Nice "rack" Criminal haha. Nice results there.
Nice, but the volts are way too high. What were the temps anyway?
AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
4.4GHz with 25ºC ambient is awesome!
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
I want to see LN2 results.
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
nice
sorry for my bad english
Gigabyte Battlefield Pi 1M #3
Nice looks like next upgrade!
nice chip! awaiting for more results...
whau, nice...How its stable, its possilbe 4200MHz for benchmarking?
ROG Power PCs - Intel and AMD
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
Kids
P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
Criminal, how is the NB clocking on that chip?
4.4GHz on air in a 25ºC ambient means 4.2GHz benchable i think, which is very nice but if CPU-NB won't cooperate it ain't much.
Can it do 3GHz on air?
So nice !!!
I realy need to replace my 940 soon :P Its now running only 3.4 .... (i want to leave it at stock volts for 24/7 usage)
System Specs: -=Game PC=- | -=Lan Box=-
yes i can run at 3GHz on air
i think that chip will be great for you my friend
Bob,i think you will love it
6150MHz with 1.58v
http://valid.canardpc.com/show_oc.php?id=600281
Mojo
Family
Criminal
Kids
990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
Is the OPN HDZ965FBK4DGI?
Yes will be sweet to attain stable 3.0Ghz for NB on Air, mine 955 really dont like any kind of voltage. max 1.43/1.28V for stable operation (3.75/2.65Ghz)... I can bench 1.47/1.32V (@3.9 /2.8Ghz) but there is no way to make it stable for everyday use...
4.0/3.0Ghz @ 1.42V/1.30V 24/7 stable would be a great performance gain for an Aircooled OCed system.
What is the max OC at stock volts?
Looks pretty sweeet man, congrats!
RIG
CPU: AMD Phenom II X4 955BE @ 3.6GHz (stock V) w/ Prolimatech MegaShadow+Enermax Apollish (Silver)
M/B: MSI 790FX-GD70 NB & HT @ 2.4GHz (stock V)
RAM: A-DATA HY63I1B16K w/ HeatSinks
GPU: Sapphire 5850 1GB (Game Edition) @ 775/1125 (stock V)
HDD: 2 x Seagate Barracuda ST31000524AS
CSE: NZXT Apollo (Silver)
PSU: Ultra LSP650
MON: Samsung T260
K/B: Logitech G11 / Mse: Microsoft Sidewinder X8
Spk: Roccat KAVE 5.1 Headset
very good chip!
how much vNB to get 3 ghz on it?
vNB defaut (for 2000 mhz) is 1.1v?
Phenom II X4 805 @ 3500 | Phenom II X4 965 BE @ 4 ghz cooled by Noctua NH-U12P - ASUS M4A79T dlx - Asrock M3790GX - 3x 2048 Gskill Trident 2000 - 3x 2048 OCZ platinium 1600 - ASUS 4870 X2 TOP - Corsair TX850
yes, default CPU-NB is 1.1V, i think, for 3000MHz u need about 1.45-1.55V
tks.
1.35 vNB is sufficient to 2700-2800?
How much OC this 965 obtain under Windows Vista/Windows 7 64 bits?
Above is running XP 32 bits and by experience, under 64 bits OS's, OC is poor.
I have only x4 955 and i have XP 32 and Win 7 64-bit. In XP i have max stable OC 3.88GHz and in Win 7 3.797GHz. In x64 its harder got higher clocks with Phenoms
I have a 955 BE and tested 3800 1.55 vcore on Vista business x64. 3.9 on this vcore is VERY instable.
Board is ASUS M4A79T Deluxe
cooling is noctua NH-U12P
amb. temp is 26-28ºc (Lisbon is very hot)
