Hi guys,
I have just designed myself a floor/desktop radiator stand to mount a 140mm rad, in my case its being designed to support the mammoth weight of a quad 140..
Any mfr is going to charge me a fortune to CNC out those feet unless were talking large volume, I was wondering if anybody here can Lathe work alu bar for £££?
Approx Requirements:
Just under 1" dia, approx 15mm thick.
Small counterbore/recess one end for sticky rubber pads.
M5 hole through centre.
Two small flutes around diameter, only for aesthetic purposes!
Full engineering drawing will be given.
I think I am going to widen the base a bit to give more stability, and adjust some panels as they do not blend well together.
If anybody wants one give me a shout as it'll bring costs down with more made in one go!
Cheers!
