XtremeSystems Forums
Go Back   XtremeSystems Forums > Gaming > PC Gaming
Reply
Old 01-08-2010, 09:29 AM   #26
YukonTrooper
Land of the Midnight Sun
YukonTrooper's Avatar
Originally Posted by mr2sw21 View Post
What is the best setting to get to 3GHZ casue I have tried to OC it to 3GHZ but the V of cpu, north and south bridges and ram when up at least 10 to 20% higher so I need to tune those Voltage to lower or is fine to leave them auto?
There are tons of easy-to-follow guides for C2D overclocking.
http://www.asusreviews.com/forum/showthread.php?tid=6
http://www.hexus.net/content/item.php?item=9808
http://www.hardforum.com/showthread.php?t=1198647
http://www.clunk.org.uk/forums/overc...beginners.html
Those are just some I pulled up on Google.
__________________
For my part I know nothing with any certainty, but the sight of the stars makes me dream.
YukonTrooper is offline   Reply With Quote
Old 01-08-2010, 10:23 AM   #27
EniGmA1987
Send a message via MSN to EniGmA1987
Just trying to save myself a little bit here:
__________________
Originally Posted by Shintai
Imagine Microsoft said that Windows 7 would only work on Acer/HP/Dell/Lenovo machines.
Its just Apple thats full of BS
Tyan S2932G2NR-SI
AMD Opteron quads @ 2.6GHz (Shanghai) x2
16GB of Kingston DDR-800 ECC RAM
Nvidia GTX 470
EniGmA1987 is offline   Reply With Quote
Old 01-08-2010, 12:42 PM   #28
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
yeah, a $200 ethernet port is going to get you significantly higher framerates and significantly lower pings...
please, come on
dont you think businesses and stuff would be using the uber leet gaymen NIC if it really helped that much? it is a prime example of marketing
__________________
i7 860 3.80ghz+ HT Turbo -- P55 FTW A59 -- Ripjaws 4x2gb 1810mhz -- 5850 850/1200mhz -- Liquid Cooling Apogee XT / MCW60 -- Claro+ ATH-M50s -- U2711 2560x1440
Happy Hacking Pro 2 -- Majestouch 87 Blue -- M13 in Black -- Zero 87 Fukka -- Cherry Brown SPOS -- MX11900 -- Extended Keyboard II -- AT101W
AndrewZorn is offline   Reply With Quote
Old 01-08-2010, 12:48 PM   #29
One_Hertz
Xtreme Mentor
One_Hertz's Avatar
Send a message via MSN to One_Hertz
There are plenty of reviews saying that the killer NIC does nothing on a proper, fast rig with a half decent connection. It will only help if you are also doing other things while gaming, like torrenting.
The little time I played wow I was getting 60+ fps even in cities... I do have a qx9650 @ 4.65ghz though.
One_Hertz is offline   Reply With Quote
Old 01-08-2010, 12:51 PM   #30
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
but even router software can do the torrent prioritizing and stuff
__________________
Old 01-08-2010, 02:17 PM   #31
mr2sw21
Thanks all, will try it out over the weekend. Hope after overclocking his CPU and get all the display setting it can improve a bit more. With his limited budget he can't get a faster CPU nor N1 card for now. Hope for what we can do at the software part can help the game play a little faster and smoother.
Thanks all again.
__________________
Q9450 w/120 extreme
Maximus II Formula
G.Skill 4gb 8800 w/ crosair fans
Sapphire HD4870 512 w/ T-Rad2
2x 160gb raptor RAID0
2x 500 gb SATA
Cooler Master 850w PSU
CM 590 Case
mr2sw21 is offline   Reply With Quote
Old 01-08-2010, 05:08 PM   #32
Decami
Decami's Avatar
internet connection has absolutely nothing to do with FPS.
I play wow and my fps is perfectly fine with my rig no issues, ( i use vsync so its pretty much always at 60) yeah it drops a little bit in cities, but its only because the massive amount of people that are
there which puts a lot more strain on your hardware.
__________________
This post above was delayed 90 times by Nvidia. Cause that's their thing, thats what they do.
This Announcement of the delayed post above has been brought to you by Nvidia Inc.
RIGGY
case:Antec 1200
MB: XFX Nforce 750I SLI 72D9
CPU:E8400 (1651/4x9) 3712.48
MEM:4gb Gskill DDR21000 (5-5-5-15)
GPU: NVIDIA GTX260 EVGA SSC (X2 in SLI) both 652/1403
PS:Corsair 650TX
OS: Windows 7 64-bit Ultimate
--Cooling--
5x120mm 1x200mm
Zalman 9700LED
Displays: Samsung LN32B650/Samsung 2243BWX
Decami is offline   Reply With Quote
Old 01-08-2010, 06:56 PM   #33
mr2sw21
What do you mean by "you use Vsyne?" you mean you set it off?
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-08-2010, 07:43 PM   #34
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
vsync by definition will lower framerates. if you cant tell the difference when it is off... if "it" (which i will not describe, so that you continue to enjoy yourself) does not bother you, turn vsync off.
__________________
Old 01-10-2010, 09:28 AM   #35
SimonD
I always play with vsync enabled but that's because I play at 1920x1200, anything pretty much over 1280x768 needs to have it on unless you can live with the screen tearing (I can't).
As far as gaming goes, my wifes Shuttle (with a 4.8 AMD X2 939) has no issues playing the game (and she only has 2gb ram). My QX9650 @ 3.5ghz and dual 5770's have no issues in Dal or anywhere else. It is CPU\Ram related rather than GPU and it's also worth mentioning not having too much in the way of AA or AF set up, 4x on both 'should' be all that's needed, any more and you're going to suffer with it.
As far as multiple processors are concerned it won't really utilise cores 2 and 3 (because it will use 0 and 1 initially) but it will allow you to multitask better.
__________________
Gaming Rig
Gigabyte EX58-UD5
1 x i7 950 @ 3.66
Corsair 800D
1 x Sapphire Vapor-X 5870
6 GB Corsair DDR3 PC3-1333 @ 9,9,9,24,2T
Corsair HX1000 PSU
G19 Keyboard 3.04 drivers
120gb OCZ Vertex SSD
BenQ FP241 WS Monitor
Spare
Black Ops
Intel QX9650 @ 3.5ghz
Coolermaster Stacker
1 x 5770 ATI card
8 GB Corsair DDR3 PC3-10666 @ 9,9,9,24,2T
Galaxy 1000w PSU
G15 Keyboard 3.04 drivers
150gb WD Raptor with Windows 7 64bit Ultimate
SimonD is offline   Reply With Quote
Old 01-10-2010, 01:16 PM   #36
mr2sw21
I just OC his CPU to 3.0 but the V is about 1.35 is that ok? TEMP is ok about 36c with 100% load w/ Wprime
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-10-2010, 01:19 PM   #37
zalbard
I am Xtreme
zalbard's Avatar
Send a message via MSN to zalbard
That's about right, yeah, the temp is actually a bit low for full load, strange.
zalbard is offline   Reply With Quote
Old 01-10-2010, 01:27 PM   #38
mr2sw21
that was the 32m test now I am trying the 1024 test.
by the way I just looked at the rams speed (which I set to auto) it tuned down the ram from 1001 to 733 I guess it is trying to tune it to 1:1 ratio is that better or should I make it back to 1001?
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-10-2010, 01:29 PM   #39
zalbard
I am Xtreme
zalbard's Avatar
You will not get huge performance gains. I'd rather go for higher CPU clock speed first, and once you hit the cap for your CPU you can try and push your memory higher if there is still some headroom left.
Old 01-10-2010, 02:22 PM   #40
mr2sw21
it looks fine with the temp, but somehow after the w/prime done the CPU V all of a sudden jump to 2.04V for 1 or 2 second. does that mean it is not stable?
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-10-2010, 04:09 PM   #41
YukonTrooper
wPrime is not a stability test. You'll want to test with Prime95, OCCT, etc.
__________________
Old 01-10-2010, 09:33 PM   #42
AndrewZorn
Xτræmε ÇruñcheΓ
AndrewZorn's Avatar
this went from framerates in a game several years old to overclocking the CPU? yeah, that'll fix it...
__________________
Old 01-10-2010, 11:56 PM   #43
BatteryOperated
seriously, I have a samsung microwave range in the kitchen. its roughly 10-12 years old. never overclocked it. And I will be it can run WoW.
BatteryOperated is offline   Reply With Quote
Old 01-11-2010, 01:44 AM   #44
Piotrsama
Piotrsama's Avatar
+1
That PC is MORE than capable of running WoW.
As we stated before, just play with the settings on the video section of the game. Re-read my previous posts.
And you might want to update video drivers while you are at it, since he changed the video card.
Piotrsama is offline   Reply With Quote
Old 01-11-2010, 07:56 AM   #45
mr2sw21
Originally Posted by Piotrsama View Post
+1
I did up dated his GC driver to 9.12
we tried a lots of setting in the option of WoW we can basically set everything to high except the shadow texture (must be low) otherwise regardless how much I overclock his cpu it still slow.
by the way we already killed all the program so basically WoW is the only program running besides OS which is 32bit XP
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-11-2010, 08:48 AM   #46
Manicdan
I am Xtreme
as a big WoW gamer my opinion is as follows
i play with vsync on, even though for me due to windowed mode limits it to 30fps most of the time (i have no idea why, but i just does) with vsync off i can get 150fps in empty areas, which really makes the gpu work hard and heats up more, i like to keep it around 50-60% usage, not 99%. so i can keep the fan speed low.
testing fps in a main city is a very bad idea, its just too cluttered and will not represent real experiences (press Cntrl + R to turn on the ingame fps counter) and see what the range is in battle grounds or groups. if he raids, check that too.
cpu clock speed is the most important thing, as long as you have more than 2GB of ram. a quad core will only help by 10%, overclocking is the real factor.
turn on higher settings in every place except shadows and you should be able to enjoy the game, even though some areas will be 20fps, most should be 60+
Manicdan is offline   Reply With Quote
Old 01-11-2010, 10:59 AM   #47
Piotrsama
Piotrsama's Avatar
That's a great tip.
You can see if you get good framerates or not. Because, if you do get high framerates, then... it's a lag/latency problem.
Maybe try to play on a server that is closer to your physical location?
(Meaning: Don't play on a European server if you are American, and vice-versa).
Old 01-12-2010, 07:57 AM   #48
mr2sw21
I remember when I play fallout3 with my PC it plays really smooth and I think I turn everything to high except no AA
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-12-2010, 07:58 AM   #49
mr2sw21
Well thanks all, I guess you all are right about WoW, cause I just got a new game Dragon ago: origin and I have set everything to high with 8aa but everything still smooth so far. May be it just because I am not in a big city yet or it is simply not a online game ^_^
Cheers,
__________________
Q9450 w/120 extreme
Maximus II Formula
2x 500 gb SATA
CM 590 Case
Old 01-12-2010, 10:12 PM   #50
vengance_01
Apply this fix for WoW. WoW Fix Second post follow the instructions. Cut my ping by alot and help stabilized my pings. Also don't max out shadows. I run WoW at 1900x1200 max everything expect for shadows as it kill performance. I also run V-sync as I hate screen tearing.
__________________
Desktop:
Antec 300
Foxcon A7AD-S 790GX
8GB Gskill PC-1066@5/5/5/12
PII X940 BE @3.6GHZ
Sunbeam Core Contact
2x 640GB in Raid 0+1
4870 512MB@800/1000
Vista Business 64bit W/ SP1
vengance_01 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
