Hi all, I've been roaming through some of your posts lately due to the fact that I've just bought myself a new PC and as a CPU I chose the i7-950. With it I bought the aftermarket cooler 212+ from Coolermaster to make sure that I could OC the CPU and keep the temps decent.
However, I feel like my temperatures are really high and I saw some of you discussing what the highest temperature should be. Some say that 68*c is what I should aim at, 73*c being the maximum, While some argue that it has to be under the tjunction of 100*c. As you can see, that's a lot of difference, and I'm not at all used to reading temperatures close to 100*C from my old E6750.
At the moment I have it clocked at 3.6ghz and when running the intelBurn test it reaches temps around 73 (the highest I've had for a brief moment after sequential tests on very high settings). Also I have HT disabled to keep these temperatures.
So my question is two-fold. What is the ideal temperature to shoot for if I want to get the most out of my OC, without being in the risk of shortning the life of my CPU noticeably? And are my temps too high? Have I done something wrong mounting the CPU Cooler? I have tried reseating it, but it still idles around 40*c.
Ofc I don't know what the ideal temps are, as I'm not used to this CPU, but I am a bit "disappointed", since I went out of my way to get a real nice Case (the corsair 600t) and made sure all the cables were routed behind the motherboard so it should have surpreme airflow. But maybe this is what I should expect? And ofc, if the "safe" temperature goes all the way up to under the tjunction then I still have a lot of headroomBut that's for you to tell me
Thanks in advance![]()
Saaya yupp, I agree
