Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: i7 Batch No# Overclock Database
    Xtreme Mentor
    Aug 2008
    Australia
    This will be a self updating database of i7 overclock results.
    Doing it manually is too arduous so this will make it much easier for me and everyone else. This will keep them all together instead of threads trailing off and no longer being updated by the OP.
    Please post a screen shot of the settings/OC you upload in this thread - you must show a screen of at least a 1 - 2 hours Prime 95, 1 - 2 hour OCCT or Linx 5 - 10x Max Mem run. If you do not, I will remove your data from the spreadsheet. I'm Please respect the submission rules, this will help everyone. You can fill in the form first then post a screenie later though.
    Ensure you state your FULL BATCH NUMBER, IE: 3xxxAxxx - just writing the first 4 digits and letter is useless.
    If you use different cooling for your max OC, please state the cooling type in parentheses after the 24/7 OC cooling type. For example: Air (LN2 Max)
    Fill out the following form with your information. Your information will be added to the spreadsheet.
    i7 Batch No# Overclock Form
    View or download the spreadsheet here:
    i7 Batch No# Overclock Result Spreadsheet
    This thing can just take care of itself now, so just download/view the spreadsheet to see everyone's OC's as they are added.
    To download the file, Click FILE then select DOWNLOAD AS then choose the format you want.
    EDIT 1 - Form updated to include fields for socket type (s1156 or s1366), Vtt (QPI), BCLK and Multiplier.
    Jul 2008
    heres mine... fully stable max setting 10 runs... sorry for the double pic
    Attached Images Attached Images
    Jun 2009
    Added myself to the spreadsheet & a few screenies..
    Xtreme Mentor
    Jan 2009
    Oslo - Norway
    Xeon W3520 (#3848A352) @4.41GHZ(210x21) 1.32v On air.
    VVT=1.23/1.26v (BIOS/load)
    Uncore x18 (3780MHZ)
    3x2GB @1680MHZ 7-8-7-21 1.65v
    1 hour OCCT stable
    5-run LinX stable
    HyperPi32M stable
    ► ASUS P8P67 Deluxe (BIOS 1305)
    ► 2600K @4.5GHz 1.27v , 1 hour Prime
    ► Silver Arrow , push/pull
    ► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
    ► GTX560 GB OC @910/2400 0.987v
    ► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
    ► CM Storm Scout + Corsair HX 1000W
    ► EVGA SR-2 , A50
    ► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
    ► Megahalem + Silver Arrow , push/pull
    ► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
    ► XFX GTX 295 @650/1200/1402
    ► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
    ► SilverStone Fortress FT01 + Corsair AX 1200W
    Jan 2003
    Norway
    W3520 3848a352
    Adding mine, W3520 3848A352.
    Water cooling, Laing DDC, HK 3.0, PA120.3 + TFC Xchanger 360.
    Ambient/Rad air intake temp 22.1 degrees.
    Without HT:
    Xtreme Mentor
    Aug 2008
    Australia
    Nice work, keep them coming.
    Even if you have posted before somewhere else, post it up here so we can finally have everything in one place
    *Rules updated and relaxed somewhat:
    Tests now accepted:
    OCCT 1 - 2 hours, Prime 1 - 2 hours, Linx 5 - 10x max mem.
    Jan 2007
    Michigan
    What about Orthos, Intel Burn Test, etc.... What about LGA 1156 cpus, are those ok? It would be nice to compare those as well.
    Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
    Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
    Intel 4.5GHz LinX Stable Club
    Xtreme Mentor
    Aug 2008
    Australia
    Orthos as far as I know, only loads 2 threads - prime 95 v25.9 has 4 or 8 threads as required and is identical to Orthos in stress level - Orthos is just Prime95 with a sexy GUI.
    Intel burn test is acceptable as long as 'max' stress is used, 'normal' is way too easy.
    This spreadsheet will be s1366 only so as to keep things distinct.
    Jan 2007
    Michigan
    Quote Originally Posted by CryptiK View Post
    Using a command line switch or batch file will load four, eight, (or whatever you want) threads. Several people use this and it works well so that's why I mentioned it...
    Isn't the standard much better than one to two hours of prime?
    Maybe this thread would be better served having both sockets together? This would help deduce which chips perform "better". Even if better is not higher clocks, but maybe lower heat, etc. I think having a socket type delimiter would be enough distinction for most folks. Unfortunately, with all the other 1336 i7 thread out there, without including the new chips this thread might fall by the wayside pretty quickly.
    Xtreme Mentor
    Aug 2008
    Australia
    Quote Originally Posted by Vinas View Post
    I wasn't aware people do that with orthos. I guess its fine so long as there's as many threads as cores/HT cores (HT on = 8 threads, HT off 4 threads).
    Linx vs prime stability is a contentious issue. In mine and other experience Linx can pass, then fail Prime, sometimes in a lot less than 2 hours. For others its the reverse. I really just want some proof the OC's are somewhat stable, so a decent length of time for any real stress testing program on max stress should be fine for that purpose.
    After some consideration, I agree I'd like to see a database for s1156 CPUs too, and I think this self updating format is the best way of doing this. I have added a socket designation field to the form, so s1156 CPUs can be added also. Thanks for the suggestion.
    Jan 2007
    Michigan
    May 2009
    My brand new i7 setup watercooled by Dtek Fusion V2 and Pa120.3 temps are just as load finished load was 70-75, Getting new block soon hope to see improvments and sorry about the 50minutes i have a house open and had to leave.
    Xtreme Cruncher
    May 2007
    Conroe, Texas
    i7-960 batch 3938A611, foxconnflaming blade gti, water cooling heatkiller block.
    Sep 2006
    Salt Lake City
    Batch #3910A372. This is on air. Noctua NH-U12P With 2 120X38MM 97CFM Delta's
    CPU 1.368V
    QPI 1.35V
    PLL 1.82
    IOH 1.18
    Asus Rampage IV X79 Extreme 1305
    Intel Core i7-3930K Processor @ 4.8GHZ 1.45V
    G.Skill Ripjaw 1866MHZ 4X4GB 9-10-9-28
    EVGA SC GTX 580 SLI 880/2200
    Corsair H100
    Coolermaster HAF932
    Corsair 1000W HX Power Supply
    Jul 2009
    Just got this. Could pass wPrime and SuperPi but linx fails after 5 passes or so. Under 80c load as well in LINX!
    Jun 2007
    5 ghz max OC on water, 1.58v, ambient 18C
    4.5 ghz, stable prime 11+hrs, linx max mem 20+ on water, 1.39v cpuz load, ambient 23-24C
    3847B005 i7950
    http://valid.canardpc.com/show_oc.php?id=707206
    Xtreme Mentor
    Aug 2008
    Australia
    Just a reminder to add your overclocks.
    We are the forum with the least number of properly documented overclocks! We are supposed to be a leader in terms of overclocking but we are not looking very good at the moment.
    Come on guys, get your OC entered!
  18. #18
    Jun 2005
    I already submit my result and here is my screen:
    Core i7 920, Asus Rampage 2 Extreme , 6GB OCZ reaper 15000, EVGA 260GTX SSC, X-Fi Xtremgamer
  19. #19
    Xtreme Mentor
    Aug 2008
    Australia
    Nice work there ^.
    It's important that as many people as possible post no matter what you overclock is, especially since these newer batches of CPU's seem to be more hit and miss.
    The more information we can get the better.
  20. #20
    Xtreme Cruncher
    Oct 2007
    I'll hit this
    W3520 Batch 3945A906:
    I've had 3 i7-920's (all in the 39XXX range) and this Xeon. The w3520 is the best chip by far; I do believe the urban legend that Intel figured out how to bin the chips better and Xeon's are better than i7's. I think Intel figured out the better binning after 2008 because in '08 it didn't seem to mater if the chips were 920's or w3520's.
    4.2GHz 24/7
    4.5GHz run
    Cooled by water and cold weather, over-volted all settings because I didn't have time to tweak the voltages to their min's.
  21. #21
    Xtreme Cruncher
    Oct 2007
    If possible I would suggest to make the spreadsheet sort by batch number instead of date the data was entered. It is a spreadsheet all about batch #'s.
  22. #22
    Xtreme Mentor
    Aug 2008
    Australia
    Quote Originally Posted by trn View Post
    Since google docs is limited in it's abilities, I can't make it auto-sort by batch number. It also causes issues if I move the timestamp column, so it has to stay where it is. However I can manually sort it by batch number so they go in ascending order (oldest batch first). Done now.
    Make sure you post your full batch number! ie: 3XXXAXXX
    3945A is not a full batch number and is essentially meaningless.
    Also can we get some image cropping & resizing happening so there's no need to scroll side to side? Surely we all know how to use photoshop
  23. #23
    Xtreme Cruncher
    Oct 2007
    Figured something like that might be the case. Sorry about my incomplete batch #. I realized my error after I reopened the spreadsheet and saw mine vs everyone else's.
    3945A906 is my full batch number.
  24. #24
    Xtreme Mentor
    Aug 2008
    Australia
    Not a problem I have edited the spreadsheet to reflect that. Thanks for your contribution, and good suggestion about sorting by batch number. It is definitely easier to read & find a batch now.
  25. #25
    Xtreme Cruncher
    Dec 2004
    South Carolina
    Intel i7 920 Batch # 3938B024
    Speed : 4410Mhz Ht on
    VCore : 1.3250
    Vtt : 1.355
    Cooler : Thermalright Venomous-X
    Prime95 1 hour / Cpuz / Real Temp
    Samsung 42" LCD/Antec 1200 Case/Corsair 1000W PS/ Gigabyte GA-X58A-UD7 / Intel I7 990X 3.47 @ 4.5 / 3 x RX360 rad /Apogee Xt /2 x 128gb Patriot Torqx M28's @ Raid 0/ WD 600Gb VelociRaptor / Kingston Hyper X 12Gb (6x2) DDR3 2000/ XFX DD HD 7970
