Has anyone been able to use logmein with vista or win7 x64? and not have issues with smp (Folding@home-Win32-x86.exe)
It works fine if smp is not running. but about 90% of the time when I log into the machine with logmein for remote with smp running.. I get a window that says the smp has died. and sure enough, check the logs and what I see is listed below.
for example here's where I lost a smp wu at 96% this morning when I logged into it.. and it took me twice to log into it because of logmein hang issues with with Folding@home-Win32-x86.exe
and this is what I find when the desktop finally comes up...
finally I had to give up and physically go to the machine to get the clients restarted. and this is what the log looked like.
Code:
[05:56:59] Completed 465000 out of 500000 steps (93 percent)
[05:57:00] Extra SSE boost OK.
[05:57:00] Client no longer detected. Shutting down core
[05:57:00]
[05:57:00] Folding@home Core Shutdown: CLIENT_DIED
[05:57:00] Finalizing output
[05:57:00] 0000 out of 500000 steps (94 percent)
[05:57:00] Writing local files
[05:57:00] Completed 475000 out of 500000 steps (95 percent)
[05:57:01] Writing local files
[05:57:01] Completed 480000 out of 500000 steps (96 percent)
[05:57:01] Client no longer detected. Shutting down core
[05:58:28]
[05:58:28] Folding@home Core Shutdown: CLIENT_DIED
[05:58:28]
[05:58:38] eck for stray files
[05:58:38] elete work/wudata_00.goe
[05:58:38] Warning: check for stray files
[05:58:58] ome Core Shutdown: CLIENT_DIED
[05:58:58] Finalizing output
[06:00:38] utdown: EARLY_UNIT_END
[06:00:38] Finalizing output
[06:00:38]
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [May 18 06:15:59 UTC]
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.23 Beta R1
http://folding.stanford.edu
Launch directory: D:\Software\Folding\smp1
Executable: D:\Software\Folding\smp1\Folding@home-Win32-x86.exe
Arguments: -smp
[06:16:00] - Ask before connecting: No
[06:16:00] - User name: mikeb12 (Team 36362)
[06:16:01] - User ID: 4C67D13127F9E3C3
[06:16:01] - Machine ID: 1
[06:16:01]
[06:16:02] Loaded queue successfully.
[06:16:02]
[06:16:03] + Processing work unit
[06:16:03] Work type a1 not eligible for variable processors
[06:16:03] Core required: FahCore_a1.exe
[06:16:04] Core found.
[06:16:04] Using generic mpiexec calls
[06:16:05] Working on queue slot 00 [May 18 06:16:05 UTC]
[06:16:05] + Working ...
[06:16:06]
[06:16:07] *------------------------------*
[06:16:08] Folding@Home Gromacs SMP Core
[06:16:08] Version 1.74 (March 10, 2007)
[06:16:10]
[06:16:10] Preparing to commence simulation
[06:16:11] - Ensuring status. Please wait- Created dyn
[06:16:12] - Files status OK
[06:16:23] - Working with standard loops on this execution.
[06:16:24] - Previous termination of core was improper.
[06:16:24] - Going to use standard loops.
[06:16:25] - Files status OK
[06:18:23]
[06:18:23] Folding@home Core Shutdown: MISSING_WORK_FILES
[06:18:23] Finalizing output
[06:18:26] CoreStatus = 1 (1)
[06:18:26] Sending work to server
[06:18:26] Project: 2653 (Run 24, Clone 160, Gen 108)
[06:18:26] + Attempting to send results [May 18 06:18:26 UTC]
[06:18:27] + Results successfully sent
[06:18:27] Thank you for your contribution to Folding@Home.
[06:18:47] - Preparing to get new work unit...
[06:18:47] + Attempting to get work packet
[06:18:47] - Connecting to assignment server
[06:18:48] - Successful: assigned to (171.64.65.64).
[06:18:48] + News From Folding@Home: Welcome to Folding@Home
[06:18:48] Loaded queue successfully.
[06:19:10] + Closed connections
[06:19:15]
[06:19:15] + Processing work unit
[06:19:15] Work type a1 not eligible for variable processors
[06:19:15] Core required: FahCore_a1.exe
[06:19:15] Core found.
[06:19:15] Using generic mpiexec calls
[06:19:15] Working on queue slot 01 [May 18 06:19:15 UTC]
[06:19:15] + Working ...
[06:19:15]
[06:19:15] *------------------------------*
[06:19:15] Folding@Home Gromacs SMP Core
[06:19:15] Version 1.74 (March 10, 2007)
[06:19:15]
[06:19:15] Preparing to commence simulation
[06:19:15] - Ensuring status. Please wait.
[06:19:32] - Looking at optimizations...
[06:19:32] - Working with standard loops on this execution.
[06:19:32] - Previous termination of core was improper.
[06:19:32] - Going to use standard loops.
[06:19:32] - Files status OK
[06:19:43] Starting from initial work packet
[06:19:43]
[06:19:43] Project: 2665 (Run 1, Clone 98, Gen 118)
[06:19:43]
[06:19:44] Entering M.D.
[06:19:44] ne 98, Gen 118)
[06:19:44]
[06:19:44]
[06:19:51] Rejecting checkpoint
[06:19:52]
[06:19:52] Writing local files
[06:19:52]
[06:19:58] Extra SSE boost OK.
[06:19:59] Writing local files
[06:19:59] Completed 0 out of 250000 steps (0 percent)
man, these freekin baby sit issues never cease...
I've tried activex, mozilla, java, and html modes. and they all do it...
the gpu is fine. but logmein kills smp every freekin time... something to do with the login from logmein fights with Folding@home-Win32-x86.exe, makes it stop responding, hangs the logmein console, then closes itself and unhangs the console. what a pita. I guess it's impossible to remote into a rig that's on smp in v64 or win7 64.. remote works for pretty much everything else on the pc, but if that smp client is running, you might as well take some tylenol, because the headaches are comin'...
anyone?
with no solution to this, my only option is to stop smp folding when I'm out of town and need remote access to these rigs.
