XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 07-15-2009, 08:58 AM   #1
PcCI2iminal
Xtreme Family
PcCI2iminal's Avatar
Modded bios for seven Biostar models , X2-X3 @ quad :D
enjoy
TA790GX 128M
http://www.4shared.com/file/11825671...0GX_128M_.html
TA790GX XE
http://www.4shared.com/file/11825679...A790GX_XE.html
TA790GXB A2
http://www.4shared.com/file/11825686...90GXB__A2.html
TA790GX_A3(R1)
http://www.4shared.com/file/11799696...X_A3__R1_.html
TA790GXBE(R1)
http://www.4shared.com/file/11799703...0GXBE_R1_.html
TA790GXE(R1)
http://www.4shared.com/file/11799719...0GXE__R1_.html
TA790GXE_128M(R1)
http://www.4shared.com/file/11799712...128M__R1_.html
you would like to try it at your own risk
Junior
__________________
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar X58A - 920~Gulf - G.SKILL2000CL8 - GTS250 - Hitachi 40gb 7200 - Giga-EZ 1000w
Kids
P4GD1 - Pentium M 740 - XMS Xpert400 - Gladiac 7900GTX - Raptor 36GB - Aopen 560w
PcCI2iminal is offline   Reply With Quote
Old 07-15-2009, 12:29 PM   #2
MacClipper
Thanks but erm, no change notes at all?
__________________
'He is no fool who gives what he cannot keep to gain what he cannot lose' - Jim Elliot
Click on the pic to download a free pdf sample of the bestselling book!
| Soldam S10 | SLB8V | TRUE120 | DFI Jr P45 | 4GB RAM | HD3870 | 5 x DVDRW | 2407FPW | MW550 |
MacClipper is offline   Reply With Quote
Old 07-15-2009, 05:06 PM   #3
luismenendez
i am afraid I forgot how to flash a bios (only remember to flash a gfx!)
__________________
Phenom II - BIO TA790GX 128M
Corsair XMS2 2X2048 8500C5C - ATI 4890
2xHP L2045W-Tough Power 700W Modular
luismenendez is offline   Reply With Quote
Old 07-16-2009, 07:52 AM   #4
PcCI2iminal
Xtreme Family
Fix Phenom II BE when change CPU multiplier can't work
save the rom in USB Flash Drive,the only requirement is that should be formatted for FAT16 or FAT32 file system. If you wish to launch BIO-Flasher Utility, press F12 on boot-up.
__________________
Mojo
Family
Criminal
Kids
Old 07-16-2009, 08:35 AM   #5
>HyperlogiK<
>HyperlogiK<'s Avatar
Sweet! How many freakin' boards did Biostar put out based around the 790GX?
>HyperlogiK< is offline   Reply With Quote
Old 07-16-2009, 08:43 AM   #6
PcCI2iminal
Xtreme Family
10
__________________
Mojo
Family
Criminal
Kids
Old 07-17-2009, 01:33 PM   #7
MacClipper
TA790GX XE
Tried the above and it works not bad at all. It IDs the stock dualcore x550 correctly and unlocks it too but the 1st boot may give you rather high Vcore settings so quickly get around to setting it right. Changing the HT frequency may confuse the BIOS into calling the CPU as an AMD Engineering Sample though, HT1.8. IDs OK but HT2.0 IDs as AMD ES on my 550x2@x4.
Thanks PcCI2iminal, pls keep up the good work.
__________________
Old 07-18-2009, 05:40 PM   #8
luismenendez
thanks.
can i use the bio-flasher with a modded bios? do i have to install the program or just to press F12? By the way I got a BIO TA790GX 128M
thanks again
__________________
Old 07-18-2009, 06:04 PM   #9
denice25
Banned
very nice links.... thanks for the share man...
denice25 is offline   Reply With Quote
Old 07-18-2009, 06:52 PM   #10
PcCI2iminal
Xtreme Family
thanks.
thanks again
just press F-12
__________________
Mojo
Family
Criminal
Kids
Old 07-18-2009, 07:52 PM   #11
MacClipper
Mixed news update:
BIOS IDs chip correctly when HT is set to 2.2.
S3 resume is now broken when HT is set beyond 1.6, argh!
__________________
Old 07-19-2009, 09:22 AM   #12
leotonch
Hi PcCI2iminal,
I am using 790gx xe with the beta 715 bios, which give me 4 core ! But no matter what voltage I give or lower the CPU to 1.6G, 1 of the core fail immediately in prime95 or LinX after 1 loop !
Interesting thing is that it pass 1 hr AMD Overdrive stablility test & CPU burn-in test without any problem !
So is it a bios issues like those early MSI bios before.... Or is my 550 is just stable for 3 core ?
leotonch is offline   Reply With Quote
Old 07-20-2009, 07:17 AM   #13
Tom128
Would this let the XE run my 955BE? I was surprised last night when I put my 955BE in there and it was detected correctly but locked it down to 800Mhz and was impossible to change with BIOS, K10stat, AOD, or any other method. I see that the 955BE is not officially supported which was my guess as to why it was not working, but I see plenty of other 125W CPU's that are, and in fact the origional Phenom 9950 at 140W is even supported. Was hoping to turn the XE into a nice LAN PC until I saw the issue.
Tom128 is offline   Reply With Quote
Old 07-20-2009, 07:57 AM   #14
PcCI2iminal
Xtreme Family
Mixed news update:
I never use the S3 resume but i will check for you
tahnks
Originally Posted by leotonch View Post
Hi PcCI2iminal,
hello
well, i think the problem is your X2 550
what kind of XE you own?
__________________
Mojo
Family
Criminal
Kids
Old 07-20-2009, 08:33 AM   #15
Tom128
I believe there is only one revision correct?
http://www.biostar-usa.com/app/en-us...n.php?S_ID=375
I purchased this one open box I believe:
http://www.newegg.com/Product/Produc...82E16813138140
Old 07-20-2009, 07:08 PM   #16
MacClipper
Thanks man cos I always use S3 so I am stuck with HT 1.6K atm.
My 0923APMW early UVOC attempts (BIOS Vcore 1.2875V), running the chip as a tri-core ie. x3, it's plenty fast still despite 1 bad core. Using PcCI2iminal's BIOS on my 790GX XE.
__________________
Old 08-18-2009, 06:20 AM   #17
joncenawordlife
i have a amd 720be with batch no. 0907cpmw on biostar 790gx a3+ ddr3 board, bios ver.080014 rev.00 date 04/24/2009
i m unable to unlock my 4th core of amd 720be
so which of the above bios suits me??
joncenawordlife is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
