XtremeSystems Forums
Reply
Old 10-23-2009, 11:53 PM   #251
strike
nop
I tried looking dealers from europe but no luck
mine purchased from sidewinder and my plate is on way to spain
thanks Gabe
strike is offline   Reply With Quote
Old 10-24-2009, 05:23 AM   #252
Main
Main's Avatar
The baseplate arrived - and Swiftech even included the allenkey needed
The is that I am invited to a big party that starts in 3 hours..... and tomorrow I will have a helluva hangover
__________________
Worklog - xtreeme Please comment and give me your input | Testware |
Main is offline   Reply With Quote
Old 10-24-2009, 08:28 AM   #253
millertime359
Xtreme Guru
millertime359's Avatar
Originally Posted by mojododo View Post
Looks good, could you roughly guess how much gap there is between the 2 there? if its above 5mm, 10mm etc.
my 45º compressions look similar in sizing to those 45 elbows so it should fit well.
I just got mine and put on 2 45s with BP 1/2 3/4 comp fittings. No problems here.
__________________
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
millertime359 is offline   Reply With Quote
Old 10-24-2009, 08:52 AM   #254
gabe
Mr. Swiftech
gabe's Avatar
Originally Posted by ChielScape View Post
maybe a generic 775 to 1156/1366 conversion bracket would be an idea?
That's what we would do anyways. But it doesn't change the nature of the problem (cost for small series) -
Originally Posted by KURTZ View Post
@ gabe (and others): can i ask you a question? i need to know if i can put 2 compression fittings for my Tygoon 1/2ID 3/4OD, thanks for the answer
edit: i mean these or maybe better these
Yes you can.
chilledpc has the new back-plates? :p
__________________
CEO Swiftech
gabe is offline   Reply With Quote
Old 10-25-2009, 09:53 PM   #255
Locke
Locke's Avatar
Originally Posted by gabe View Post
It's not always possible (Apogee drive for example will not be 1366/1156 compatible), but we are certainly concerned about this and always do our best to provide an upgrade path.
We weren't contemplating doing the GT either, but I am having second thoughts about this. The issue is that the cost of making small series, necessitates using laser cut technology, which would make the GT brackets quite expensive ($15 each).
Any user feed-back will be appreciated.
Thanks in advance.
What about waterjet, may be a bit cheaper than laser, and should give a nice result in the end. And you could cut all of your upgrades out of one sheet of stock. Not sure the laser cost run per hour though.
__________________
i5 750 @ 4200 on Apogee GTX
Gigabyte p55a-ud4p
2 x 2gb GSkill Trident pc1600
HD5850 on mcw60
PA120.3
Custom Built Case
My Blog:
http://www.destructoid.com/blogs/Locke
Locke is online now   Reply With Quote
Old 10-26-2009, 06:32 AM   #256
mojododo
Cheers mate, just waiting on aussie stores to stock em!
mojododo is offline   Reply With Quote
Old 10-26-2009, 11:20 AM   #257
nsx241
Hey Gabe,
I grabbed an XT last week, but after I opened it up, it seems to have some manufacturing defects. I contacted michelle, is she the right person for this issue?
nsx241 is offline   Reply With Quote
Old 10-26-2009, 11:21 AM   #258
gabe
Mr. Swiftech
gabe's Avatar
Originally Posted by nsx241 View Post
Hey Gabe,
From a thermal and hydraulic standpoint, these minor imperfections will not cause any measurable degradation whatsoever. We cannot even consider them cosmetic defects since they are hidden inside the block. We view this as an acceptable norm deviation, and they passed QC.
These do not qualify for RMA. However, as a customer service accommodation we are always willing to please the customer and replace the plate.
__________________
CEO Swiftech
Old 10-26-2009, 02:40 PM   #259
ChielScape
i dunno 'bout you gabe, but dont want any loose copper pins in my pump for example...
if thats the kind of quality i can expect.. it looks like i'll be buying a heatkiller.
ChielScape is offline   Reply With Quote
Old 10-26-2009, 03:23 PM   #260
WaterFlex
WaterFlex's Avatar
Hmmm, have never seen things like that 0_0
__________________
Intel E8400 500x9MHz@1,37V LinX 64bit mode stable
Asus Maximus II Formula 2202 Bios
OCZ Blade Series PC2-9600 4GB 1200MHz/5-5-5-15/PL8/1,8V
Seagate RAID0 2x Barracuda 7200.12 500Gb
Asus Radeon HD5870
Iiyama ProLite E1902S-B1 Black
Thermaltake Xaser VI BWS
Seasonic M12-700 Watts
M-Audio Audiophile 192
Liquid Cooling System :
Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
EK Water Blocks EK-FC5870 Acetal+Nickel with EK-FC5850/5870 RAM Backplate
ThermoChill PA120.3, Laing 12V DDC-1Plus, XSPC Laing DDC Reservoir Top
Arctic Cooling MX-3, 3x Scythe S-FLEX "F", 3x Scythe Gentle Typhoon "15", 2x 140mm Noiseblocker NB-BlackSilentPRO PK3, Scythe Kaze Master Ace 5,25''
WaterFlex is online now   Reply With Quote
Old 10-26-2009, 03:27 PM   #261
space_pope
+1 on that.
space_pope is offline   Reply With Quote
Old 10-26-2009, 03:39 PM   #262
Blkout
Oh, get a life, you're WAY overreacting.
Blkout is offline   Reply With Quote
Old 10-26-2009, 03:45 PM   #263
gabe
Mr. Swiftech
gabe's Avatar
Of course not, and you wouldn't either. These are thoroughly inspected, and blown with a 120 PSI jet many times during the manufacturing process. if pins are loose, they will be ejected during cleaning.
Tha'st not "the quality you can expect either". That's a minor deviation from the "perfect" norm.
@waterflex: you couldn't have seen it anywhere. As far as I know, we are the only company in the world making a pin that small (0.25mm).
It's a real techical challenge to make these guys. We thrive to maintain a perfect score, but when there is a minor miss, QC people have the authority to allow it thru if they feel positive that it does not present a risk to the user.
__________________
CEO Swiftech
Old 10-26-2009, 03:48 PM   #264
millertime359
Xtreme Guru
I don't see any loose metal there, but as far as HK goes, have you ever seen a rep on these forums from HK?
At least Gabe comes onto the forums on a regular basis so you can bring issues like that up to him.
__________________
Old 10-26-2009, 03:56 PM   #265
nsx241
I've been a swiftech user for many years, and this is the first time I've encountered something like this in one of their blocks. In any case, Michelle already contacted me about a replacement, so no big deal other than a little time lost completing my build.
Old 10-26-2009, 04:24 PM   #266
ChielScape
Watercool has their own forum. I visit it from time to time. It's great.
one free internet for the first to guess this block. (see attachment)
Old 10-26-2009, 04:34 PM   #267
gabe
Mr. Swiftech
gabe's Avatar
Yes, because over the years, we have been pushing the enveloppe. As I said above, these little guys (0.25mm pins) are a real technical challenge.
Another factor to consider is the fact that production always improves over time, as we improve our know-how.
__________________
CEO Swiftech
Old 10-26-2009, 04:35 PM   #268
ChielScape
challenges are meant to be overcome, not to be used as an excuse.
Old 10-26-2009, 05:07 PM   #269
gabe
Mr. Swiftech
gabe's Avatar
you can interpret it as an excuse, I said it as an explanation. I also said above "Another factor to consider is the fact that production always improves over time, as we improve our know-how " which validates that point. In any given manufacturing process, there is a ramp-up stage.
__________________
CEO Swiftech
Old 10-26-2009, 05:18 PM   #270
ChielScape
Im looking forward to seeing the risk decrease to the point where I'll be able to consider the XT a viable option, then.
Old 10-26-2009, 06:33 PM   #271
Spawn-Inc
Spawn-Inc's Avatar
http://www.xspc.biz/photo/deltav3/2.jpg
seems to be a normal thing, look at all the messed up pins...
and ChielScape it's a Thermalright XWB-1
and they DON'T machine the block like swiftech does. they use plates of copper with notches cut in them stacked then soldered into place. though i'm not 100% sure it's soldered in place, i do know it is not machined the same way.
__________________
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
Spawn-Inc is offline   Reply With Quote
Old 10-26-2009, 10:35 PM   #272
meanmoe
Cool
Hey Gabe,
I'm a huge swiftech fan. Seriously, big fan, but I'd be pretty upset if I recieved that block.
When I bought my danger den torture rack, I was real excited. Everyone (that gets a sample to review) always raved about the quality. When I got mine, some of the holes were badly over drilled. It was pretty ridiculous to me and although it 'passed QC', I most likely will never do business with them again. Oh and I'm going to tell people about it.
This may seem overly harsh, but I guess that's the trade made in QC vs. Cost. I know it's a numbers game, but I expect 'as advertised'.
Really though, I'm a big swiftech fan. Don't send me a block like that though.
__________________
upgrading...
meanmoe is offline   Reply With Quote
Old 10-26-2009, 11:16 PM   #273
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
crap, hope this quality thing is not a problem on a lot of blocks. i bought 3 bran new swiftech blocks, and all 3 have problems . i thought i was the only one and just got extremely unlucky, but does not seem like it.
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
WhiteFireDragon is offline   Reply With Quote
Old 10-28-2009, 12:41 PM   #274
talonz
As of yesterday we started shipping all Apogee XT's with 1156 back plates. I will update the website asap.
John
JAB Computers
www.jab-tech.com
Ordered mine! Hopefully the baseplate has clean machining
__________________
Panworld 40PX - Swiftech Apogee XT - BIP II - 2x Scythe Slipstream 1200
talonz is offline   Reply With Quote
Old 10-28-2009, 01:00 PM   #275
kInOzAwA
kInOzAwA's Avatar
Mr gabe, is that Swiftech XT already launch the AM2+ mounting yet? I know there's some desperate AMD fan out there like to use this great WB including myself....
kInOzAwA is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
