GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
This chip is insane. c'mon 2010!
- i7 5820K | Asus X99 Deluxe | 16GB Corsair Vengeance LPX | eVGA GTX 970 SC SLI | Asus PB278Q | 250GB Samsung 840 | 11TB HDD Storage | Steel Series Rival & QcK+ | Razer Orbweaver & Black Widow Ultimate '14 | Corsair RM1000W | Win 8.1 -
- Ek Supremacy Nickel | Alphacool NexXxos UT60 360MM | Coolgate UHE 360MM | Bitspower Water Tank Z-Multi 150 | EK D5 CSQ Top | Alphacool VPP D5 | Corsair SP120 HP's | Corsair 900D | Xbox One & PS4 | Sharp Aquos Q 60" | Astro A50 -
~ Gone but never forgotten: Xtreme Legend - Hallowed Point - Enthusiast - Bencher - Friend ~
Damn nice ! run it X64
Apple MacBook Air
Apple IPad 2
CPU-Z typically shows a range on ES processors. The minimum 12 followed by the default maximum. Processors that support turbo boost are then able to go beyond this maximum.
When users are willing to spend a $1000 bucks or so for an Extreme processor, Intel is usually nice enough to give them an unlocked multiplier. i9 will likely be unlocked when it hits retail just like an i7-965 or i7-975 is.
Nice cpu score vantage but it will suck at the 3d score of vantage becouse of the low speed at 19x multi and lose lots of points.
its a nice chip for wprime/cinebench however.
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
And don't forget Chess
-Core i9 7980XE @4,20Ghz Vcore:1,10V
-Asrock X299 Taichi XE
-Custom water-cooling loop
-16Gb Corsair DDR4 3200Mhz
-Samsung 970 evo Plus 500Gb
-Samsung 960 evo 250Gb
-Samsung 850 evo 500Gb
-Samsung SH-S223Q
-Asus RTX 2080 Dual OC
-Cooler Master HAF 932
-Seasonic Prime 1300W Gold
Test results are always welcome with this Chess Test where all your cores/threads will run @100% ,Thanks
http://www.xtremesystems.org/forums/...=1#post5259523
this is gonna be a rosie beast@4ghz!
Intel Pentium G3258 | ASRock Z97M OC Formula | Samsung 2x4GB DDR3-1600 | Galaxy GTX660 GC | Samsung PM840 Pro 128GB, PM830 250GB FDE |
"I Love To Camp!"
"Comensing Shock Therapy!"
HeatWare
3D mark 06 CPU test @ 4,0-4,2GHz please.
Why you guys broke NDA ??
[Core i7 4820K Ivy Bridge-E @4,7Ghz Vcore 1.28v][Asus Rampage Iv Extreme bios 4403][16Gb G-skill Ocz 2133mhz DDR3][Lian Li Pc2120 B, black Case][480Gb OCZ SSD main disk+120Gb ssd game disc][EVGA GTX Titan@900mhz Oc luft ][Os Windows 7][Telia 1000/250Mbits fiber ][24,4TB Lagring] upcoming Intel Haswell-E 8 cores/16 Threads next year Q4 2014 ?
Those guys never signed any NDAs
I could have an i9 too- but didn't want one- it's useless if you don't do benchmarking or professional work as a living
Most games don't even use 4 cores...
And why all the people spoke about i9 ? Gulftown will be i7
***** Visit us on PCWorld.fr *****
[[Daily R!G]]
Core i7 920 D0 @ 4.0GHz w/ 1.325 vcore.
Rampage II Gene||CM HAF 932||HX850||MSI GTX 660ti PE OC||Corsair H50||G.Skill Phoenix 3 240GB||G.Skill NQ 6x2GB||Samsung 2333SW
flickr
cpu-z dosent support core i9 yet mabe or can read it
damn locked 19 multi =(
Intel 990X ES @ 6x4,60Ghz@1,440V klick / DFI UT x58@ MIPS HD6950@70@1Ghz / 256GB M4 SSD / X-Fi / HK3.0 - Laing Ultra - Thermochill PA120.3 + TFC 120er + Cape Cora Ultra 8x/ Aquaero Steuerung / Lian Li A7110B / Seasonic Platinum 1kw / 2xDell IPS 23" / Win 7 + Server 2008 R2/ DSL 16K
HTPC + HTPC Wiki + sysProfile + Clarkdale @<15W + Eigenbau-Ambilight + Ambilight PreOrder
Guys, there seems to be only one "type" of chip circling right now. Mult 18, Turbo 19 - but definitely locked, unfortunately - or I would have gotten one by now
Chrisch, that CB10 looks low (I've seen another chip @ same frequency do >33k) is that 32bit?
Yes, its 32bit.
x64 looks like this
That's more like it Chrisch
BCLK wall?
222BCLK, but i think it is the gigabyte board which limited. Its my third UD5 and all had a wall at ~221-222Mhz (with different CPUs)
i have now a RIIE here but i need a bloomfield to flash a Gulftown "ready" bios
Multi 19 too locked with your gigabyte UD5 ??
Edit : i have found a perfect detection here :
