XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 11-02-2009, 08:27 AM   #1
Clunk
Clunk's Avatar
Send a message via MSN to Clunk
Noctua Launch 140mm cooler
http://www.clunk.org.uk/news-stories...-unveiled.html
140mm fan in the centre and 120, fan at one end.
Clunk is offline   Reply With Quote
Old 11-02-2009, 08:29 AM   #2
Musho
Damn those fans are ugly. I wonder how it will perform though.
Musho is offline   Reply With Quote
Old 11-02-2009, 08:34 AM   #3
Manicdan
saw this in the water cooling section i think
its nice they offer compatibility, but they would really need to provide shrouds that prevent extra airflow from escaping (outside the fins on 120mm, within the fins on 140mm)
Manicdan is offline   Reply With Quote
Old 11-02-2009, 08:37 AM   #4
zalbard
zalbard's Avatar
Looks like IFX-14 ver.2, bound to fail IMO. But we will see.
Has 2 more heatpipes, though.
Also it will have just as retarded motherboard compatibility due to this huge ass heatsink.
__________________
Donate to XS forums
>> Join Intel 4.5GHz LinX Stable Club <<
Originally Posted by Mechromancer View Post
Bulldozer can't show up fast enough either. Bulldozer better live up to THIS: Image
It will either make history or make AMD history if it doesn't. Intel's thread count is getting higher than Fugger's bed sheets!
zalbard is offline   Reply With Quote
Old 11-02-2009, 08:42 AM   #5
Scubar
I am Xtreme
Scubar's Avatar
Dont see the point in using that 140mm. A 120mm will fit better and look nicer.
__________________
Gaming Rig
Case: Silverstone TJ-07 LCD: 32" Samsung A656 CPU: i7 920 D0 w/Swiftech Apogee GTZ Mobo: Foxconn Bloodrage RAM: 6GB OCZ Blade
GFX:
HIS 4870X2
w/EK Nickel/Acetal FC Block Power Supply: Corsair HX 1000W Sound Card: Auzentech X-Fi Prelude HDD: 60GB OCZ Vertex HDD: 2x1TB Samsung F1
Media Rig
Case: Zalman HD160XT+ LCD: 40" Toshiba XF355D CPU: Q9450 w/EK Supreme LT Mobo: Asus Rampage Formula RAM: 8GB Geil Black Dragon
GFX:
Gainward 8600GT SilentFX
Power Supply: Corsair HX 620W Sound Card: Auzentech X-Plosion HDD: 500GB WD Caviar Black
File Server
Case: Custom Built Torture Rack CPU: E8200 w/Ultra-120 Exterme Mobo: Asus P5QL-EM Ram: 4GB OCZ Platinum
GFX: Onboard Power Supply: Corsair HX 620W HDD: 250GB Seagate HDD: 2x1TB WD Caviar HDD: 2x1TB WD Caviar
Scubar is offline   Reply With Quote
Old 11-02-2009, 08:47 AM   #6
kamieldehond
hope the 120 and the 140 have the same airflow otherwise its a big fail
__________________
e8500 c0 - 4275MHz - 1,344 vCore
DFI UT P45-T2RS
4x1gb D9GMH
Ati HD4870
Modded HAF 932
Watercooled:
Heatkiller v3.0 cu - D-tek Fuzion GFX 2 - PA120.1 - PA120.2 - PA120.4
kamieldehond is offline   Reply With Quote
Old 11-02-2009, 08:57 AM   #7
lowfat
I am Xtreme
lowfat's Avatar
Two different fans w/ different CFM will work perfectly fine
__________________
i7 920 on single stage * EX58-UD5 - * 6GB @ 1620MHz * HD4550 * 80GB X25-M SSD * Enermax Revo 85+ 1050W * BD-ROM * (2) HDDVD-ROM * Silverstone FT01BW
Q8200 @ 3.2GHz * P5Q Pro* 4GB @ 915MHz * 9500GT * Auzen Prelude * 30GB Vertex * 11.5TB * Seasonic 420 M12-II * Silverstone LC17B * BD/HDDVD-ROM
lowfat is offline   Reply With Quote
Old 11-02-2009, 09:03 AM   #8
LagunaX
LagunaX's Avatar
Should have made the center fan black to reduce the fugly factor...
__________________
Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
Foxconn Mars
2 x2GB G.Skill Pi PC2-6400
Sapphire 5870 Unlocked
300gb Velociraptor
PC Power & Cooling 750w Quad Silencer
Coolermaster CM690
LagunaX is offline   Reply With Quote
Old 11-02-2009, 09:04 AM   #9
MpG
MpG's Avatar
Hard to say for sure, but looks like a pretty wide fin spacing - the restriction might not be too bad, especially with two fans at work. I like those silicone blocks that the 120mm fan is resting against. Better than skinny little strips a la TRUE, or the pins like the Vendetta 2.
__________________
i7 920 | Foxconn Bloodrage | GTX280 | Corsair DDR3-1600 2x3GB
MpG is online now   Reply With Quote
Old 11-02-2009, 09:17 AM   #10
PeterStoba
Send a message via MSN to PeterStoba Send a message via Skype™ to PeterStoba
Be interesting to see how two 120s and two 140s compare to the 120 and 140 combo...
__________________
PeterStoba is online now   Reply With Quote
Old 11-02-2009, 10:30 AM   #11
Helloworld_98
or three low noise 140's vs two high speed 120's assuming it can take a third fan.
Helloworld_98 is offline   Reply With Quote
Old 11-02-2009, 10:34 AM   #12
Sam_oslo
Sam_oslo's Avatar
Those 6 heat pipes in that configuration looks very promising. It's interesting to see if this can raise the air-bar with a few degrees. When can vi expect a test?
__________________
* DFI LP UT X58-T3EH8, R.A51 (BIOS 11/05)
* Xeon W3520 (#3848A352) @4.41GHZ(210x21) 1.32v
- 1h OCCT stable , 5-Run LinX stable
* Prolimatech Megahalems, 2xScythe Slipstream 1600RPM push/pull
* 3x2GB Corsair XMS3 1600MHZ CL7 (ver. 2.2) @2100MHZ 9-10-9-24 1.65v
- HyperPi32M stable
* XFX GTX 295 @684/1246/1476
* OCZ Vertex v1.41 30G + F1 750GB + 512MB RAMDisk
* Corsair HX1000W
* CoolerMaster Cosmos 1000, 5x120
* Samsung 24" 2493HM , Razer Lachesis , Logitech G35 Headset
* W7 RC1, 64bit
* 3DMarks P23095
Sam_oslo is offline   Reply With Quote
Old 11-02-2009, 10:36 AM   #13
dro
dro's Avatar
F-u-g-l-y
__________________
dro is offline   Reply With Quote
Old 11-02-2009, 10:50 AM   #14
Helloworld_98
it probably won't be that much better than an IFX-14, maybe 1 or 2C max.
Old 11-02-2009, 11:48 AM   #15
Sam_oslo
Sam_oslo's Avatar
2'C better would be good enough for me. I have changed several coolers just for that little 2-3'C-extra.
__________________
- HyperPi32M stable
* Corsair HX1000W
* W7 RC1, 64bit
* 3DMarks P23095
Old 11-02-2009, 11:58 AM   #16
Junos
First review (in German): http://www.overclockers.at/air_cooli..._nh-d14_211569
Junos is offline   Reply With Quote
Old 11-02-2009, 12:17 PM   #17
Helloworld_98
7C better on an i5 750 @4GHz than a NH-U12P, not bad, but not ground breaking either.
Old 11-02-2009, 12:21 PM   #18
zalbard
zalbard's Avatar
Originally Posted by Junos View Post
OK, this is pretty impressive.
If it actually is 6C better than NH-U12P, then it's as good as Megahalem. Or maybe even better!
It's way bigger, though...
The thing is, though... Need to compare those with similar fans. That would give more accurate results.
__________________
Donate to XS forums
Old 11-02-2009, 12:36 PM   #19
Sam_oslo
Sam_oslo's Avatar
I've been using Megahalem for a while now, and it is a great cooler. But considering those 6 heat pipes, the configuration of pipes, and up to 3 fans, then hopefully a few degree better than Megahalem is in reach,
It would be interesting to follow a few tests on this one.
__________________
- HyperPi32M stable
* Corsair HX1000W
* W7 RC1, 64bit
* 3DMarks P23095
Old 11-02-2009, 01:53 PM   #20
RSC
RSC's Avatar
Between this one and the Mega Shadow, my heart swings...
RSC is offline   Reply With Quote
Old 11-02-2009, 03:37 PM   #21
Blacky
Blacky's Avatar
I wish noctua got rid of that color scheme ~_~
__________________
Blacky is offline   Reply With Quote
Old 11-02-2009, 04:03 PM   #22
Manicdan
true, people who spend that much on fans, probably want to show it off, so color options are very important
Old 11-02-2009, 09:09 PM   #23
Computurd
Computurd's Avatar
I dont believe that the appearance of the fans is nearly as important as the function of the fans. That front fan has vortex notches, wondering if the center fan does as well? I have read about these vortex notches and it seems to improve the flow of air. That may have a very large impact on the performance of this cooler.
__________________
"Lurking" Since 1977
Computurd is offline   Reply With Quote
Old 11-03-2009, 12:41 AM   #24
Origin_Unknown
Xtreme Cruncher
Origin_Unknown's Avatar
no copper base
__________________
E8500 - G.Skill F2-8000CL5D-4GBPQ 4*2GB PC 8000 - DFI LT X38 T2R
Palit 8800GTS 640Mb - Lian-Li A71 w/ 6 * Noctua NF-P12 - Corsair TX750
Thermalright Ultra Extreme - HR03 - HR05 IFX *2
We'll Keep the Red Flag flying high - Because Man United will never die
Origin_Unknown is offline   Reply With Quote
Old 11-03-2009, 12:47 AM   #25
celemine1Gig
celemine1Gig's Avatar
Send a message via ICQ to celemine1Gig
Originally Posted by Origin_Unknown View Post
no copper base
Uhhhmmm, sorry, but just because it isn't copper-colored, doesn't necessarily mean that it is not made of copper. I highly doubt that they would use anything else than copper or silver on a top of the line heatsink like that. And as silver would make this thing super expensive, I bet that it is nickel plated copper.
So, don't just always go by the looks.
__________________
celemine1Gig is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
