Page 65 of 119 FirstFirst ... 15556263646566676875115 ... LastLast
Results 1,601 to 1,625 of 2964
Thread: ***Official***Z68X/P67A-UD7 Club/Discussion/Info**
  1. #1601
    Aug 2004
    Germany
    Since last Friday I'm using P67A-UD7-B3, too.
    I found a few things that I don't "lik". First was the fact that only one fan can be controlled (BIOS F3c JZ). And vcore (fluctuation) even with llc 1 is horrible in comparison with my former used ASRock Fatal1ty.
    But I also had an issue with switching frequency. I set my 2500k with multiplier 48 and vcore 1.35 volts. Under load frequency went down to 4700 mhz constantly. I tried different settings in bios but everytime I got 4700 under load. Then I just upped vcore to 1.40 and multiplier to 50 and frequency stayed at 5 ghz all the time.
    Does anybody has experienced the same issue?
  2. #1602
    Dec 2008
    MALAYSIA
    2197MHz 8-9-8-20
    2200MHz 8-9-8-24
    2240MHz 8-9-8-20
    SUCCESSFUL TRADE LIST RM600k+
    ^^ Malaysia's Overclocking Enthusiast Community Website ^^
    Find us at Facebook HERE
    XS Successful Trades:
    G.Skill RipjawsZ 2400C9 4X4GB - sold to easegantini | G.Skill RipjawsX 2133C8 2X2GB - bought from Dumo | 2600K 57X - bought from newhit | 3770K 6750 - bought from Viss | 3770K 6750 - sold to Sniper | 3770K IMC 2800+ - bought from Dumo | G.Skill Pi 2200C7 - bought from websmile | 3770K IMC 2933+ - bought from Viss | DomGT 2kC7 3X2GB - sold to _AntLionBR_ | G.Skill Pi 2133C8 - bought from websmile | DomP 2800C11 - bought from Alex-Ro | Pi 2000C7 - bought from websmile | GTX4 + KVR 1333C9 - bought from TaPaKaH
  3. #1603
    Oct 2007
    Quote Originally Posted by jacek View Post
    I join the club.
    nice setup
    Being Tweaked
    ASUS Maximus V Forumla Bios 1408
    Intel Ivy Bridge 3770k UNLIDDED
    4.8 ghz EK Supreme HF Block 1.38v
    Dominator Platinum 2666MHz 11-13-13-35
    EVGA Titan eK bLOCK
    Corsiar AX850W
    Samsung 840 Pro 256GB C:/ OS
    Samsung 840 Pro 512GB D:/ Game:
    Western Digital Black WD4001FAEX 4TB 7200 RPM 64MB E:/ Data
    Western Digital Black WD4001FAEX 4TB 7200 RPM 64MB F:/ Data
    X-Fi Titanium Fatal1ty
    Windows 7 PRO 64bit SP1
  4. #1604
    Oct 2007
    Ok got my Gigabyte P67A-UD7 - B3 . . running F2 bios
    Board is running perfect with all my tweaked settings exactly the same, I did lots of linx and 3dmark testing testing she's good , hard drive performance still excellent also
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  5. #1605
    Jul 2008
    Prestonsburg, KY
    UD7-B3 on the way
  6. #1606
    Sep 2004
    West Covina. CA
    Quote Originally Posted by the_real_7 View Post
    So why is owikh84's board running his cpu worse than his B2 board?
  7. #1607
    Oct 2007
    Quote Originally Posted by Falkentyne View Post
    I would tell you i have no idea why maybe his bios are reacting different . . I did all my settings that i know in my head by heart , and board ran exactly the same without a issues on two different sets ram , actually ran better cause boot issues have disappeared ,
    Two thumbs up from me on the B3 running excellent
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  8. #1608
    Mar 2008
    Wherever I may roam
    Just received mine yesterday.....if anything B3 board seems smoother, less reboots,etc. Still can't find a "nice proc" but with the ones I do have slightly lower volts to run the same benches.
    ____________________________________________
    More & more very expensive, quickly obsolete parts!!
  9. #1609
    Oct 2007
    Quote Originally Posted by Expat GriZ View Post
    same for me I just received my yesterday from newegg which was fast and next day shipping ,I agree the B3 seems so much smoother easy to play with now that when you switch setting they hold and you don't get boot loops , as for processor I'm in same boat , to hit 5.0 Im running 1.500 vcore to hold a load of 1.463 vcore , grrrrrrrr
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  10. #1610
    Mar 2008
    Wherever I may roam
    yup...the eternal search for a "nice chip"......9 and counting....max is 54 multi....need 56 ....57 would be great because for the life of me....raising bclk has me stumped........
  11. #1611
    I am Xtreme
    Dec 2004
    France
    Quote Originally Posted by MusicIsMyLife View Post
    I don't have the same issue, but i should tell you that OCing GB P67 boards is much different than OCing asrock/asus boards. You should disable turbo, as well as ratio change in OS. Disable power saving features, and just set a ratio for the CPU. IDK how much voltage fluctuation is b/c i haven't received my B3 yet, but I thought they drastically improved LLC on the B3 boards, at least they did for the UD4. I don't thin they have yet for the UD7.
  12. #1612
    Aug 2004
    Germany
    Quote Originally Posted by sin0822 View Post
    Yes, of course Gigabyte is different than ASRock. But that's not the issue.
    I already did that (UD7 is my 3rd p67-board ). That didn't help at all. The only thing that helped was upping vcore and multiplier. Everything else remained the same - and it worked.
    With P67 Fatal1ty I had 5 LLC-options. I choosed Level II where my vcore dropped about 0.01 volts under load. I set 1.415 in bios and got 1.416 idle and 1.408 load. That worked perfectly.
    With UD7 when I set 1.425 volt in bios I got 1.428 volt idle (LLC Level I) and 1.392 load. If I set LLC Level II (1.425 volt in bios is still the same) I get 1.440 idle and 1.452 load.
    For me this is a bad situation. Either vcore drops nearly 0.04 volts with LLC 1 or it raises more than 0.01 volt with LLC 2. Gigabyte can do better for sure.
    No offense, I like UD7. But there are a few quirks that shouldn't be on such a premium priced board.
    I already discussed my findings with my contact over at Gigabyte and he forwarded it to the hq. Maybe and hopefully there is something that can be done...
  13. #1613
    Sep 2004
    West Covina. CA
    You need to check the vcore with a DMM before complaining that LLC1 isn't working like you want it to. Several people who checked the UD4, UD5 and UD7 found that the boards overvolt from the sensor readings. And the UD4 overvolts as much as 0.03v; Bullet took a reading from his B3 UD4. If the UD7 does the same thing, then your vcore is almost right where it needs to be.
  14. #1614
    Xtreme Mentor
    Dec 2007
    My P67A UD7 B2 is dead, waiting for rma reply from newegg. P67A UD5 on the way, ordered today.
  15. #1615
    Xtreme Memory Hoarder
    Mar 2010
    Quote Originally Posted by OC Nub View Post
    wondering where you were at buddy hadn't seen you post in a while
    I am going to order a UD7 B3 this friday, can't wait to test it.
  16. #1616
    Oct 2007
    Hey Oc Nub what happened to the board ? call newegg are gigabyte they'll get you back up in a ud7 quick
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  17. #1617
    Jul 2008
    Prestonsburg, KY
    Anybody ever feel like a retard for not just paying the extra $13 for 2-day shipping? I ordered my 2600k + UD7 this morning and I am grinding at the bit to get it. So any of you guys have any luck with hypers at 2133 strap? I got a set of mushkin redlines I am hoping will play nice with the board.
  18. #1618
    Oct 2006
    new jersey
    argh! my b2 was reboot free the b3 is the one that is reboot happy other then that they are the same,.
    _________________
  19. #1619
    Sep 2002
    in front of PC
    F8f black screen
    Hi to all,
    I've posted a few times and i always come to "Xtreme" first for all the best info.
    Well, I have a B2 board and have just gone from F8x to F8f and now I cannot boot past the bios screen into windows 7 (64). It always stops with a black screen after "Loading operating system" Tried a full OS installation on another drive with same probs. Tried default bios and optimized as well, no go. Also tried Windows @BIOS to no avail.
    If I go back to F8x everything is fine. I want to go to F8f because of the greater stability (reboots and C1's etc). Everybody agrees that F8f is the way to go but not for me.
    It's a real pain for me and i am totally baffled. I don't want to stay at F8x if F8f is the better bios.
    Help needed please
    PS
    Not sure If I'm in for a B3 board (I have registered) because there are usually too many hoops to jump through here (UK) so I need an answer if I have to stay with the B2 board
    Sig always changing .
  20. #1620
    Oct 2007
    Quote Originally Posted by newhit View Post
    Hi to all,
    Help needed please
    PS
    no worries friend your definitely on the b2 board , are the bios your using would not be working . Ok i had the same problem F8x to F8f at the loading screen , try go to bios and change your achi setting to ide and see if it boots on F8f , if it does you'll be without achi which brings a bit more hhd performance
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  21. #1621
    May 2008
    Quote Originally Posted by chuchnit View Post
    No luck here with Hyper Redlines, on Ud7 or UD4, even with various other SPD's.
    Let me know how you get along, but I suspect it's not going to go smoothly at 2133
  22. #1622
    I am Xtreme
    Dec 2004
    France
    yea it seems like teh best bet for cheap ddr3 2133 is PCS
    Id pay 13 bucks for faster shipping sure, if i am already paying $500 why not.
  23. #1623
    Sep 2002
    in front of PC
    Thanx for your help.
    Do I need to re-install Win7 before it will work or just select IDE in the bios and go for it............. or is life with F8x just as stable anyway?
    If it is I might stay with F8x.
  24. #1624
    Oct 2007
    hey no problem
    You would have to just select ide in bios but once you go there it'd hard to go back to achi without reloading or doing a registry hack . . . Achi is faster for ssd and faster new gen hdd
    if your not a big tweaker stay with F8x as it is very stable . . . .except for some reboot loops on setting chnages
    Good luck
    Being Tweaked
    EVGA Titan eK bLOCK
    Corsiar AX850W
  25. #1625
    Sep 2002
    in front of PC
    hey no problem
    Good luck
    Many thanx for your info. I'm good to go now.
    Whether I stay with F8x or go for F8f is not the big mystery it was. I can go with either.The reboot loops with certain settings I can live with.
    Maybe Gigabyte UK will make this problem irrelevant if they come through with my B3 version.
    Thanx again.
