I would describe the theme I'm creating on the 600T as "Sci-Fi or Futuristic Military Equipment Cargo Carton" that has seen some action in the field. (No bullet holes on this one!) The drawings I posted are only Conceptual. The final piece will be slightly different and much more detailed. A large portion of the construction will involve PVC sheets and I will debut a brand new custom LED lighting system, compliments of I&H Accessories
Graphite Series 600T Manufacturer Product Information
The Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade.
Features for Builders
Corsair innovated cable routing with the Obsidian Series™ cases, and the Graphite Series features the same ingenious design. Pre-cut holes in the motherboard tray with rubber grommets and plenty of room behind the motherboard to route cables for a clean, uncluttered interior. The optical drive bays are tool-free, the side panels easily detach with the built-in latch mechanisms, and the integrated fan controller allows you to choose between quiet operation or maximum cooling performance.
Features include
* Twin 200mm cooling fans with white LEDs for excellent cooling
* Eight expansion slots provides you flexibility for multiple graphics card solutions
* Unique cable routing holes guarantees you a clean and clutter-free installation
* Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance
* Tool-free optical drive installation makes building your system faster than ever
* CPU backplate cutout makes upgrading your CPU heatsink easy
* 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!
* Two year warranty with Corsair’s world-class customer service and technical support
Specifications
Type
ATX Mid Tower
Color
Dark Graphite Metallic
Case Material
Steel / Plastic
Motherboard Compatibility
Micro ATX / ATX
External 5.25" Drive Bays
4
Internal 3.5" Drive Bays
6
Expansion Slots
8
Front Ports
4 x USB 2.0, 1 x USB 3.0, 1 x IEEE1394, 1 x Headphone, 1 x Mic
Cooling System
1 x 120 mm fan
2 x 200 mm white LED fans
Dimensions(L x W x H)
23.30" x 10.40" x 20.00"
Weight
24.5 lbs. (out of carton)
Photo tour of Corsair's new 600T Graphite Mid Tower case before modifying it
Countersunk holes for 10/32 socket head screws, in the channel around the border and attaching window. CNC milled from 1/2" thick sheet of PVC.
Updated 9/27/10
Soss Hinges for the HD access door
ball latch
HD Access door
