XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 09-12-2009, 10:54 AM   #1
Tommie_lj
Send a message via MSN to Tommie_lj
Is P2 940BE IHS soldered? (Deneb)
is the heatspreader soldered or not on this chip?
and is it whorth it to remove the Ihs? im running it under water..
/Tommie
Tommie_lj is offline   Reply With Quote
Old 09-12-2009, 11:01 AM   #2
chew*
No rest for the weary
chew*'s Avatar
All phenoms I or II are soldered.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 09-12-2009, 02:38 PM   #3
Tommie_lj
okok.. is it worth the risk removing it, or is a simple "lapping"job good enough?
Old 09-12-2009, 04:19 PM   #4
chew*
chew*'s Avatar
Up to you.....its your warranty.
Can you kill it attempting removal? Yes.
__________________
heatware chew*
Old 09-12-2009, 04:37 PM   #5
Tommie_lj
the warranty issue is not concerning me, i just want to know if there will be a significant drop in temperature.. and if it is a big difference between a nicely lapped one, and cooling the die directly..
Old 09-12-2009, 07:08 PM   #6
chew*
chew*'s Avatar
For normal water and air.....you won't see any major gains.......probably not worth the risk or effort.
We tried one delidded under ln2......it lasted 3 minutes , never posted again.
__________________
heatware chew*
Old 09-12-2009, 08:57 PM   #7
DedEmbryonicCe1
Delidded with a torch or a gentler method? I remember seeing a Phenom I Agena that had the top popped off with a torch but it was already dead beforehand.
DedEmbryonicCe1 is offline   Reply With Quote
Old 09-12-2009, 09:34 PM   #8
chew*
chew*'s Avatar
It was done by AMD themselves.....
__________________
heatware chew*
Old 09-12-2009, 10:02 PM   #9
Neox69
Neox69's Avatar
Send a message via Yahoo to Neox69
Found this and it might be useful...
http://forums.extremeoverclocking.co...d.php?t=325952
Neox69 is offline   Reply With Quote
Old 09-13-2009, 12:17 AM   #10
ajaidev
ajaidev's Avatar
I think lapping is better "less chance you can break it"
ajaidev is offline   Reply With Quote
Old 09-13-2009, 04:01 AM   #11
Tommie_lj
i think i will try lapping it flat first.. the ihs is far from being flat.. very concave..
Old 09-13-2009, 04:39 AM   #12
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Lapping the heatspreader will gain you anything from 0 up till sometimes even 10ºC under load, idle won't see much of a difference.
Keep us posted, i'm curious how much of a difference either lapping or removing the hs will give.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 09-13-2009, 04:51 AM   #13
mAJORD
The biggest issues with removing an IHS is not massivly overheating for long periods of time, and also, bending the PCB too much.
I first preheat the whole package to around 100c, then use a 'hot plate' that's around 200c. by applying gentle but constant "prying" pressure between hspreader and PCB, when the IHS itself conducts the heat to the solder joint, it will flow, and break free.. too much pressure though and the PCB might bend to a point it fractures solder joints on the capacitor networks.
This prevents the die from seeing excessive hea,t as when the solder melts, the cpu pops off, I quickly remove it from the area and let it cool naturally.
Remember, regardless of the fact the IHS older is relativly low melting point, the IC's can handle around 240+deg Celcius (~470 F) for a short time, as that's the temperature they would see if soldered onto a board. Not to mention the packaging process itself.
mAJORD is offline   Reply With Quote
Old 09-13-2009, 05:06 AM   #14
Tommie_lj
i will post results later..
Old 09-13-2009, 09:54 AM   #15
demonkevy666
demonkevy666's Avatar
Send a message via MSN to demonkevy666 Send a message via Yahoo to demonkevy666
ihs removed would be nice a copper true sitting flat on bench board on some small case.
__________________
http://www.youtube.com/user/golem720.../0/GKiZtsEVb8I
^ EVIL BUNNY
HTPC coolermaster 690 sempron 140, Gigabyte UD3H, ddr3 1600mhz, 650 ps, 160gb hard drive currently running windows vista 64 bit (30 days)
AMD Green & black dragon GODZILLA get it it's now classic XD
foxconn destroyer revived Thermaltake Xaser IV case (bought)
285gtx 2gbs need to save cash now
demonkevy666 is offline   Reply With Quote
Old 09-13-2009, 11:09 AM   #16
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
I think I dropped a few C lapping mine, not really sure though. My temp sensor might be broken. Added pressure to my TRUE mount and gained... nothing. Odd chip. On the other hand I gained 100mhz at the same voltage stock cooler lapping an AM2 3800+ X2 a few years ago. Here's a mid lap picture of my 940BE, as you can see they are quite concave.
and finished
Took about 2 hours started out dry sanding with 100 grit until it was all copper then smoothed it out with 600 grit wet.
Do you know what caused it to break?
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is online now   Reply With Quote
Old 09-13-2009, 12:53 PM   #17
Tommie_lj
okay, i have lapped the cpu now, and i did it with only 600Grit, cus thats the only one i had at home..
after running intelburntest a couple of times to let the AS5 have some time to "cure", i now see around 1-2 deegres lower temp.. thats ok, but not really what i expected.
have to admit im still very tempted at delidding this sucker..
Old 09-13-2009, 08:50 PM   #18
perkam
Live Long And Overclock
perkam's Avatar
Send a message via MSN to perkam Send a message via Yahoo to perkam
and finished
Holy Hell, if it isn't AFI 0_o
How're you doing m8? You must be in highschool/ college by now?
@Tommi, lapped CPU? WE NEED MOAR PICS !!
Perkam
__________________
Star Trek Online Open Beta
Name: Captain Maxentius
Rank: Lt.
Ship: USS Kira
Class: Miranda-Class
Preferred Class: Akira-Class
perkam is offline   Reply With Quote
Old 09-14-2009, 01:30 AM   #19
Tommie_lj
Perkam, sorry but i only have my K800i as a camera, and the cpu is already in the PC.. but i think i will try sanding it down to the silicone either today or tomorrow.. then i can take som pics for you guys
Old 09-14-2009, 04:52 AM   #20
afireinside
I am Xtreme
Perkam
LOL! Yeah I'm still floating around... Doing pretty good I'd say. second year of college now
__________________
Old 09-14-2009, 06:25 AM   #21
Tommie_lj
guess what... im sanding the little bastard right now!! i have a fair bit of sanding left, but i think im pretty close hehehe..
first to sand a Phenom II to te silicone?? ^^
Old 09-14-2009, 11:14 AM   #22
DedEmbryonicCe1
When I lapped my 5000+ Brisbane I discovered it had a concave depression in the center shaped like an hourglass. Regardless, I didn't notice much improvement with my Vendetta 2.
Old 09-14-2009, 12:40 PM   #23
Tommie_lj
everything in this pic has its explaination
here is right after the top part and the solder has been removed..
dirty hand holding shiny chip
here he is in his home after a long long day
Old 09-14-2009, 01:02 PM   #24
felix_w
felix_w's Avatar
Very nice Tommie...awaiting your temperature differences to be announced...
felix_w is offline   Reply With Quote
Old 09-14-2009, 01:47 PM   #25
Tommie_lj
waiting for the as5 to get full effect, but somewhere around 5 degrees celsius cooler from stock IHS..
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
