Page 1 of 20 123411 ... LastLast
Results 1 to 25 of 495
Thread: ** OFFICIAL ** Core i5 Overclocking Results/Tips Thread
    Jul 2006
    Arrow ** OFFICIAL ** Core i5 Overclocking Results/Tips Thread
    boobs
    I will start the ball rolling with this VERY modest o/c, I am stuck on stock cooling atm so I am being held back my temps allot.
    BIOS vcore - 1.22v
    RAM voltage - 1.645
    VTT - auto
    QPI Ratio - 16
    RAM Ratio - 5
    C1E & EIST - Disabled
    Spead Spectrum - Disabled
    Load Line Calibration - Disabled
    Sep 2007
    Ontario, Canada
    I'm having a ton of trouble myself with my new i5 750 and 4x2gb dimms.
    I can do 3.5ghz @ 1.3v core and 1.15v VTT, all else stock.
    3.8ghz@ 1.3875v core and a monstrous 1.41v vtt. I'm sure the insane VTT is because of the 4 dimms being used :/
    Hardware
    • Core i5 750 @ 3.6Ghz (180x20)
    • Scythe Zipang 2
    • 4x2Gb DDR3 (1080@7-7-7-16, 1.65v)
    • Gigabyte P55-UD2
    • EVGA GTX 260, Corsair 550VX, mATX case
    Audio/Video
    • Samsung LN32A550 32" 1080p LCD
    • Asus Xonar Essence STX
      1. Denon AH-D2000
      2. Sony STR-DE197 -> Polk Audio M10
    Desktop Picture
    Jul 2006
    Weird, check this to see if you missed anything obvious
    http://www.youtube.com/watch?v=I6zANFlYEDM
    I have the GD65 so this helped me quite a bit, although I nvr touched VTT and only have 2x4GB.
    Have you checked the basics like, dropping you RAM/CPU multi and seeing what base clock you can get stable?
    ASUS P8Z77-V PRO
    Core i7 2700K @ 4.8Ghz | H80
    Gigabyte Windforce HD 7970
    8GB Crucial Ballistix Elite 1866Mhz
    2x 128GB Samsung 830 RAID-0
    Corsair AX750W
    Silverstone FT02
    Sep 2007
    Ontario, Canada
    Quote Originally Posted by ArCElM View Post
    I've overclocked once or twice in my day.
    I've dropped the qpi multi to 32x, ram to 6.0x, cpu multi to 10x, and loosened ram timings a ton to narrow it down to a BCLCK soft-wall.
    The only thing that has helped has been to raise the VTT (mch is on this voltage circuit) by a -ton for every little bit of BCLCK I raise.
    It's kind of unfortunate, but I'll probably just run 3.5Ghz for the sake of my VTT.
    Hardware
    • Scythe Zipang 2
    • Gigabyte P55-UD2
    Audio/Video
      1. Denon AH-D2000
    Desktop Picture
    Mar 2004
    Need better cooling for 4GHz+.
    Spec:
    MSI P55-CD53 mb, has printed voltage measure points
    Crucial 1333MHz 4GB KIT, CL9
    Corsair 450W VX PSU
    CM Hyper 212 Plus CPU Cooler
    CPU batch: L924B514T
    Measured voltage vcore DMM: idle>->1.438v load<->1.358v
    Feb 2008
    Sweden
    Quote Originally Posted by Bradan View Post
    My Giga P55 UD5 will NOT under any circumstances allow a BCLK higher than 160 if i have more than two sticks of RAM in the computer, if I remove two of them(I also have 4x2GB) it does 210 BCLK without a hitch.
    Apr 2006
    Smile i5 750 sweetspot on stock
    Not having anything better than the stock cooler, and looking for the sweet-spot of o/c and temps, I have settled on the following:
    19x160=3040 MHz
    36x QPI
    1.1750v vcore, LL off (gives 1.15 actual, 1.14 under load)
    1.9v Mem using Patriot Viper @ 1600/7.7.7.23
    All other voltages at AUTO
    Max temp using Prime95 is around 65 celcius with ambient temp of 22 degrees.
    I'm looking forward to the release of aftermarket coolers, and annoyed that the lga775 ones 'just' don't fit!
    Core i5 750@19x160MHz | Gigabyte P55-UD5 | 4Gb Patriot Viper DDR3-1600 7-7-7-23 | 1Tb Seagate SATA2 | Gigabyte 8800GTS 512Mb @ 700/1800/1000 | Creative Audigy | Thermaltake Tsunami | Seasonic 650w
    May 2007
    Using a very cheap Gigabyte P55M-UD2..
    Love the underdog!!
    Intel Core i5 750 @ 4.3Ghz H2O
    Gigabyte P55M-UD2
    Sapphire HD4890 Vapor-X @ 950/4800
    2 x 2GB Ripjaw PC16000 @ 9-9-9-24-1T
    2 x 250 WD Raid
    OCZ StealthXtreme 600W
    Sep 2009
    NICE, stable?
    May 2007
    Stable to use 24/7 but it does fail prime95 after a while...
    Gigabyte P55M-UD2
    2 x 250 WD Raid
    Apr 2005
    www.vmodtech.com,Thailand
    SYSTEMS
    CPU Intel® Core™ i5 750 Retail Box
    Motherboard GIGABYTE P55-UD6
    Memory G.Skill Trident PC12800 6-7-6-18 2GB*2 Dual Channel
    Graphic Card INNO3D GTX295 @ 729/1,566/1,242MHz
    Harddisk Seagate Barracuda 7200.11 500GB
    CPU Cooler Water Cooling (EK Supreme ,Swiftech MCP655 ,Swiftech MCR320)
    Power Supply SEASONIC 850W
    Operation System Windows 7 Ultimate 32-bit
    http://valid.canardpc.com/show_oc.php?id=722679
    http://www.vmodtech.com/main/article...55-ud6-review/
    Sep 2008
    ROMANIA
    Finally someone put a thread, a thread to 860/870 must be created to..
    750 it's a great Cpu..from what i see 4ghz 24/7 it's sure, at leas with 4gb rams..
    Oct 2005
    Bochum / Germany
    Quote Originally Posted by xdan View Post
    Yeah, 4GHz is quite easy, after you found out, how your motherboard behaves...
    Sep 2007
    Ontario, Canada
    Quote Originally Posted by ovard View Post
    Good to know. I have the UD2 matx board and I'm feeling lucky to get the 175 BCLK at 1.19v VTT with 4x2gb.
    I'm kind of torn about this because with 8gb and pagefile disabled, my system is much smoother than any other I've used.
    Hardware
    • Scythe Zipang 2
    • Gigabyte P55-UD2
    Audio/Video
      1. Denon AH-D2000
    Desktop Picture
    Feb 2006
    Manchester, UK
    Managed this one, my CPU isn't great but the memory controller looks to be pretty decent so far
    4GHz - 200 BCLK x20 @ 1.41v Vcore 1.4v QPI/VTT 1600MHz Memory 6-7-6-24 1T
    Jan 2007
    Michigan
    Repost, can a mod combine these threads please?
    http://www.xtremesystems.org/forums/...d.php?t=234670
    TYIA
    Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
    Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
    Intel 4.5GHz LinX Stable Club
    Feb 2008
    My results
    1.42v, 1.32v IMC, 1.15v PCH, 1.90v PLL
    1.44v (bah...), 1.32v IMC, 1.15v PCH, 1.90v PLL
    • ASUS P7P55D Deluxe
    • Kingston HyperX (i5 specific) 1600 2x2GB Cas 8/1.65v rated
    • Noctua NH-UP12 with Scythe 120x25, 120x38 PUSH/PULL 86CFM fans
    i5 2500K @ 5GHz (1.4v) | Biostar TP67B+ | 8GB GSKILL 1600
    HEATWARE / Rate My RIG / i7 950 @ 4.6GHz / 1090T @ 4.5GHz / i5 2500K @ 5GHz
  18. #18
    Dec 2008
    Hi Guys,
    I just bought i5 750 last night from Egg...I didn't get mobo and ram yet, I found this thread is really interesting me here.
    @ keenan, I like your idea to buy cheaper mobo and it works like charm and no need spend expensive one.
    I am drooling of your mobo, but I think I had enough with gigabyte brand and maybe this time to get different brand like Asrock P55 Pro or better.
    Guys, would you please run Core Temp 0.99.5 to see what is your VID ?, also dates and batch if possible, just take screenshot to post here.
    I will post it when my new shiny i5 750 arrive probably next week.
    Keep up strong i5 750 !
    dg
  19. #19
    Jun 2009
    I was able to get 4 GHz
    Vcore 1.3875 Bios
    VTT 1.35 V
    PLL Default 1.8V
    Hardware
    CPU: Core i5 750
    MOBO: Evga P55 Le
    RAM: 4GB OCZ Gold DDR3 1600
    GPU: XFX Radeon 4890 [950/1100]
    Case: Coolermaster Cosmos 1000
    PSU: Corsair CMPSU-750TX 750W
    Cooling
    CPU: Heatkiller 3.0
    GPU: XSPC Razor 4890 Water Block
    Radiator: Black Ice GTX480Quad
    Pump: MCP655 Pump
  20. #20
    Jan 2007
    Michigan
    Just to recap, most chips seem to be doing the following:
    Average Low OC: 3.6GHz @ ~1.22 to ~1.30
    Average Medium OC: 4.0GHz @ ~1.35 to ~1.38 vcore
    Average High: 4.3GHz @ ~1.38 to ~1.42vcore
    Keep up the results people!
  21. #21
    Jul 2006
    Quote Originally Posted by Vinas View Post
    Repost
    ROFL not really a REPOST is it!
    "i5 batch number list"
    Anyway the thread is turning out just the way I planned, somwhere were people can discuss results, and how they achieved the results.
    I am still waiting on the LGA156 Bracket from Corsair before I can do anything else
    ASUS P8Z77-V PRO
    Corsair AX750W
    Silverstone FT02
  22. #22
    Jan 2007
    Michigan
    Besides the fact the title is different, the original thread is the same as this...
    Edit: No big deal but the other thread was posted several days before you created a new thread, that's all. There was another thread started by batman too! So it gets confusing.
  23. #23
    Jul 2006
    Only thing confusing is your title, specially if your thread was meant to be about overclocking results and tips.
    My thread is about, my title..
    Core i5 Overclocking Results & Tips.
    Hence my threads penis is 4.2" and yours is 2.1"
    Now enough about you telling me how many people had already created a thread just like mine, and back to some epic i5 Results.
    How about we see a screenshot with the vcore as well Vinus of your 4.3Ghz, coz thats pretty extreme
    If I can hit 4Ghz when I get my Cooling I will be MORE than pleased.
    ASUS P8Z77-V PRO
    Corsair AX750W
    Silverstone FT02
  24. #24
    Feb 2008
    Who cares how many threads there are, lets see results.
  25. #25
    Jul 2006
    Hi
    Not quite in your league but it prime95 stable 12 hours
    1.316 in bios
    1.3 vtt
    mem 1.6
    every thing else stock
    under water
    Batch/L924B290T
