update #7
well this update is not so big aswell but i have decided on a color and a paint theme (somewhat) and i got the plate mounted with countersunk screws heres goes the pics:
this is the silver i am going for
taped it off
and heres the blue im going with
and the theme is to go with the racing stripes around the whole comp
and now heres the plate
holes are countersunk
and mounted
i had to use 3 metal washers to get it to sit tight since my material isnt think enough and the standoffs have a small area right at the top of the thread which is blank so without these washers the standoffs wobble all over the place
since the place wasnt thick enough either I had to use a washer for that aswell and it came out pretty well if you ask me
with the top panel on to see the distance between the dvd drive and the plate
thanks for reading/watching
update #8
i did a few things this weekend... got the LED holder ready and good to go done with all the sanding and primered and got the front panel cleaned up and sanded down for powdercoating and i got the HDD holders installed (WoW and TF2 are really taking over my life hehe)
here goes the pics:
The LED holder left a bit of the blemished look for the look of it
the little plate which will be holding the LEDs
The PCB mount
test look
ready to be primered
and done with first coat
with slight wet sanding and second coat on
the plate sanded down and ready for paint
primered (first coat)
the back of the LED holder primered
both pieces with 3 coats of primer with slight wet sanding in between each coat
doesnt look as blemished as the initial pic just that bottom right side
and got one coat of river blue on the plate
and now onto sanding down the front panel:
where i started
after 120 grit
and done up till 2000 grit (battery ran out on camera)
heres a look at the difference between the original and what it is not... its not perfect but it will be after powdercoating
and now the third thing i did this weekend install the hard drive holders:
The method i am going with is what i saw on CyberDruid's Wall Hanger Absolutely brilliant idea to take one of these:
and then chop it down to the size you want THANKS CD :thumb:
removed all of
got to cutting and the end product
drilled the mounting holes
well it was a bit difficult to get the rivet gun in that angle so i decided sand it down the area around the rivet a bit
mounted and good to go
on to some tests
these screws to mount the HDDs
clamped together a mock up to see how it does in the case as i measured it... it should be good
the third hdd seems to hit the false floor
after riveting the false floor it turned out ok the false floor just misses it
and here is how it sits atm
thanks for watching/reading
