XtremeSystems Forums
Reply
Old 07-26-2009, 08:40 PM   #1
UNIXgod
UNIXgod's Avatar
does MCW-NBMAX fit :banana::banana: 7/16in. Compression fittings?
Picking up a rampage and I'm gonna replace the nb with the MCW-NBMAX. I have a pair of bits_power 7/16 silver compressions and was wondering if there was any compatibility issues with these two parts.
banana??? wtf?
__________________
CPU: Intel Core 2 Extreme QX9650 Yorkfield
Motherboard: Foxconn Blackops X48
Memory: 4G 2x2 OCZ Reaper DDR3 1800 (PC3 14400) 8-8-8-27 1.9v
Hard Drives: 2 x W.D Raptor 150GB (OS, games, apps) RAID0
Video Card: XFX Black Edition 9800GTX @ stock frequency (760 core / 2280 memory / 1900 shader)
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Optical Drives: Nec 3550 dvd burner
OS: Gentoo GNU/Linux amd64 | Windows Vista Ultimate 64-bit
Odds/Ends: Razer Diamondback Mouse - Happy Hacking Keyboad Pro2 - RME pro audio card. FreeBSD UNIX servers and laptop when I'm not gaming!
UNIXgod is offline   Reply With Quote
Old 07-26-2009, 09:00 PM   #2
stangracin3
B P's name is censored. see the thread in the first forum
__________________
thank god they listened.
stangracin3 is offline   Reply With Quote
Old 07-26-2009, 09:23 PM   #3
BP-Vincent
Send a message via ICQ to BP-Vincent Send a message via AIM to BP-Vincent Send a message via MSN to BP-Vincent Send a message via Skype™ to BP-Vincent
banana??? wtf?
The outer diameter of our CC6/CC4/CC3 is 24MM.
From the SPEC of MCW-NBMAX...It might fit...But need to have real one on hand to check.
I back to this forum first and then those will be next.
BP-Vincent is offline   Reply With Quote
Old 07-26-2009, 09:34 PM   #4
UNIXgod
UNIXgod's Avatar
Thank you Vincent. I love your silver compressions. I hope they fit!
__________________
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Old 07-26-2009, 09:37 PM   #5
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
there was a whole thread dedicated to different compression fitting brands and sizes and which blocks the will fit. if my memory serve me right, the 7/16 one should barely fit, but the 1/2" one will not. let me dig up that thread and verify it for you
very off-topic, but does this mean vince is not banned anymore?
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
WhiteFireDragon is offline   Reply With Quote
Old 07-26-2009, 09:38 PM   #6
stangracin3
yes
__________________
Old 07-26-2009, 09:40 PM   #7
WhiteFireDragon
Xtreme Cruncher
found it. as long as the OD is 5/8" or smaller, it should fit. everything you see on here has been tested, not speculations
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
Old 07-26-2009, 10:27 PM   #8
UNIXgod
UNIXgod's Avatar
Thank you WhiteFireDragon. That chart is very helpful.
They need to fix the bananas. I'm in the middle of reading that thread now.
Are there any other solutions for the rampage extreme? or is this nb block my only choice?
__________________
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Old 07-26-2009, 10:35 PM   #9
Kibbler
Kibbler's Avatar
You mean X48 rampage extreme yes (not X58 rampage II extreme)? If so bananas also make this:
http://www.performance-pcs.com/catal...ducts_id=24932
Kibbler is offline   Reply With Quote
Old 07-26-2009, 11:04 PM   #10
UNIXgod
UNIXgod's Avatar
I very much like that banana! Thanx for the link
__________________
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Old 07-26-2009, 11:08 PM   #11
JOCKTHEGLIDE
I installed one of those in my x48 RE and my NB and SB improved by 10C....could be that I applied better thermal paste than the workers at asus though.
JOCKTHEGLIDE is offline   Reply With Quote
Old 07-26-2009, 11:51 PM   #12
UNIXgod
UNIXgod's Avatar
I see it comes with the cooler for the circuit above the memory as well. Does it come with a mosphet block(s) as well? That would make it worth the price.
__________________
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Old 07-27-2009, 05:22 AM   #13
shazza
Xtreme Fan
shazza's Avatar
I believe you have to buy the mosfet blocks separately. I used 7/16x 5/8" compression fittings on the MCW-NBMAX on a Rampage Extreme board, and they worked fine. I ended up using one 45 degree fitting because it was less crowded on the block top, and also helped with my loop layout:
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is offline   Reply With Quote
Old 07-27-2009, 05:27 AM   #14
GregSG
I so want this too
Anyone willing to share pics of it installed?
GregSG is offline   Reply With Quote
Old 07-27-2009, 05:33 AM   #15
HoosTrax
Wonder if those BananaPower 45 degree fittings work on a MCW60. That's the only part of my loop that uses regular barbs, but I can't fit regular compressions that are larger than 3/8" (I use 7/16" tubing).
HoosTrax is offline   Reply With Quote
Old 07-27-2009, 05:40 AM   #16
shazza
Xtreme Fan
shazza's Avatar
Here's a pic of a 45 on the MCW60 (4870 version) ... not sure if the 4870 version differs in size. The regular compression fitting is 3/8 x 5/8 (which I believe we've previously determined has the same outer dimensions as the 7/16x5/8" fittings):
__________________
Old 07-27-2009, 05:52 AM   #17
HoosTrax
Afaik, the delrin top on the MCW60-4870 is identical to a regular MCW60.
I've tried my 7/16" compression on it, and it's too fat, so I had my eye on these.
If I'm reading the description correctly, it sounds like you can keep the rotary pointed in one direction while screwing it down, so in theory it should be possible to get two of them on a MCW60. Maybe.
Old 07-27-2009, 05:56 AM   #18
shazza
Xtreme Fan
shazza's Avatar
Those should work ... I have a couple of them as well, but ended up going with straight barbs on my MCW60. It may take some coordination to get them screwed on - the rotating part is pretty stiff at first, but don't see why it wouldn't work just fine.
__________________
Old 07-27-2009, 06:10 AM   #19
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
I just want to note here (and be completely off topic) that I appreciate the BananaPower moniker and I move that B!tspower should officially change its name to BananaPower
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 07-27-2009, 10:04 AM   #20
3Z3VH
3Z3VH's Avatar
I am not sure who is maintaining that spreadsheet, but I have personally verified that B P D-Plugs fit just fine on a D-Tek Fuzion GFX V2 block, both inlet and outlet at the same time. This includes the use of the D-Tek Unisink. It does not interfere with the D-Plugs at all.
3Z3VH is offline   Reply With Quote
Old 07-27-2009, 10:24 AM   #21
Laine
Laine's Avatar
Send a message via MSN to Laine
http://shazza53.smugmug.com/photos/5...58_m4KbV-M.jpg
Fixed it for you.
Even during hard times we must not forget the censorship!
__________________
LianLi V1000
LC Worklog: Project Crystal Clear
LianLi A05
LC Worklog: Project Simplicity
Laine is offline   Reply With Quote
Old 07-27-2009, 10:30 AM   #22
Coldon
Coldon's Avatar
Send a message via MSN to Coldon
Originally Posted by Laine View Post
Fixed it for you.
bwahahahahahaha... lol that made my day
__________________
Inside: i5 750, ASUS P7P55D Deluxe, 8GB G.Skill Ripjaws DDR3 2000, EVGA GTX260 C216, 3x1TB Seagate 7200.12 HDDs
Case & Cooling: CM ATCS 840, Corsair HX620 PSU, Swiftech Apogee GTZ, MCW60-R2, Swiftech MCR320 Rad + XSPC RS240 rad, DDC 3.2 with XSPC Bay Res One.
Coldon is offline   Reply With Quote
Old 07-27-2009, 10:31 AM   #23
NaeKuh
Broken Gainestown
NaeKuh's Avatar
Fixed it for you.
OMFG
this made my week!
Shazza he found the reason why u have no flow.. your hubby's been doing bad stuff to your gpu blocks.
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 07-27-2009, 10:53 AM   #24
shazza
Xtreme Fan
shazza's Avatar
I've been getting a bit tired of the silly bananas all over the place and the banana jokes. BUT ... THAT was funny. Gave me a good laugh. Thanks, Laine
(And, I hope to heck this banana:banana thing gets sorted out soon!)
__________________
Old 07-27-2009, 11:11 AM   #25
NaeKuh
Broken Gainestown
NaeKuh's Avatar
yeah... your not the only one...
ive been talking to dave on the phone about it a lot.
Sorry for the OT, as i dont want to get into the details... But if it wasnt coming, you guys know id be one of the first to explode on it...
But it was coming... like a 50 foot tsunami wave.
I hope things go well with B*P. B*P fittings are kinda manditory to me now.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
