XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 01-07-2010, 07:31 PM   #76
haylui
for xeon or i7?
don't think i7 could do MPU
__________________
RIG 1:
AMD PHENOM II X3 720BE (unlockable into quad core)
batch no.: 0906 FPMW
ASUS M4A785D-M PRO
THERMALRIGHT ULTRA 120 eXtreme
TEAM ELITE DDR2 800MHz 4GB KIT
XFX HD4650 512MB DDR3
Maxtor 6Y080L0
WDC WD2500KS-00MJB0
new: OCZ ModXStream Pro 600W
haylui is offline   Reply With Quote
Old 01-07-2010, 08:33 PM   #77
H2O
H2O's Avatar
Originally Posted by Tobit View Post
Says who? Do you have one? No. Low profile doesn't automatically assume water cool only. Plus, the person I quoted was probably referring to the pics of the board lacking heatsinks.. so don't say no to me sir. The benching picture was not done by EVGA.. it is not a final board.
Ok, I made a simply reply to your response, no need to get all defensive.
No, I do not own the board, and I know that it is not the final version, but I still think that it will be very difficult to come up with a heatsink design to sufficiently cool the 3 very hot chips without interfering with the PCIe slots. And odds are, if you have $450-$550 to spend on a motherboard, $2000 to spend on CPUs, and at least $400 to spend on RAM (not to mention the large/multiple PSUs, large case, GPUs, etc.), an additional $150 for a full cover watercooling block would be peanuts.
__________________
Regards,
Chris
Yes, I'm proud of my 0.4 points.
Core i7 920 3931A318 4.4GHz 1.375vcore | EVGA X58 Classified E760 | EVGA GTX470 1280MB | Corsair Dominator GT 7-8-7-20 1688MHz | Heatkiller 3.0 CU and Feser xChanger 480 | Seasonic M12 (Soon to be replaced)
H2O is offline   Reply With Quote
Old 01-07-2010, 09:35 PM   #78
LardArse
Moderator
LardArse's Avatar
Originally Posted by miahallen View Post
Very nice Peter...you've gotta be in geek heaven, working for a company that lets you dream big, and then bring your dreams to reality...this thing is truly a masterpiece
I really am looking forward to seeing more. I'm also very curious about the GPUs you were benching with...what were they?
thanks, its something fun right, kinda a next step? the gpus arent what you think they are so sorry to disappoint you there
LardArse is offline   Reply With Quote
Old 01-07-2010, 10:00 PM   #79
Hondacity
Hondacity's Avatar
do you have drivers that support quad 295s(are they 295s?) now?
this board rocks
retail around 800$?
__________________
Hondacity is offline   Reply With Quote
Old 01-07-2010, 10:21 PM   #80
miahallen
World Champion - IRONMODS
miahallen's Avatar
Send a message via MSN to miahallen
Yes it is the next step...my question is...what's the NEXT step?
I didn't think so...with only a single SLI bridge connection and all
__________________
THE POST COUNTER IS NOT AN INTELLIGENCE METER!
Ever thought about overclocking competitively? If not, you should! It can be cheap, and is a lot of fun!
It doesn't matter if you've never run a benchmark before in your life, have ancient hardware, and are on entirely stock cooling.
CHECK OUT THE "BENCHMARK BUFFET" AND GET STARTED HERE!
Trying to OC your CORE i3/i5/i7 ??? CLICK ME!
www.ironmods.com
Heat
miahallen is offline   Reply With Quote
Old 01-07-2010, 10:31 PM   #81
LardArse
Moderator
LardArse's Avatar
aint that obvious? a Motherboard to house your case in.
Old 01-07-2010, 10:42 PM   #82
miahallen
miahallen's Avatar
__________________
www.ironmods.com
Heat
Old 01-07-2010, 11:22 PM   #83
rintamarotta
rintamarotta's Avatar
Originally Posted by Sadasius View Post
2 X Ultra 1600's should power this up with some cards no problem. Just use a adapter to use both PSU's and make sure they are plugged into separate household power loops. I am thinking of a custom case for this monster.
16A fuse in 230v, hmm 3680W.. 1 single household power loop is enought and leaves room for about 480watt's for screens etc and this system would not use 3200watts anyway, i think max about 2000-2400watts needed witch makes shure single household power loop is enought for everything i need
EDIT : oh wait, you're from usa, 110v grid right? that makes sense 2 separate loops..
__________________
::: Desktop - Intel :::
Intel Core i7 975EE @ 4.5Ghz
EVGA X58 SLI Classified
12Gb (6x2Gb) TeamGroup Extreeme Dark DDR3 2000MHz (7-8-7-20)
2 x 64Gb Kingston SSDNow E-series (Intel X25-E), Raid0
2 x 2 TB WD Caviar Green, 3.5", SATA II, 64 MB, "IntelliPower"
2 x Sapphire Radeon HD5970 + PoV GeForce GTX285 for PhysX with modded drivers.
Thermaltake Toughpower 1500W PSU
CoolerMaster Cosmos 1000 Black Label
Windows 7 Ultimate x64
::: Dekstop - AMD :::
AMD Phenom II 965BE @ 4Ghz
MSI 790FX-GD70
4Gb G.Skill Trident DDR3-2000 F3-16000CL9D-4GBT
2 x 80Gb Intel X25-M G2
1.5Tb Samsung EcoGreen F2
Gigabyte Radeon HD5870
Thermaltake Toughpower 1000W PSU
Thermaltake Element S
rintamarotta is offline   Reply With Quote
Old 01-07-2010, 11:31 PM   #84
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
Originally Posted by N19h7m4r3 View Post
Weird format as in it's longer down then E-ATX, meaning I need a new chassis, the same with those 6pin power ports.
Supermicro will easily win over this for me since I get what I can use and get some of the best Reliability around.
Also SLI does with without nf200, as been proven before.
ye, but you cant get 4 gtx285 cards working in quad sli if there are no nf200 between them
formats... yeah... that is a bit odd... but then again, whoever wants this thing is not going to worry about the format at all so i think its not a problem to go for a custom standard...
so itll basically pull as much as a big water boiler or vacuum cleaner, but itll get you crysis in 3d on a huge display... now that IS something i can see people with enough cash getting interested in
saaya is offline   Reply With Quote
Old 01-08-2010, 12:03 AM   #85
rintamarotta
Well, my vacuum cleaner takes 1200Watts, close to same amount my current i7 rig takes power.
Boiler tough in my house takes around 4000watts that is running trought 3stage power each line going trough 16amp fuse thats 3680watts per-line but its spread evenly to all power lines, even tough that boiler is not active 24/7, if it would then my power bill would be astronomical .
Houses main fuse 25amps, thats about 5700watts per line .
I only wish ATI would make crossfire support for 6 or 8-gpu's (4xHD5970 or 3xHD5970 + GTX285 for PhysX) that machine would be beast.
__________________
MSI 790FX-GD70
Old 01-08-2010, 01:35 AM   #86
N19h7m4r3
N19h7m4r3's Avatar
Send a message via MSN to N19h7m4r3
Originally Posted by TheKarmakazi View Post
This board isnt trying to steal market share from SM. lol
Never said it was.
But why should I pay so much for this that needs a specialised PSU and chassis when I can get a SM board that's basically the same.
SM boards can OC as proven by Particle and his 6core cpus running nice and high.
So in the end like I have stated before there will be a place for this, but the people buying it obviously don't have money as an issue or reliability since it doesn't even use ECC.
So my opinion stands that this just isn't a great board atm, but I'm sure someone will buy it/recieve for free and clock the hell out of it since they'll probably also be getting that 2500W PSU it might need
__________________
N19h7m4r3 is offline   Reply With Quote
Old 01-08-2010, 02:11 AM   #87
s0lid
Great 93.
s0lid's Avatar
Send a message via MSN to s0lid
Yea every other than LGA1366 boards OC from SM, proven by jcool and movieman.
__________________
WTB: ALR 6x6! Hexa socket Pentium Pro system!
You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
[22:53:09] [@Jaco-XS] i'm gonna overclock this damn box!
--->Blog<---
Main rig: Intel and ATI with ZOMGWTFBBQ Overclocks.
s0lid is offline   Reply With Quote
Old 01-08-2010, 02:20 AM   #88
Expat GriZ
Xtreme I am
Expat GriZ's Avatar
Send a message via Skype™ to Expat GriZ
Well, I for one can't believe the negativity shown towards this new product. Not enough of this, doesn't support that, too much power, won't fit in my case... etc. etc. blah blah blah. This is XTREME SYSTEMS and this board represents a tremendous advancement that incorporates some outstanding features, progressive ones at that which will push the limits and open doors for newer and better products down the line. It might not be for everyone, deal with it.... nothing ever is. Hats off to Shamino and the eVGA team for even attempting to bring this board to market. When it does arrive, I for one WILL be purchasing it, and I WILL save up for processors to put in it, and I will enjoy the heck out of it.
Sorry for the rant, but come on folks.....we have something here which is new and exciting.....ENJOY IT!!!!
__________________
____________________________________________
More & more very expensive, quickly obsolete parts!!
Expat GriZ is online now   Reply With Quote
Old 01-08-2010, 04:33 AM   #89
Mabyboi
Xtreme Cable Management Freak
Mabyboi's Avatar
why in gods name would the sata ports not be 90degree?... WHY?!
__________________
Blood(Rage) shall be spilt
Intel Core i7 | Enzotech Sapphire
Sapphire 5970 | Koolance AR597
Foxconn BloodRage | BloodRage Waterblock
OCZ Platinum 6gb DDR3 | GTX 480 QUAD rad
Corsair HX1000W | MCP 655
Silverstone TJ-07 | FrozenQ T-Virus Res
Intel X25-M G2 SSD 80GB | Primochill UV Red Tubing 1/2"ID-3/4"OD
WD 1TB Black | Distilled Water
I also have a Macbook Air (waiting for 2010 model)
Wanna See?
You best be Crunching and Folding/GPUgrid'ing!
Mabyboi is offline   Reply With Quote
Old 01-08-2010, 06:39 AM   #90
Sadasius
Tygon Warrior
Sadasius's Avatar
Yup thinking the same thing here. Kick that damn IDE plug off of the board and place the 90 degree sata's there.
Sadasius is offline   Reply With Quote
Old 01-08-2010, 06:46 AM   #91
Buckeye
Buckeye's Avatar
Originally Posted by H2O View Post
if you have $450-$550 to spend on a motherboard.
I have a feeling that the MB is going to be a lot more than that. Shoot my Limited Edition Classy when it first came out was almost $500 shipped to my door.
__________________
Jinu 2 Stage Cascade
http://www.youtube.com/watch?v=-zDu-Xgt400
Phantom LN2 Pot - First Encounter
http://www.youtube.com/watch?v=dLo7Dr_kR2U
How I cool my benching lab
http://www.youtube.com/watch?v=PLgwW...eature=related
Buckeye is offline   Reply With Quote
Old 01-08-2010, 07:00 AM   #92
LardArse
Moderator
LardArse's Avatar
just to be tidier right? its not gonna block any long VGAs even in current position
Old 01-08-2010, 07:19 AM   #93
H2O
H2O's Avatar
I think that it was stated in the other thread that at extreme overclocks, the PCIe frequency is too fast for SATA drives to handle, hence the IDE port.
__________________
Regards,
Chris
Old 01-08-2010, 07:21 AM   #94
Don_Dan
Don_Dan's Avatar
Send a message via ICQ to Don_Dan
And that's why I wouldn't consider buying a board without an "outdated" IDE plug.
__________________
Intel E8600 // Gigabyte GA-EP45-UD3P rev 1.0 // Club 3D CGNX-G882DDC // Thermalright Ultra Extreme 120 Black // Western Digital Caviar RE WD1600YS // Thermaltake Toughpower 750W // Lian Li PC-7B PlusII // Samsung 931C
RAM: 2x1GB Mushkin Blackline 996600, 3x2GB Mushkin Redline 998750, 2x2GB Corsair Dominator GT 2000C8, 2x1GB Cellshock 1800CL8, 2x1GB Cellshock 1866CL8, 2x2GB OCZ Blade 1066 CL5 LV, 2x1GB OCZ Titanium Alpha VX2, 2x2GB Mushkin XP2-6400 996561, Mushkin XP2-8500 996562, 2x1GB Patriot 6400 CL5, 4x512MB Corsair 8000UL, 5x512MB Corsair 5400UL, 2x1GB Corsair Dominator 6400C4D, 1x1GB Corsair 6400C3, 1x1GB Corsair Dominator 8888C4D, 2x1GB Super Talent T1000UX2G5, 2x1GB G.Skill 6400 HK, 2x1GB G.Skill 6400 HZ, 2x1GB Crucial Ballistix 5300, 2x1GB Crucial Ballistix Tracer 5300, 2x1GB Crucial Ballistix Tracer 8500, 6x1GB Crucial 10th Anniversary 5300, 2x1GB Crucial Value 6400 CL5, 2x1GB FSC Value 6400 CL5, 2x1GB Cellshock 1066CL5, 2x1GB TeamGroup Xtreem 5300 CL3 and 2x1GB TeamGroup Xtreem 8500 CL5 cooled by Corsair Dominator and Dominator GT Airflow Fan
Don_Dan is online now   Reply With Quote
Old 01-08-2010, 07:40 AM   #95
zalbard
I am Xtreme
zalbard's Avatar
Send a message via MSN to zalbard
Looks good.
Do you have any early screens with overclocking attempts? Or is it still being tested with stock settings?
zalbard is offline   Reply With Quote
Old 01-08-2010, 07:59 AM   #96
crash5s
Agreed. I also still love my floppy port!
__________________
Silverstone TJ-09, AMD Phenom II 940 BE, Asus Crosshair II formula, 4gb corsair 6400c3D, 8800 GTS SLI, PC P&C 750, ocz vertex SSD, ocz solid SSD, 2x seagate 1tb, 2x DVD-RW, HT omega-clario +.
Cooling, swiftech MCR320, swiftech MCR220, swiftech MCR120, OCZ hydroflow, 2x EK FC GPU, ddc 3.2, EK res, 3/8 ID tubing, crap load of delta and panaflow fans.
crash5s is offline   Reply With Quote
Old 01-08-2010, 08:18 AM   #97
sethk
I bet this board gets OEM's by the e-Peen specialty vendors like Maingear, Falcon, etc. looking to get mainstream reviews which say fastest PC evar. (I'd mention Alienware and Voodoo in that list, but who knows what their corporate overlords will permit.)
sethk is offline   Reply With Quote
Old 01-08-2010, 08:46 AM   #98
BatteryOperated
Send a message via Yahoo to BatteryOperated
Ignoring child-like mentality and e-peen, why would anyone buy this?
AMD's Maneralo platform is due this quarter with Magny Cours followed by Thuban sometime later.
Right now, I am picture 2 or 3 people jumping up and down whilst holding their bodies in a rigid stance; no bending of the knees as one would normally have. "heh heh heh it overclocks massive heh heh heh" "but fellas, the board is not a good design." "LOLZOZLZ STFU!!!"
BatteryOperated is offline   Reply With Quote
Old 01-08-2010, 08:49 AM   #99
zalbard
I am Xtreme
zalbard's Avatar
What do you know about the motherboard design anyway?
Old 01-08-2010, 08:57 AM   #100
s0lid
Great 93.
s0lid's Avatar
Take a little look at Xtreme teams forum, there's this DC asylym called World Commynity Drid forum, i know a hand full of people who are ready buy that board right now if it were in stores
Originally Posted by haylui View Post
for xeon or i7?
5000-series xeons only:
Originally Posted by trueg50 View Post
I believe so.
The model Xeons that are built for multi-socket operation have I think 2 QPI links or something like that so they can communicate with the NB and with the other chip (and pull data from that chips RAM).
__________________
--->Blog<---
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
