #758
    Mar 2006
    Sydney , Australia
    Quote Originally Posted by crossg View Post
    Where does hwbot show the batches?
  9. #759
    Xtremely Addicted
    Dec 2004
    NL
  10. #760
    Dec 2003
    L040b208
    Hey guys, I have an L040B208 that hasn't been opened yet and I p[lan to build the system this weekend. I can still exchange it at a local TigerDirect store, but I'm not sure what other batches they have in stock.
    I'm a bit nervous that it's apparantly one of the older first shipping batches, but the results on this thread seem pretty good, although the volts needed are perhaps a bit highjer than some of the newer batches.
    Would you stick with this L040B208 or try to find a newer batch? If so, which one(s) should I look for?
    Intel i7-2600K (L040B208)
    Asus P8P67 Deluxe
    BIOS 1029 (all stock settings at the moment)
    Noctua NH-D14
    8 GB GSkill RipJaws (F3-12800CL8D)
    Crucial 128GB C300 SSD
    ATI X1900XT
    Antec TruePower II 550W
  11. #761
    May 2006
    Philippines
    Quote Originally Posted by rpr View Post
    Stick with it mate! I have a L040B307 and that clocks like crazy up to a 55x now! Even if you get a newer batch it isnt certain to clock well luck of the draw!
  12. #762
    Feb 2008
    My core 1 temperature is way lower than the rest, or better put, the rest are higher than core 1. I already tried a little more thermal paste, but it doesn't help. Any ideas?
    Measured with RealTemp, running IntelBurnTest 20x max.
    i5 2500K | Noctua NH-D14 | ASUS P8P67 PRO 1204 | G.Skill Pi 1600 CL6 4GB
    OCZ Agility 60GB | WD5000AAKX | HD502HJ | NEC 7260S | G5 (2007) | Lenovo L220X
    Gigabyte GTX460 1GB 840/2200 | ASUS Xonar D2X | Sennheiser HD 555 | Corsair 600T | Corsair TX850 V2
  13. #763
    Xtreme Mentor
    Nov 2004
    Elma, NY
    Quote Originally Posted by Gr1mR34p3r View Post
    My core 1 temperature is way lower than the rest, I already tried a little more thermal paste, but it doesn't help. Any ideas?
    I always see the same thing till I lap it. I lap all my CPUs. More than likely the IHS isn't flat. Thats the only way to fix something like that.
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
  14. #764
    Banned
    Sep 2010
    Demotte,IN
    B208 is considered a very good batch ,you won't know till you try
  15. #765
    Jan 2004
    North America
    I too have a L040B208 and mine can do 56 multi. Do not trade that one with out testing it as you might be lucky.
  16. #766
    Oct 2006
    new jersey
    Quote Originally Posted by cowie View Post
    I went thuogh all pages i may have missed it but anyone see 044A892 before?
    1 week to play using this batch was ok
    x54 np up to 101 bkl,x55 boot not 3d stable thuogh
    1.55 real ok 54x 5400 was pushing 1.60 here but it died soon after
    Attached Images Attached Images
    _________________
  17. #767
    Jan 2004
    North America
    That is a killer 260 score right there,nice work.
  18. #768
    Jul 2007
    Sofia, Bulgaria
    A mate of mine has this BEAST- batch L041C124
    24/7 Asrock P67 Extreme4|2500K @ 4600 @ 1.38v|2x2GB A-data value|XpertVision 8500GT 600/450|WD 6400AAKS|CM 690 + 3 x 140mm + 2 x 120mm|Zalman CPNS-10X Performa|Chieftec 750-14C|Zalman MFC1 Plus
  19. #769
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Quote Originally Posted by overcrash View Post
    http://prikachi.com/images/56/2953056l.jpg[/IMG]
    Good one.
    I've been looking for these rare C-batches. This is the second one I've seen, and both has been doing really good.
    Just after the resale I said: C-batch seams the way to go in tis round, and now this beast proves it.
    EVGA SR-2 , A50
  20. #770
    May 2004
    Okay, so I went and got the L042B243 and I'm testing it now. So far it's doing worse than my first two CPUs. Can't even pass 5Ghz with 1.50V (LLC Overvoltage Enabled). Is my board the culprit?
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
  21. #771
    Aug 2008
    Atlanta
    The problem with SB batch hunting is there can be a big difference between chips within the same batch. I had three samples from the same batch and there was an easy 300Mhz difference amongst them with the same BIOS settings. That sample probably has a higher VID.
  22. #772
    May 2007
    Wanted to see if my chip (a bit of an odd batch L038A660) would boot to 53x and 54x. 53x yes, 54X no. Requires more than 1.55vcore and bios says cpu overvolt (F1) and wont let me go any higher. In windows it'll go to 54. Really just to see if it would or wouldn't boot. Looks pretty average to the newer chips. I can bench at 5200 with this so I'm happy with that.
    Rig 1
    Rig 2.
  23. #773
    Jan 2004
    North America
    Very nice vcore. Looks like C batch has some winners also. Nice work.
  24. #774
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    Batch is L049A796. Haven't quite pushed to 5GHz yet but this chip is starting to look good.. 4.7GHz @ 1.3v
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
  25. #775
    Jan 2004
    North America
    That could be a killa chip.
