Parts:
CPU: Q9450 @ 3.6Ghz(OC'd)1800Mhz FSB
Mobo: EVGA 780i
GPU: HD 5870 (I have two but only got one in at the moment)
PSU: 1000w Corsair
Ram: 4GB Corsair dominator DDR2 1066Mhz
Soundcard: Asus Xonar D2
Monitor: Samsumg 226BW 22" and secondary 17" LCD
Speakers: logitech Z5400
Case: Tj07 fully sleeved wires
Water cooling:
Loop 1: Mobo NB & Mofset with Zalman resorator
Loop 2: CPU (Ek supreme) with MCP 355 XSPC acrylic top 360 & 240 mm rad
Here's another update after the rest of the parts arrived. This last part (finishing off) is the most complicated and boring because there's so many little details to take care of
A little trick to place two HDDs in a 5 1/4" bay:
Ooooo, mind telling me what these are and where ya got em? They could help immensely with my build....
thanks!, and great build, loving the backlit motherboard tray idea!
Everything is very clean and well executed... and I too like your puddy tat.
Thanks Charles! Wouldn't be possible without the MM sleeving
Originally Posted by WatZp
Great job. What compression fitting size you use on NB?
These are 3/8 ID and 5/8 OD fittings from Enzotech as used in the whole build
Thank you, and sorry for the late reply
I can't remember the brand i used (threw the boxes away) but they are similar to these here and are widely available.
Originally Posted by RCG_Bex
Ditto!!!
Lovely and clean lookign build - look forward to final pictures
~Bex
Thank you!
The side panel is *finally* going for the final mod (tinted acrylic window) next monday, so in about a week or maybe less i'll have some photos to show of the final product. Meanwhile i ditched the two GTX280's and got for an extra €20 plus the money from selling the 280's a GTX295 Co-op. The overclocked card performs about the same as the two 280's even though it's only 448-bit and 896MB per GPU but heats way less and doesn't draw as much power.
This is how it turned out, i'm using the second PCI-E slot for even better cooling:
Haven't been at home during the day, those pictures are crying for proper lighting Let's hope the final ones are better
Well, here she is at long last, the side window has arrived. Unfortunately a darker acrylic wasn't available, so a transparent version was used. Here are the final pictures:
Case how it looked when the side panel went for modification:
I installed a black acrylic panel made by the same person who made the side panel window (thanks Patuga @ www.coldzero.pt) so it covers the drive cage side:
The long awaited side window:
Internal thermometer can now be seen clearly, i'm sorry about the pictures quality, it looks WAY better live:
Something else was added, AlphaCool LCD which unfortunately was returned to RMA with two dead vertical lines after 4 days of use:
Would you be able to tell me when there are two HDDs installed in that little contraption, what are the dimensions of space the HDDs are now taking up? I just want to know how tall it is, so I can work out if I can use those nexus mounts for my HDDs. I have limited space so I need to pack the HDDs in as tightly as possible.
The height is about 6,5cm. Sorry for replying only now
Originally Posted by sniperbob
Really clean looking setup you have there! Can i request a nice night shot to show off all the insane lighting going on inside the case? PLEASE??!?!
Thank you. I am a mess taking night shots, but i will try to get some and post them here ASAP
hey namco how many uv lights are you using and where? ... Thanks
Hello, just one. It's hidden on top, just above the acrylic window
Originally Posted by Neox69
Wow.... I like! might get one of those screens...
Yeah, it's interesting, allows you to monitor what's going on with your CPU and GPU while gaming, i already found some interesting facts about some applications because of it
