oh
Bad scores
oh
Bad scores
AMD Phenom II X6 1055T @ 4009MHz
NB @ 2673MHz
Corsair H50 + Scythe Ultra Kaze 3k
Gigabyte GA-MA790X-UD4P
2X2GB DDR2 OCZ Gold
XFX Radeon HD5850 XXX @ 900MHz Core
OCZ Agility2 60GB
2x500GB HDD WD Blue
250GB Samsung
SevenTeam 620W PAF
CoolerMaster CM690
One hundred years from now It won't matter
What kind of car I drove What kind of house I lived in
How much money I had in the bank Nor what my cloths looked like.... But The world may be a little better Because, I was important In the life of a child.
-- from "Within My Power" by Forest Witcraft
Who's the retard who tested a X6 at 800 mhz? What the hell?
lol those 1055T scores in cinebench look bad.
Does anyone know why were the tests done with 800Mhz or were these done with 2.8Ghz "The cinebench and vantage scores say otherwise" and if they were done in 800Mhz why ??
In cinebench the scores are like :
ST:
3246 - x4 920
4238 - i5 750
2758 - x6 1055T
MT:
11444 - x4 920
14142 - i5 750
12642 - x6 1055T
Is it possible that the 1055T is running at 2.8Ghz but the lack of cache is effecting the efficiency of the cores??
Coming Soon
yes 4.58x caught me off guard too, until i remembered turbo .... sidenote, higher cpu score in vantage than x4 @ 4150mhz cpu/2770mhz nb & lower score in cinebench multithread edit: these scores arent really relevant since they were on 64bit win7,,, just realized those scores were w/ 32bit :/
LEO!!!! amd phenom II x6 1100T | gigabyte 990fxa-ud3 . . 2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd sapphire ati 5850 | x-fi xtrememusic. . . samsung f4 2tb | samsung dvdrw . . corsair tx850w | windows 7 64-bit. ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . . lycosa-g9-z2300 | 26" 1920x1200 lcd .
Guys, this is only 32 bit Cinebench, AMD is more btter at x64 (better performance comparsion x86 vs x64 up than Intels a bit)
this score is simillary as x4 9xx Deneb core with 3.9 GHz
multi 4.6x is not bad! Man, do u think, it must be 5.9x?
Now we know score at x68, at x64 Thuban at 4 GHz will have about 4600x 4.62 = 21 000+(maybe more, case scaling mutli CPU is too better)
ajaidev : i5 750 score, what u posted is not x86, but x64. Know it at 100%. X4 965 is better in x64 than i5 750(turbo on) about 100 points.
ROG Power PCs - Intel and AMD
Found a score for a istanbul on socket F.
Thats 64bit mind you.
For the people that dont know, istanbul is earlier version of lisbon that was server only ,D0 stepping, lisbon/thuban is E0.
So theres definietely something wrong with that score
That opteron is a six core 2.6Ghz no turbo on slow DDR2 cpu.So if anything, scores for Thuban will be higher.
good comparison
hopefully 1090T is good for 16k
I agree those posted Thuban results are crippled.
I'd like to see Cinebench R10 and R11.5 x64 and WPrime
I've just made a quick bench on Win 7 64bit (with 32bit cinebench exe):
@3.8GHz:
Cinebench
Thuban: 12642
Deneb: 9023
Vantage CPU (perf.)
Thuban: 14533
Deneb: 9570
So where is the problem?
Mem on the result posted is running at 3GB+ Unganged Mode @ 666Mhz @ 9-9-9-24. HyperMemory introduced some latencies too. ^_^
Like many have stated before the scores are perfectly fine... C10 is a 32bit score and is like Oliverda showed 40% higher than on the same clocked Deneb,while scaling is off due to higher single tread score produced by Turbo Core functionality. Vantage score shows perfect scaling(50%).Oh and the CnQ is on obviously hence the 800Mhz CPUz shot. So,again where is the problem ?
I think the ram is slow.
And 3Go of ram. ... 32bit os with 4go of ram ... !!!
wouldnt 3GBs of ram mean that duel channel was off?
edit: NM it does have 4GBs but only 3.3 are avail. good job confusing me
I wonder if we can disable Turbo mode? Strictly for Folding@Home I'd love to have all my cores running at the same speed.
As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
No,it means the test rig used 32bit OS... Ram is naturally dual ch. Again,the scores show higher single thread perf. due to Turbo and 40-50% higher multi thread. results over Deneb. Quite predictable if you ask me and very good .
Turbo is for poorly threaded apps ,while folding your cores will run at the speed you set them to(be it stock or OC manually in BIOS or AoD).
Turbo is for noobz.
according to the link,
Phenom II x6 1055T 32bit Cinebench R10 render time is 1 min 9 sec, 69sec
Core i7 920 32bit Cinebench R10 render time also 69sec
Core i7 920 source: http://www.legitreviews.com/article/824/9/
edit: I guess logically, Phenom II x6 would have at least 5.3x of rendering time of a single core
Main Rig:
Processor & Motherboard:AMD Ryzen5 1400 ' Gigabyte B450M-DS3H
Random Access Memory Module:Adata XPG DDR4 3000 MHz 2x8GB
Graphic Card:XFX RX 580 4GB
Power Supply Unit:FSP AURUM 92+ Series PT-650M
Storage Unit:Crucial MX 500 240GB SATA III SSD
Processor Heatsink Fan:AMD Wraith Spire RGB
Chasis:Thermaltake Level 10GTS Black
Main Rig:
