XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 10-28-2009, 04:24 AM   #1
davidexD
davidexD's Avatar
I7 860 gbt ud4 trident help overclock!
i don't know if this is the right place to write this kind of thread. and this is the first time that i try to pump a nehalem configuration.
i need to reach 4 ghz on this configuration and i don't know where to fix on this bios
__________________
CM 690 Nvidia Ed. - I7 860 - EVGA P55 SLI E655 - Ybris Black Sun - G.skill ECO - HD XFX 5770 - Ezcool 750 watt
davidexD is offline   Reply With Quote
Old 10-28-2009, 07:50 AM   #2
K404
Wanna look under my kilt?
K404's Avatar
What CPU cooling you on?
Realistically you will need the vCore at around 1.32v. 190x21 you might be able to keep the VTT and PLL at stock. RAM multi at.... x4? (giving you just under 800MHz on the RAM...) start low on the RAM and work up when you have a base to work from. Timings at 800MHz... 7-8-7 should be alright
.......and welcome to XS!
__________________
Proudly using
Crucial Ballistix + G.Skill RAM
Xigmatek air & power
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
______
K404 is offline   Reply With Quote
Old 10-28-2009, 08:13 AM   #3
davidexD
davidexD's Avatar
thanks for the welcome, liquid cooling for the cpu the best italian waterblock, the trident ram are awesome reachs all kind of frequenchy so in not worried about.
i tried with just 1,32 1,34 1,40 ,145 but it doesn't want works. blue screen on the win 7 logo again and again.
__________________
Old 10-28-2009, 08:17 AM   #4
K404
K404's Avatar
Ah... just thought of something. I did 4GHz with Turbo disabled. If I enabled it, things stopped playing nice as part of the CPU is trying to run 4.4GHz or so. If you have Turbo enabled, try disabling that and E1ST. Your whole chip will still be running at 4GHz... plenty of power
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 08:19 AM   #5
davidexD
davidexD's Avatar
i've already disablead e1st and all the cstate and turbo too. thanks anyway.
__________________
Old 10-28-2009, 08:23 AM   #6
stasio
stasio's Avatar
G.Skill Trident model?
DDR3 memory run at 1600MHz should be multi x8.
__________________
Need a Gigabyte latest BIOS?
GA-P55-UD6 (F11c),Core i7-860 @ 4.2 GHz
G.Skill F3-17600CL8D-4GBPS @ 2210 (8-8-8-24)
XFX 9600GT,2xHitachi SATAII 500GB,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 7601.16562
stasio is offline   Reply With Quote
Old 10-28-2009, 08:26 AM   #7
davidexD
davidexD's Avatar
2000 cas9
__________________
Old 10-28-2009, 08:41 AM   #8
K404
K404's Avatar
Depends on BIOS. MSI cuts it in 2 to give "actual" MHz
Thats weird... if you've tried way higher voltages and it still wont even load Windows. Hmmm. Try VTT to 1.3-1.35v?
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 08:45 AM   #9
davidexD
davidexD's Avatar
but how can i get on vtt max? in a safe way.
__________________
Old 10-28-2009, 09:07 AM   #10
K404
K404's Avatar
1.30v should be totally fine
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 12:59 PM   #11
davidexD
davidexD's Avatar
it works thanks very much!!
__________________
Old 10-28-2009, 01:14 PM   #12
K404
K404's Avatar
So it was VTT holding you back? Glad you have some MHz now, lets see some screenies!
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 01:24 PM   #13
davidexD
davidexD's Avatar
and if i want for example reach 4,4 i must give much more vcore and much more vtt right? like 1,45 vcore and 1,40 or 1,45 vtt?
__________________
Old 10-28-2009, 01:44 PM   #14
davidexD
davidexD's Avatar
yes i reached 4 ghz but it's a bit hard to pass linx for only 1,3440 of vcore, i'm very newbie on this kind of sockets
__________________
Old 10-28-2009, 02:00 PM   #15
K404
K404's Avatar
4.4GHz stable might be dangerous to aim for. Both for chips temps and for the current draw through the socket 1156 isnt strong enough, theres a big thread in the Extreme overclocking section. Frozen chips at 4.9-5.1GHz (the ones suffering problems) are drawing ~ similar current to watercooled chips at 4.1-4.2GHz.
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 02:02 PM   #16
davidexD
davidexD's Avatar
i saw in a italian forum that a guy with my same configuration keeps 4 ghz with only 1,3440 where i can fix for save some volts? this bios for me is a total chaos!
__________________
Old 10-28-2009, 02:14 PM   #17
K404
K404's Avatar
Im using an MSI board, sorry I cant help you there
__________________
Proudly using
you sigged that?
why?
______
Old 10-28-2009, 02:16 PM   #18
davidexD
davidexD's Avatar
ok but thanks again for the vtt, i was going crazy for it!
__________________
Old 10-29-2009, 05:41 AM   #19
davidexD
davidexD's Avatar
can somebody help me for save some vcore on gigabyte board??
__________________
Old 10-29-2009, 05:52 AM   #20
hokiealumnus
hokiealumnus's Avatar
That's actually very good Vcore for a stable 4GHz. My chip takes 1.37v loaded to stabilize at 4GHz...and that's without HT. As mentioned before, 4.4GHz is going to be very difficult to reach and if you do get there, it will not be with much stability. Even the best of these chips don't really do that for 24/7 clocks. Here is a thread showing some 860/870 overclocks for you to reference.
__________________
EVGA P55 FTW * i5 870 @ 4.0GHz * Water * 2x2G G.Skill, DDR3-2400 (9-11-9-28) * HIS 4890 Turbo * Corsair TX650
Water Cooled RC690: MCP-355 w/ XSPC Res Top -> Swiftech MCR-220 -> Swiftech MCR-320 -> Swiftech Apogee XT
hokiealumnus is offline   Reply With Quote
Old 10-29-2009, 05:58 AM   #21
davidexD
davidexD's Avatar
no i'm not stable with 1,3440 at all, i'm searching a right voltage but i think it's very tall.i need to tweak the bios but i don't know anything about gigabyte bios.
__________________
Old 10-29-2009, 06:15 AM   #22
RJR
What is your LOAD vcore?
Do you have LLC enabled?
Gigabyte P55 boards have a steep vdroop (at least mine does).
RJR is offline   Reply With Quote
Old 10-29-2009, 06:47 AM   #23
davidexD
davidexD's Avatar
what is llc? i set in the bios 1,34 but in load it jumps to 1,368 so strange
__________________
Old 10-29-2009, 07:00 AM   #24
stasio
stasio's Avatar
For start read this review for UD6 and implement on yours UD4:
http://www.clunk.org.uk/forums/revie...ng-review.html
__________________
Old 10-29-2009, 07:03 AM   #25
davidexD
davidexD's Avatar
nice guide but is not the same mobo for example i can't choose the level of the loadline calibration.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
