@Notechis:
Looks like you have that on too tight, you can see the card warping. No need to be so tight that it warps the card, It could damage it (i.e. could make the GPU break contact with some BGA pads)
@Notechis:
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
Just throw a gpu only block on like I did. You could probably find one for 40-50 bucks(less if used) and use it for multiple cards. Throw some good 'sinks on the mem and vregs and you are good to go. Palit and I believe Gainward are g92 spacing so no extra bracket needed. Plus swiftech should( if their smart) have a reference adapter for all the other 460's.
I checked my card, but it doesn't look like it's warped. Well maybe in the middle, (checked it with a ruler , otherwise it look straight) but my guess is that it's because of the weight of the cooler pushing down.
I've took another picture and you can see it that X-Fi which is above GTX is also warped at least on the picture so I think the camera must be slightly distorting images
In case it benefits anyone to know, the Prolimatech MK-13 fits the 768MB Palit card without any modifications to the heatsink.
The MSI, easily.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
MSI Cyclone OC wins on cooling, has a better HSF design.
Palit Sonic Platinum wins on performance, stock clocks are 800/1600/4000, MSI only 725/1350/3600.
Now you should be able to OC the MSI to match or exceed the Palit, however there is no guarantee that it will, but very likely it would. Also the Palit is smaller.
I'm waiting for a better cooler too,after my accelero twin turbo i need this silent again!
MSI 1GB Cyclone
The daily system
2500k @4.3 - P8P67 Pro - 4GB Corsair XMS3 C8 1600 - 460 cyclone 875/2050
That HS is huuuuuuuuuuge. Possibly worth cutting it down a bit.
"Prowler"
Cooling:
So the Prolimatech wont fit the MSI,GB,Asus... cards?
Looks like the palit is non reference.
Damn it looks good.
The daily system
Correct palit is non reference. however it sports the g92 bolt pattern so lots of aftermarket coolers and water blocks will fit, same with the gainward.
That was my reason for going with the palit, i had a dd maze5 water block on my 8800gt, and it bolted right on to the palit, did not even have to open up my loop another big plus!
Last edited by CrazyNutz; 09-02-2010 at 05:19 PM. Reason: typo said galaxy but ment gainward
Ah too bad it wont fit,my accelero twin trubo would been nice for this card.
I'll keep searching for the first aftermarket air cooler!
The daily system
The prolimatech comes with a whole bunch of little heatsinks to use on the other chips of the memory card, so I am using those. Here is a link that has some better pics.
