Okay so I was wondering why a lot of people around here seem to believe a 5200 btu a/c system is only good for an oc'd cpu? The conversion for btu to watts is 1 watt = 3.413 btu's so a 5200 btu system should have 1523.6 watts of cooling power, a top end oc'd cpu maybe puts out 300 watts of heat? That still gives a lott of head room for gpu's, nb, ram, etc.. sure the pump and lack of perfect insulation takes some of that cooling power away but still most computers today won't go over 1500 watts of heat.. so wouldn't I be good to use a 7000 btu system (2050.1 watts of cooling) for my whole rig? With dual oc'd gpu's, oc'd cpu and ram and nb all hooked up to the loop? I doubt that'd break 1500 watts of heat even..? Any input here?
