After all these tests weve done Im wondering if anyone else got 4.6ghz validation on air or water??
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
was gonna go for it tonight when i was trying for 4.4ghz 3dmark06... couldnt get past cpu tests, what vcore and temps did you need for your high clocked 3dm06 runs?
i think 4.5 valid would be no problem with cold wisconsin winter air but 4.6 would be tough. i will go for it next few weeks, weather has to be juuuuust right
ps. anyone have a good aluminum cooler (or any non-heatpipe cooler) - my heatpipes were freezing last night within like 30 seconds of having pc hanging out the window, so i had to keep it partway inside the house to find a balance, once the cores got to 6c is about when the heatpipes would freeze and then it would just steadily rise and rise until i brought it mostly in the house. which means my lowest idle i can run with this heatsink is about 7-8c, and Wisconsin has so much more to offer than that
LEO!!!! amd phenom II x6 1100T | gigabyte 990fxa-ud3 . . 2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd sapphire ati 5850 | x-fi xtrememusic. . . samsung f4 2tb | samsung dvdrw . . corsair tx850w | windows 7 64-bit. ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . . lycosa-g9-z2300 | 26" 1920x1200 lcd .
I have 4551 MHz (ambients was 13 C )validation with air....More is not possible,maybe with luck i can hit 4560-4570....I know only, 4600 MHz "easily" hit Chew with AIR, think, if he want it, can make validation with air about 4650-4700 MHz
ROG Power PCs - Intel and AMD
I had it at 4.6 the other night and tried to validate but i think i did not check the argeement box when installing CPU-Z. Was unable to validate. But i ran SuperPi 1M at 4580 which was much better for me than validating at 4.6
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
+200 MHz diferent Zeus (my AIR and your watter system ). Nice.
4.6 all cores air.....4.7 all cores water with NB cranked on both and optimized ram.......that said I can validate alot higher if only trying to suicide a valid.
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
its very hard with max RAMs and NB, i have not so high NB, of course. Think, u can hit about 4700 MHz with tweaking AIR (lower RAms+NB), know, AIR is for u so boring :-)...
these are some sick numbers, i thought C3 was good for 4200-4300 normally, not 4500
we talking only about max. validation ...
Here is my score with Big Typhoon... It is very cold outside, -1°C and I open the window and freezed rig and myself too...
Maximum performance overclock on air
Joining the 4.6GHz air club soon with lower nb and ram
Intel i7 3930K C2 4.6GHz 1.33V
MSI Big Bang - XPower II
Noctua NH-D14
G.Skill Ripjaws Z 4x4GB 2133MHz
Sapphire HD 7970
Mushkin Chronos 120GB, 2X Seagate 1TB
Corsair AX 1200W
Cooler Master HAF 932 Advanced
cele303, nice mem speed 1870
Vishera 8320@ 5ghz | Gigabyte UD3 | 8gb TridentX 2400 c10| Powercolor 6850 | Thermalight Silver Arrow (bench Super KAZE 3k) | Samsung 830 128gbx2 Raid 0| Fractal case
Nice number Cele on air
MSI 790FX GD-70
965 BE C3
4Gigs Corsair GTS 2000 Cas 8
Noctua U12P Push Pull
Hmm I should probably try some cold air or water testing but I think I have to wait another month for the cold to "kick" in around here.
heatware chew*
WOW sick ram Cele, nice speed on that, R the 1866 cas7 binned better then the 2000 cas 8? mine ran 1700 all night memtest stock volts 6-6-5-18 trc 24, im working on droping my cpu voltage b4 i go any further tho, stock cooler is just JUNK (as to b expected....will make me appreciate my soon 2 b water cooling that much more!)
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
I tried last weekend and 4620 was ok, but I didnt to validation. Ambitent was 5C.
for you guys C3 stands for Cold Chip Cooking
wow 4.7ghz on air is impresive
www.vitesse24.de
www.vitesse24.de
C2Q q6600 3.3GHZ @ 1,184V
4,5GHZ@ 1,52V ( 9* 500 )
Corsair Dominator 10000 2gb, 8888 2gb, 9136 1gb
this my new max AIR
To bad i dont have any 965BE C3 anymore becuse i have -29c outside now... and i´m not afraid to put the stuff outside , i have done that before and i will do that again.
Maybe i was hoping to much for some x-mas gift
"I have in my left clenched hand a C3 965. I have in my right a C2 965"
Its about -12 deg c here atm and it just got dark a few hrs ago so only going to get colder tonight, (and for the next few months) once i get something decent to cool my C3 ill b in here, hoping to get my water cooling sooner b4 latter
Dragon
Opty 175 Rig
AM3 Rig
DFI NF4 BIOS Guide
AMD 1090T@4.0ghz
12gb Gskill 1300mhz
HIS HD5970
4.61ghz water
Wow, you guys have real cold wheater, here in the Netherlands it's around 0ºC atm, waiting for the temps to drop a couple of degrees below zero.
If i can do 1M at 4580MHz (four cores of course), what will be my max validation frequency? 4650? 4700?
I have no idea, never done validation actually.
ZEus: i had ambients about 11 C yesterday.
my run superpi with aircooling was at 4410 MHz (NB 3000+ MHz). So, max validation i had 4570 MHz (more than 150MHz up, of course, for higher validation u must down NB clock about 1800-2400MHz, it help you about 50-70Mhz up for validation, RAM downcloks a bit too)
thanks guys, ram is insane and Gigabyte is awesome, C3 rules, rig is the beast overall...
FireDragon, I don't know, I think that my sticks (3x2GB 1866 7-8-7-20 1.65V) are the same as 2000 C7 (3x2GB 2000 7-8-7-20 1.65V), this is my i7 920 test with advertised speed and timings, so far 1900 7-8-7-20 1T 1.65V no problem...
http://img121.imageshack.us/img121/1576/kanta.jpg
Noctua NH-D14
Sapphire HD 7970
Corsair AX 1200W
