this tech station is actually a combo of 2 existing cases... when done it will house (4) 5 1/4 bays and between (6) and (10) 3 1/2" bays.
The Motherboard will be externally mounted with a set of hinges on the tray allowing for easy access to the internals...
it will have provisions for at least (3) 120mm fans on the bottom level
I am debating weather this should be a vertical or horizontal case...
