Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: HD 5670 Reviews
    Sep 2004
    If really at < $100 US it is a steal of a card IMO. Much higher than 4670 with the early drivers too.
    HTPC - AMD Phenom II 555 Unlocked(4cores) - 4GB Gskill - AMD HD 5850 - Avermedia Duet - Harman Kardon avr247 - Surround Sound (Infinity Beta 50's, 10's, 360, and ed a2-300) - Samsung 46"
    Desktop Powerhouse PC - Gathering dust due to high usage of HTPC as general pc now
    Jan 2008
    So, we have 800 shaders (HD5770) and 400 shaders (HD5670) as replacement for the previous generation. Maybe they will release a replacement for the HD4770 (640 shaders) as the HD5730 or something like that?
    Although with the HD5770 at ~$160 and the HD5750 at ~$140 there's no real reason to add another card for a potential ~$120 segment and saturate the production...
    Jun 2006
    Florida
    Quote Originally Posted by Pontos View Post
    The HD5770 and HD5750 are the replacements for the HD4770 and HD4750.
    Core i7 3770K
    EVGA GTX780 + Surround
    EVGA GTX670
    EVGA Z77 FTW
    8GB (2x4GB) G.Skill 1600Mhz DDR3
    Ultra X3 1000w PSU PSU
    Windows 7 Pro 64bit
    Thermaltake Xaser VI
    Feb 2005
    OZtralia
    Looks like it runs a little too hot for HTPC usage using the std cooler
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
    Oct 2004
    well, its the cheapest card that can bitstream hd audio, and it is fairly energy efficient. a good htpc card.
    for gaming, its hard to top the $100 4850's that are floating around. those basically thrash anything that cost remotely the same amount.
    DFI P965-S/core 2 quad q6600@3.2ghz/4gb gskill ddr2 @ 800mhz cas 4/xfx gtx 260/ silverstone op650/thermaltake xaser 3 case/razer lachesis
    Jan 2009
    Hmmm... Beastly little card. A little bigger then I expected it would be... but still not too shabby.
    ASUS Maximus VI Impact | Intel Core i7 4770k | Sapphire HD 5870 | 2x8GB Corsair Vengeance 1866 | Corsair 760AX
    Jul 2009
    NY
    Not sure what Ati is trying to do here , this thing has more bandwidth then 4770 while having less SP's? 128 bus plus 4000 mhz gddr .Not a big deal just strange , have gddr5 have gotten cheaper then gddr3 ?
    My Heatware
    Originally Posted by some guy on internet
    That's your problem right there. Just forget about how things look on paper as that's irrelevant.
    Oct 2009
    Santos(São Paulo), Brasil.
    Quote Originally Posted by ~CS~ View Post
    Gddr3 probably is cheaper, but GDDR3 on this card would cause it to be bandwidth limited.
    Maybe GDDR5 memory that can reach 4GHz is not more expensive than the GDDR5 in HD4770 cards.
    AMD Phenom II X6 1055T @ 4009MHz
    NB @ 2673MHz
    Corsair H50 + Scythe Ultra Kaze 3k
    Gigabyte GA-MA790X-UD4P
    2X2GB DDR2 OCZ Gold
    XFX Radeon HD5850 XXX @ 900MHz Core
    OCZ Agility2 60GB
    2x500GB HDD WD Blue
    250GB Samsung
    SevenTeam 620W PAF
    CoolerMaster CM690
    Apr 2008
    Lansing, MI / London / Stinkaypore
    Not exactly yet, but enough cheap (1.3-1.5x cost I'd say) that ATI can make their whole range of GPUs use GDDR5.
    Envy 15's 5830 uses GDDR3, but again it's under TDP reasons instead.
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Wuf
    Jul 2007
    Finland/Tampere
    Lets see does that card OC well as my HD4670, 1025/1030
    If it does, DAAAAAAMN
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    [22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
    Ze gear:
    Main rig: W3520 + 12GB ddr3 + Gigabyte X58A-UD3R rev2.0! + HD7970 + HD6350 DMS59 + HX520 + 2x X25-E 32gig R0 + Bunch of HDDs.
    ESXI: Dell C6100 XS23-TY3 Node - 1x L5630 + 24GB ECC REG + Brocade 1020 10GbE
    ZFS Server: Supermicro 826E1 + Supermicro X8DAH+-F + 1x L5630 + 24GB ECC REG + 10x 3TB HDDs + Brocade 1020 10GbE
    Lappy!: Lenovo Thinkpad W500: T9600 + 8GB + FireGL v5700 + 128GB Samsung 830 + 320GB 2.5" in ze dvd slot + 1920x1200 @ 15.4"
    Jan 2009
    They're trying to fill out their lineup of 5xx0 cards. It's what they did with the 4xx0 series; everything from the 4870x2 down to the 4350. Things might look strange compared to the 4000 series, but compared to other cards in the 5000 series it shows a typical trend going from high performance to entry level (or will). I imagine we won't see GDDR3 except maybe on the 5300 and 5400 series.
    NooB MOD
    Jan 2006
    South Africa
    Less TMUs than the 4670? I wonder how they'll compare, maybe I'll replace mine.
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Jul 2009
    NY
    Quote Originally Posted by Macadamia View Post
    As far as i know gddr5 uses less voltage and thus less power .
    I did found something interesting tho ,"Joe Macri is Director of Technology at AMD… and in parallel is the president of the JEDEC committee which is involved in defining DRAM memory standards." not sure if still the case , but it would give them an advantage and influence as to where the gddr5 prices will go plus i imagine buying more dgrr5 in bulk does reduce price enough to make gddr3 redundant .As far as gddr3 bottle necking the card i highly doubt , gddr5 will provide higher bandwidth and lower latencies but performance impact will be minimal .
    My Heatware
    Apr 2008
    1. Although less voltage is used you have ~2X the clock speeds. In an ideal condition voltage power scaling is exponential while clock power scaling is linear. So it's not as clear cut yet, especially on desktop, but mobile wise AMD is offering GDDR3 GPUs with higher clocks relative to the GDDR5 ones at the same TDP.
    2. Performance impact should be large enough on a 128-bit bus, see GT240's 2 variants. Brutal. It gets even sweeter on a 64-bit bus where clocks/voltage are both low and GDDR5/3 only accounts to ~2W difference (5470)
    Dec 2008
    Athens ~ Greece
    Give us a good fanless variant with GDDR5, and I'm sold...
    NooB MOD
    Jan 2006
    South Africa
    AMEN to the above, else I'll unplug the fan and run a 120mm Zalman F3-ZM under it.
  18. #18
    Apr 2006
    City of Lights, The Netherlands
    I guess I must have misread AMD's slides concerning the launch of their Mobility Radeon 5000 series cards, but I thought their GDDR5 models had a lower TDP than the DDR3. Not entirely sure about GDDR3 though.
    You also have to remember that the currently available GDDR5 memory is not comparable to the first iterations we had in for example the 4870 and future versions may be even better from a power consumption perspective. That's partially because of improvements to manufacturing, but mainly because they have been making slight changes to how it operates and will continue to do so in the future.
    "When in doubt, C-4!" -- Jamie Hyneman
    Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
  19. #19
    Jun 2009
    Quote Originally Posted by s0lid View Post
    doubt it with the cheapass standard cooler. Despite its low power consumption being a hothead, obviously the standard cooling solution sucks.
    Maybe with a vaporX edition.
  20. #20
    Wuf
    Jul 2007
    Finland/Tampere
    Quote Originally Posted by bladerash View Post
    wasn't talking about stock cooler
    I'm using AC Twin turbo accelero.
    Ze gear:
  21. #21
    Xtreme Guru
    Aug 2007
    Looks like the article was removed.
  22. #22
    Sep 2006
    Nordschleife!
    Quote Originally Posted by SKYMTL View Post
    Yep.
    I'm looking for a new HTCP card, this should be perfect with a decent cooler.
    For those who read the article, I suppose the 5670 has native HDMI out, right?
    Murray Walker: "And there are flames coming from the back of Prost's McLaren as he enters the Swimming Pool."
    James Hunt: "Well, that should put them out then."
  23. #23
    Xtreme Guru
    Aug 2007
    All new ATI cards have native HDMI out.
    Makes me wonder if the review took the price of the card versus the HD 5750 into consideration if they gave it such a positive review.
  24. #24
    Jan 2005
    No(r)way
    Do these lower cards still have Eyefinity? Damn, I wanted to read that review.
    Obsolescence be thy name
  25. #25
    Sep 2006
    Nordschleife!
    Thanks for the info. It's been a while since I went shopping for a low-end card so I wasn't sure.
    I think this VGA doesn't make any sense from a pure 3D performance standpoint so any sort of comparison with a 5750 is kinda pointless, IMHO. I mean, a 4850 (wich is comparable to a 5750) sells for almost free today and I'm sure it almost doubles 5670's performance in games.
