Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 241
Thread: Asus Crosshair IV 0801 Bios
  1. #76
    Feb 2006
    Potosi, Missouri
    Quote Originally Posted by malik22 View Post
    Hi guys ive decided to go the AM3 route im getting this board and a X6 I have a question though I have a kit of kingston 3x2gb 2000 that I was gonna use with a I7 build will they work with this board?I would only use two to have dual channel.
    If they are newer model CAS9 sticks they will work but 2000 speed will be dependent on how strong the memory controller is on your CPU. With that said, 2000 memory speed is pretty much useless for 24/7 anyway if you are looking towards performance. If they are they older CAS8 sticks the best performance I found with them is at 1600 CAS6.
  2. #77
    Xtreme Cruncher
    Apr 2008
    Ohio
    Quote Originally Posted by FlanK3r View Post
    I have build problem....My Thuban is done, but i cant boot, because ASUS board dont dedect my second HDD :-/...I tried diferent SATA ports, but it was the same. HDD spins around 10s, than turns off. In BIOS dont see it . So i took this HDD and boot with him without problems at the second PC with Gigabyte boards and 965 BE. Wtf??? Some setings at bios or...?
    How old is the drive? try the single SATA port that stick out by itself. See if your drive has a speed change from 1.5 to 3.0 jumper.
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
  3. #78
    Jan 2007
    Quote Originally Posted by Praz View Post
    Here is the kit number KHX16000D3T1K3/6GX kit of 3 all I want to know is if it will work with this board?
  4. #79
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    charged3800z24: it was samsung 500GB F3 http://www.alfacomp.cz/php/product.p...4007H000000RM1... My board dont see it ...Now im at 2x 320 GB older HDDs
    ROG Power PCs - Intel and AMD
  5. #80
    Feb 2006
    Potosi, Missouri
    Did you try both 3GB and 6GB drive options in the BIOS?
  6. #81
    May 2008
    Czech republic
    Praz:no, where is it exactly?
  7. #82
    Feb 2006
    Potosi, Missouri
    Main Tab -> OnChip SATA Speed. Need to be on at least the 0701 BIOS.
  8. #83
    May 2008
    Czech republic
    yes, i have 0701...
  9. #84
    I am Xtreme
    Feb 2003
    Netherlands
    Another flaw of this bios: Once the system has hardlocked or bsod'ed, the next boot is always unsuccesfull. I have to push the reset button to make it post agian.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
  10. #85
    Xtreme Mentor
    Nov 2005
    Devon
    I have the same fluctuating HTT issue as other guys, but it is non-issue for everyday use. It only gets nasty when you OC to the limits
    Second problem I've found is that SIL SATA controller can't see my Samsung F1 750GB 32MB drive with Boot Room enabled. It simply sits at detecting screen for 2 minutes and then finds nothing. With Boot Room for SIL disabled and Windows booted up from another drive, the invisible F1 750GB is accessible!
    It works fine though from SB850 SATA connectors, but due to my HDD setup I would prefer to boot F1 750GB from SIL controller which I can't at the moment :/
    Samsung F1 1TB, Samsung T166 400GB and OCZ Solid SSD 30GB are detected on SIL controller fine.
    @Bingo13 - is theoretically possible to set SB850 SATA channels 5 and 6 to RAID without setting first 4 channels to RAID as well? Will option like that (if possible) be implemented in future BIOS releases?
    Thanks!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  11. #86
    Jul 2009
    England
    There is me thinking retail is from a store Wish I could get sequentially picked retail chips from the future
    My pot is bigger than your pot
    WHAU!!!!
  12. #87
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by El Gappo View Post
    A retail batched part is destined for a store so whether it comes off the line or out of a box or off a shelf does it really make it any diff? Week 15 chips are the past.....plenty of people have em btw just some FYI. Flanker is in another country has one, madd22 in asia has one....
    When you can convince AMD that the smarter choice is to sell boxxed chips to a reseller, then buy them back for more money and then have me bench them you let me know.
    You really need to research before you speak gappo this is week 19 atm, I received on week 17 and the chips are week 15.
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
  13. #88
    Jul 2009
    England
    Yeah all well and true, they are hitting stores now but didn't you get them before blackops? I just think calling it a retail looses meaning when your average joe can't go get one.
    Your always one step ahead chew*! or 4 weeks in this case lol.
    WHAU!!!!
  14. #89
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Well would you rather have me use ES or retail grade parts retail avg joe can get one just not the same day.
    I got them week 17, I imagine resellers move old stock before selling new. So I can't call my retails retail anymore if i have a week before everyone else? Or am i allowed to call them retail only when others have the same week. I fail to see the point your getting at...basically. Average joe can compete with and buy a 1090T.
    I have plenty of week 15 duds if you want to buy them so you don't feel left out. I said it before and i'll say it again, I binned a few 2 were good rest were ehhh.
    Chips are only good becasue i took the time to bin. More chips you test the higher the chances to find a decent one, it's the basic law of averages.
    heatware chew*
  15. #90
    XIP
    Nov 2004
    NYC
    Retail or "retai"l don't matter. All have etched batch and week on its hsf.
    Unless peep got his hand on ACBBE, the only thing that matter is NB @>4300 with any given board
    If peep have $3200 to spend then they can binned 10 pcs. of 1090T from Newegg....as simple as that then sell it/all and start it again
    Better yet, open a used cpu store
    I have two 1013 and one is good. I will keep torturing 'em untill it dies or get rid of. Then I will buy another 1090T and again and again
  16. #91
    Jul 2009
    England
    The point I'm making is I want some retail chips from the future :p
    WHAU!!!!
  17. #92
    XIP
    Nov 2004
    NYC
    It doesnt matter peep got cpu for free or they actually spend money on it...The truth of the matter is unless peep have a lucky streak with one gem cpu, most of the time they have to binned a few or a dozen to find one or two that really good on air, water or ln2......make it 3 dozens
    Now lets go back to Bios 0801...Shall we?
  18. #93
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    We seem to be varying a bit off topic here...
    I've been on the quest for the perfect Week/Serial Number for the last 10 years and have never found the secret formula.
    It all really comes down to "Luck of the Draw" unless your lucky enough to get hand tested chips from the manufacturer.
    That being said, I'm going to go pick out a 1055 tomorrow (21 samples to choose from) so if anyone has any suggestions for a good week/Serial# I'm all ears...
    I do have a couple question though.
    1) Does anyone know what "IOMMU" does under the Advanced/NB Chipset Config tab?
    Would it help to enable it?
    2) I'm having a really hard time getting my machine to boot with an HTRef of 300 or greater (practice for the 1055 ). Everytime I try to boot at a high HTRef my machine hangs at the Win7 splash screen,
    and even worse, it has trashed my Video Card drivers a couple times requiring a "System Restore" to get things back.
    I'm running a 4850/4870 Crossfire settup BTW...
    Anyone know if the 300 HT is a limitation of the board, or is it just the 965 thats causing the problem?
    Thanks... Dave
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
  19. #94
    May 2008
    Czech republic
    Lightman: i have to fluctuating, but not always...try some restarts to system (third restart was ok for me :-) )
  20. #95
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Put 80 hours a week in like i do....stare at a memtest screen for another 20 hours a week, help endusers, never game or enjoy yourself and have very little time if any to bench and I'm sure you will get your wish. Did I forget to mention that all that needs to be done weekly without pay?
    Point grass is not greener on other side of fence.
    Dave you shouldn't have much issues until after 350 although depending on ram divider your using it could be straining your ram.
    I am busting my hump to get the manufactuers to get 1/1 ram ratios working on ddr III boards....that should help out most average guys as 400HT with 1/1 ram divider = 1600 ram
    I have already confirmed/debunked the myth that these chips aren't fond of HT and have been booting/benching at 420 HT.
    heatware chew*
  21. #96
    Feb 2010
    Poland
    it was samsung 500GB F3 ... My board dont see it
    Hi! F3s have compatibility problem with AMD SB850 chipset.
    Here is a firmware upgrade for F3s solving this problem:
    http://www.samsung.com/global/busine...bbs_msg_id=308
    And Here is a correct F/W Patch Procedure:
    1. Unzip "ASUS.EXE" file to DOS Bootable media (USB, CD, Floppy...etc).
    2. Remove all other SATA drives and put the F3 disk on the first SATA port.
    3. Boot the system to DOS.
    4. Run "ASUS" (without quotation marks!).
    5. When FW Flash successfully message displays, please Power OFF system, to make F/W flash complete.
    NOTE: Please DO NOT warm boot (Ctrl+Alt+Delete, or push Reset button..etc) your PC after the F/W patch !!!
    Warm boot can make F/W Patch fail and make unexpected problem on HDD.
    6. Restart the system normally.
  22. #97
    Xtreme Mentor
    Nov 2005
    Devon
    Thanks for the tip
  23. #98
    I am Xtreme
    Feb 2003
    Netherlands
    Quote Originally Posted by Daveburt714 View Post
    Dave, just don't boot into windows whenever testing high ht refclock or high mem clocks/tight timings.
    Whenever i do one of the above testing i always boot into memtest86 from a thumbdrive. (push F8 in postscreen and select bootable device)
    This has save me many many headaches. Once i found settings that survive a number of loops of test 1,2,3 and maybe test 4, i'm brave enough to put my Windows install on the line.
    When i'm testin ram i usuallly run test 1,2 and 3 cause they don't take long and then at least 3 loops of test 5.
  24. #99
    Xtreme Mentor
    Dec 2007
    Zeus: Thanks for the advice man... Believe it or not, I actually know where my gear is somewhat stable and I try to keep things in range...
    When I push the HTRef, I make sure all the other clocks are well below my known stable state... I don't try to push everything at once, that leads to madness...
    Even with the CPU @ 3800, IMC @ 2400 and Mem @ 1600 I still can't boot at 300 HTRef.
    Personally, I find Memtest86 a little boring, but I'll take your advice and test memory a little more before I try higher HT clocks.
    I'm going to go pick up a 1055 tommorow to go with the new C4F....
    And it will all start anew. Hehe...
    I may not be as skilled as some of you BigDogs, but playing with stuff is 90% of the fun!
    And I do test quite a bit, even though some of my questions may seem noobish...
    Thanks for your advice bro, I'm sure this won't be the last you hear form me this weekend...
  25. #100
    Feb 2006
    Potosi, Missouri
    Thanks... Dave
    The board has no problems booting with 300 and above. Might be CPU, memory speed or voltages.
    click for larger image
