Hey stasio,New beta BIOS F7d is out.
Saw this is TT forums, any changelog? TIA...
Just received from Taiwan and now they are close,maybe 2moro.
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
Few things that I have come across the board that is troublesome
As soon as I go over 5 Ghz I sometimes have a failed OC, not always...normally when I reboot from Windows, the board then loads F3 bios and I have to reflash to the later bios, very annoying.
If I use level 1 LLC the board undervolts by .05v, if I use LLC level 2 I get an overvolt of 0.04v?
Any comments?
Lastly how do I swap from one bios chip to another in the Bios screen?
Asus P8P67 Pro BIOS 1253
i7-2600k @ 4.5 @ 1.3V
Thermalright Venomous-X w/GT @ 1450
8 GB (2 x 4) G.Skill Ripjaws DDR3-1600 9-9-9-24
Gigabyte GTX 480
Corsair 750HX
I love this board !
Here is my max overclock (I personally don't want to go higher) and a Super PI 32M
CPU: i7-2600K||Sabertooth Z77|DDR3 16GB CL9 1866Mhz|GTX 580|SSD: Corsair Force 180GB|Blog: Jack-Brennan.com|Twitter: JBTechSec
I still see it? http://forums.tweaktown.com/gigabyte...test-bios.html
it was on this afternoon but not there now, heres whats there
GA-P67A - Previous BetaBIOS
GA-P67A-UD7 - F7a
GA-P67A-UD5 - F6a
GA-P67A-UD4 - F7b
GA-P67A-UD3 - F6a
GA-P67A-UD3P - F6a
GA-P67A-UD3R - F7a
so it looks like its been on and pulled off again
, a lot of people are having trouble getting it to boot with the higher multi's regardless of good cooling and extra volts, maybe its the cpu's i hope not i hope its a bios thing, also have you manually set the bclock as mine is at 99.8 where as yours is the correct 100 , nice going
Yes, i set it to 1002 in the BIOS. I got sick of people saying "Oh thats not 5Ghz that's 4989Mhz" ect.....
I also manually set the PLL voltage instead of using the Auto PLL overclock feature.
But yes i've been extremely happy with the F7A bios and my overclocking has gone extremely well. I'm sure the chip is capable of more, maybe 5.6 if i really push it, but as a personal goal, 5.5Ghz is really enough. I'll leave 5.6/5.7+ to the guys who really know what they are doing and have better cooling than me.
**I also heard that the F7B bios had problems with AHCI and was removed because of that.
Up & running guys with latest bios f7d.
Does anyone notice the delay on welcome screen loading into win7 U64?
My rampage III was fast loading win7.
One good thing the raid controller is faster, 750 W & 800 R maxing out contoller using 3 ssd's Raid 0.
New System Specs
Asus Ramgage IV Black Edition
CoolerMaster Striker Case Black
SeaSonic 1250 XSeries
Intel i7- 4960X (Running 4.5GHz @ 1.375v LLC 25%
Dominator 2133 9-11-11-31 CR1 Running 8 x 4GB / 32GB
3 x Red 2TB Running Raid 5
2 x Samsung Pro 250GB Running Raid 0
2 x Evga 980 Sli
CPU Water Cooling & Video Card Cooling Dual Loops EK
Dell U3415W 34"
Yes, before with the SSD there was no welcome screen, went by so fast didnt notice it. Now it seems to take a while to get to desktop, on any of the bios's I have tried
And the "no turbo" coming out of S3 is still there...
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
New System Specs
2 x Evga 980 Sli
Dell U3415W 34"
I will try F7d if it solve slow move in M.I.T. BIOS section
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
anyone ?
almost every time i got bsod on Hyper pi32 or ibt it's will roll back to F3 ( def bios )
Any problem like what Asus' P67 boards (all models) are having? There seems to be many frustrated users. All kinds of problems...DOA, not OCable, not stable, glitches left and right, etc....That's why I do not want to be a beta tester. Hope the dust will clear soon or else I will have to wait until 2nd half before doing any upgrade.
Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
Asus MA378-T with AMD Athlon 64 X2 7850
ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
I have noticed a problem with Gigabyte Dynamic Energy Saver 2. My CPU is currently at 4.5Ghz @ 1.265v.
Anyhow i decided to install DE2 and see what it does, but when i enable Dynamic Energy Saver it puts my voltage to 1.58v . Maybe this software is designed to work with everything on the motherbaord being set to Auto and default settings?
Has anyone else come across such an issue?
Wow 5.5ghz amazing WITH HT ON!!!! that must be a new on. That is impressive I must say the least jack!
Hmm that is odd with DES2, what i do know is that if you don't install DES two then phase switching doesn't occur(as in 2 phases or 4 phases at a time) 12/12 phase occurs automatically other than when OCing.
Maybe DES hasn't been properly updated? IDK how it can change your vcore?
