XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 02-05-2010, 12:43 PM   #1
batmang
batmang's Avatar
[i5_alive]
[i5_alive]
The goal of this build
  • Overclock the i5 750 to a modest 4GHz
  • Maintain a full max CPU load temperature of 65C or below
  • Build a clean and functional water loop within the NZXT Tempest EVO
Components / Hardware
  • NZXT Tempest EVO Case
  • Intel i5 750 2.6GHz Quad Core CPU
  • ASUS P7P55D Deluxe
  • Kingston DDR3 1600MHz 2x2GB Memory
  • XFX ATi 5770
  • 74GB WD Raptor 10,000RPM Hard Drive
  • Samsung DVD-RW +/- Optical Drive
  • Corsair HX 650 PSU
  • Clear plexiglass side panel window replacement (I don't like the smoked window or the side panel fan)
Water Parts
  • Swiftech Apogee GTZ CPU Block
  • EK ASUS P7P55D Acrylic Chipset and MOSFET's Blocks
  • EK Reservoir Combo DCP 4.0
  • EK MCP 4.0 Water Pump
  • EK 5770 GPU Block
  • HW Labs SR1 120 Radiator
  • Koolance 2x140 Radiator
  • PrimoFlex 7/16 inch Inner Diameter Tubing - White
  • BitsPower Matte Black 1/2 inch Barbs
- Have
- Don't have yet
Rough Google SketchUp of routing plan (this is the very early idea, changed since then)
__________________
X6 1090T @ 4.2 (for now ) / 890FXA-GD70 / 5850 / 4GB 1600MHz / Water
HEATWARE
batmang is offline   Reply With Quote
Old 02-05-2010, 12:47 PM   #2
batmang
batmang's Avatar
EK ASUS P7 series blocks with Bitspower matte black 1/2" fittings.
Koolance 2x140mm Radiator with Bitspower matte black 1/2" fittings.
EK DC 4.0 Pump with reservoir combination with Bitspower matte black 1/2" fittings and plug.
EK motherboard blocks installed.
__________________
HEATWARE
Old 02-05-2010, 12:48 PM   #3
batmang
batmang's Avatar
Koolance 2x140 radiator installed. Fit perfectly.
HW Labs 120mm Radiator
EK SB Block
CPU is lonely, awaiting the block. :P
__________________
HEATWARE
Old 02-05-2010, 12:49 PM   #4
batmang
batmang's Avatar
Unplanned memory arrived. 2x2GB G.Skill DDR3 1600MHz CL6 1.65v
Did more cable management, fixed kinked tube, leveled the res/pump, installed memory, and finally decided on loop path.
Since temps don't change for crap when the routing is changed, I'm going with the simplest and cleanest route.
Cable management
I will have more pics to post tonight. I'm waiting for the 24 pin 8" extension to come in so it can be sleeved as well as my reference 5770. Once those items the build will be pretty much complete.
__________________
HEATWARE
Old 02-05-2010, 04:13 PM   #5
Antioch
Antioch's Avatar
hmm... it's really Nehalem... but whatever. I likes.
How are you enjoying the board? I've had a hellacious time with mine. Seeing you're all decked out makes me jealous/
Antioch is offline   Reply With Quote
Old 02-05-2010, 04:37 PM   #6
batmang
batmang's Avatar
Lynnfield is based off Nehalem, but it has an integrated IMC and PCI-E controller, and also has a different socket. Definitely not Nehalem.
I'm enjoying it very much. Clocks very well, responds to memory overclocks well. Great board.
__________________
HEATWARE
Old 02-05-2010, 05:00 PM   #7
batmang
batmang's Avatar
8 inch 24 pin cable arrived. Came with two white ends, replaced motherboard end with a black one. I was planning on sleeving it, but to my surprised it arrived in all black wiring. No sense in wasting sleeving...
Looks good enough to me.
__________________
HEATWARE
Old 02-05-2010, 05:03 PM   #8
liveify
liveify's Avatar
Where did you get that extension?
__________________
800d -
q6600 @ 3.2, Asus p5n-d 750i, 4gb Mushkin ram, Evga 285 Classified, 8800gts for second and third monitor, PC Power and Cooling Silencer 750
Swiftech gtz, mcr320 & 3x panaflos, mcp355 & xspc top, Bitspower z-multi resivoir, bitspower matt black 1/2
liveify is offline   Reply With Quote
Old 02-05-2010, 05:07 PM   #9
weston
Looks like a good start, I agree that the black wires look good, sleeving is nice, but it's getting a little too common I'd say. Bare wires are more unique
weston is online now   Reply With Quote
Old 02-05-2010, 05:19 PM   #10
Antioch
Antioch's Avatar
By that I'm assuming you think that the Bloomfield chips are "Nehalem"? All the Core i-series are Nehalem (Core i3/i5/i7, Bloomfield/Lynnfield/Clarkdale/Arrandale/Gulftown), just different configurations of it - but the core logic is all the same. What changes is the UnCore (the PCIe controller and such that you mentioned).
http://en.wikipedia.org/wiki/Intel_N...oarchitecture)
See the variants subsection. We're all one big happy family, just different shapes.
Old 02-05-2010, 05:26 PM   #11
batmang
batmang's Avatar
ugh. of course i know this. lets get back to the topic please...
__________________
HEATWARE
Old 02-05-2010, 09:27 PM   #12
Antioch
Antioch's Avatar
It's my pet peeve.
Old 02-05-2010, 09:58 PM   #13
batmang
batmang's Avatar
It's my pet peeve.
Does my signature bug you because it doesn't say " Nehalem " ? Is it really that big of a deal that my sig says Lynnfield. Here is a good example; how many people have you seen call the i9's Nehalem's? I'm pretty sure the majority of people refer to them as Gulftown. Just like people referred to i5-750's and i7 8xx at launch as Lynnfield. We all know what they are based off of, but differentiating them is much easier using the specific architecture name. Why does it bug you anyway?
__________________
HEATWARE
Old 02-06-2010, 12:22 AM   #14
Kadett
Kadett's Avatar
Nice build, but its a shame really to have spend that 100 bucks on the Asus Chipset/Mosfet where you could have spend it on a faster video card. Its not in need of cooling and from the looks of it the southbridge block sits in the way for an Crossfire upgrade? Or does it leave just enough room to add a second video card?
Kadett is offline   Reply With Quote
Old 02-06-2010, 01:34 AM   #15
Alexandr0s
Alexandr0s's Avatar
I'm pretty sure Eddy made that block so that a video card could still be installed there.
And lets keep watercooling for p55 motherboards discussion in it's appropriate thread .
Alexandr0s is offline   Reply With Quote
Old 02-06-2010, 01:55 AM   #16
jcool
SR-2 WB missing, go Eddy!
jcool's Avatar
Actually, that's not entirely correct - Gulftown (and other new 32nm CPUs due to be released in March) are based upon the Westmere architecture
Remember the good old game.. Nehalem was Tick, Westmere is Tock (die-shrink, more Cores/L3, hardware AES unit etc)
On topic: Nice build, I like it
__________________
World Community Grid - come join a great team and help us fight for a better tomorrow!
Rigs:
16-Cores: Quad Opteron 8347HE @ 2.0
12-Cores: Dual Westmere-EP X5680 @ 4.3 | Dual Westmere-EP X5650 @ 2.93
Octacores: Dual Gainestown X5570 @ 2.93 | Dual Harpertown X5450 @ 3.6
Hexacores: Intel Xeon L5640 @ 3.8
Quadcores: Core 2 Q9550 @ 3.8 | Dual Sossaman (Yonah Xeon) @ 2.0
crunching 24/7 | crunching part-time | offline/down
jcool is online now   Reply With Quote
Old 02-06-2010, 03:00 AM   #17
Red-5
Red-5's Avatar
A very neat and tidy build you have there. Looking forward to following it. Excellent photos by the way
Red-5 is offline   Reply With Quote
Old 02-06-2010, 03:19 AM   #18
ohms
VČ/P
ohms's Avatar
Send a message via AIM to ohms Send a message via MSN to ohms
Looks like a nice build so far! nice choice of hardware also
I was tempted many times to pick up that EK pump/res combo but I couldn't really find any reviews on it so avoided it, do let us know how it works out.
__________________
My Worklog: Project Raven (CM ATCS 840) || My Worklog: Project Raven MK II (CM 690 II Adv) || The Build Blog
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
" Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
ohms is offline   Reply With Quote
Old 02-06-2010, 08:13 AM   #19
batmang
batmang's Avatar
Glad you like them, I try and utilize my D40 and 35mm f/1.8 lens as much as possible. :P
Thanks for the feedback everyone. The pump/res combo should do well, I have faith in EK products. A second card will fit, just barely. EK did a wonderful job designing the P7 series blocks. Although they are unnecessary, I wanted to cool the entire motherboard. I didn't want to spend too much on a video card because this rig will be used for light gaming, I'm not a hardcore gamer. I wanted a moderately quiet case that would properly cool an overclocked i5 750 but also have the aesthetics be a big part of the build as well. Nice, clean, functional, that was the goal.
__________________
HEATWARE
Old 02-06-2010, 08:37 AM   #20
batmang
batmang's Avatar
EK 5770 GPU Block, still waiting on the 5770.
__________________
HEATWARE
Old 02-06-2010, 09:17 AM   #21
aka_GK
aka_GK's Avatar
Send a message via ICQ to aka_GK
I like this warmy supersharp picture styling Probably it is not perfect photography but it adds some personality to this buildlog
subscribed and waiting for more
__________________
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
aka_GK is offline   Reply With Quote
Old 02-06-2010, 12:03 PM   #22
skydoy
skydoy's Avatar
WOW great pics ^^
Great Build you have there ^^
__________________
Gigabyte GA-X58A-UD7 | Intel Xenon 3520 | 6GB Gskill DDR3 PC12800 Ripjaws CL8 | XFX 5850 XXX 1GB GDDR5 PCIe2.0 | 2X Samsung F3 500GB | 1TB Seagate | 1TB Samsung | Crosair TX 750W | Samsung T260HD | Razer Manba | Razer Lycosa Mirror | Powered By: SilverStone TJ07
skydoy is offline   Reply With Quote
Old 02-06-2010, 01:28 PM   #23
batmang
batmang's Avatar
Thanks sky! 5770 just came in, putting everything else together right now. More pics later tonight.
__________________
HEATWARE
Old 02-06-2010, 02:37 PM   #24
skydoy
skydoy's Avatar
Cool i Love good pics ^^
Post Some more ^^
__________________
Old 02-06-2010, 05:09 PM   #25
batmang
batmang's Avatar
Leaked tested approved.
Rig is up and running, working great. 5770 is overclocked to 960MHz core / 1445MHz memory and after 40 minutes of Furmark's xtreme test the max temp is 47c, average is 46c.
http://img.techpowerup.org/100206/Capture.jpg
I will have more pics of the system running tomorrow.
__________________
HEATWARE
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
