Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 101
Thread: mcp350 to 355 mod?
    May 2008
    San Diego
    mcp350 to 355 mod?
    I heard that the mcp350 could be modded with a little soldering to perform like the 355... Still possible?
    Been looking at getting this:
    http://www.performance-pcs.com/catal...oducts_id=2539
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    AFAIK,
    Circles SucQ!
    May 2008
    San Diego
    nice, saves me $15
    another little question. How much does a Y fitting restrict flow? Im thinking of using it as a fill line placed right before the inlet of that pump.
    May 2008
    Not much, but I would think a T should be better. I wouldn't worry about a single Y or T, though.
    May 2009
    Scotland
    I just done this mod to my 10w Laing DDC and it worked for me, I haven't got round to fitting the pump into my system yet, but I have tested it in a small loop outside my case, and it seems to be just fine..
    Very simple mod to do, I managed it, and I'm hopeless with a soldering iron!
    Core i7 D0
    Asus Rampage II Extreme
    6GB Corsair Dominator GT 1866MHz
    SLi'd GTX280s
    Corsair HX850
    Custom Silverstone TJ07
    Custom Watercooling
    Logitech G15 Keyboard
    Logitech G500
    Roccat Kave 5.1
    May 2008
    San Diego
    Great Should be placing my order today.
    Another question lol. Which is a better top?
    http://www.performance-pcs.com/catal...ducts_id=24824
    vs
    http://www.performance-pcs.com/catal...ducts_id=22700
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    did that, just the other way with my ddc...
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
    Dec 2006
    Riga, Latvia
    EK X-top V2 is slightly better
    About pump I havent heard that swiftech would be already distributing DDC-3.15 and 3.25 under same names mcp350 and 355 so that one still should be rebranded DDC-3.1 and 18w mod would work fine!
    May 2008
    San Diego
    Hey guys just got my pump and it looks like this:
    Where do I solder?
    May 2008
    San Diego
    Like this?
    Maybe I got a DDC3.15? It doesn't match Martin's pic.
    I am Xtreme
    Jun 2007
    What does your impeller look like?
    Circles SucQ!
    May 2008
    San Diego
    It's blue.
    I am Xtreme
    Jun 2007
    I'm gonna say that you got a 3.1 with a newer PCB on it. It could be that Laing is using the same PCB for both the 3.x and 3.x5 models with just some slightly different components/better windings. Last I heard, Swiftech hadn't gotten any 3.x5 yet and that they (3.x5's) actually had a 2 tone impeller.
    For your original question, it looks like you'd need to move the yellow wire over to the left as you suggested.
    Circles SucQ!
    May 2008
    San Diego
    Thanks waterlogged
    Should I just bridge them or actually move the wire?
    I am Xtreme
    Aug 2008
    Quote Originally Posted by Waterlogged View Post
    how sure are you on moving the yellow cable?
    I am Xtreme
    Jun 2007
    Quote Originally Posted by Hondacity View Post
    Sure enough that I would do it myself if I had one.
    Circles SucQ!
    I am Xtreme
    Aug 2008
    the pmp400 has the same configuration as his 350...
  18. #18
    I am Xtreme
    Jun 2007
    Now you got me wondering if his pump is mislabeled. Did you ever get to head pressure testing the pmp400 after your flow tests? That may very well be one of the few true ways to tell the difference.
    @ Burninator, does it appear that there is another label underneath the Swiftech label. . .can you peel the Swifty label off and post what the other label says?
    Circles SucQ!
  19. #19
    May 2008
    San Diego
    There was another label but nothing saying pmp400...
    Guess it is a DDC3.1?
  20. #20
    I am Xtreme
    Jun 2007
    pmp400 is what Koolance calls the 3.25, at least, this is what we've been told.
    As for your dilemma, I'm suddenly not so sure anymore.
    Circles SucQ!
  21. #21
    May 2008
    San Diego
    So if I were to re-solder the yellow wire on the left... any ideas on what would happen if it wasn't the right thing to do? Boom headshot to my pump?
  22. #22
    I am Xtreme
    Jun 2007
    That could be one outcome.
    Myself, I'd still go ahead but after some careful observations of the PCB and probably some poking and prodding with a DMM. I've now torched enough hardware in my lifetime that it almost doesn't phase me anymore. The 3 I took the hardest were all DDC-2's, I still weep over losing them.
    Circles SucQ!
  23. #23
    I am Xtreme
    Aug 2008
    shoot 3.1s LOL...i'm checking my pm400s now...i'll poke the stickers off maybe there is a label behind it..
    curious is..the pcb layout looks so much alike...
  24. #24
    I am Xtreme
    Aug 2008
    burninator..
    could you take a pic of the entire pcb? include the ddc3.1 on the pcb
    thanks
  25. #25
    May 2008
    San Diego
    here you go
