Hey everyone!
I decided to pimpmod my Coolermaster Cosmos 1000.
Goals to achieve:
-Hide cables as much as possible
-Clean looking case
-Silver, (I always had black cases or black interior in previous cases)
-Radiators, pump and reservoir not visible (for a change), only tubing visible.
-The metal panels have to have holes where the tubing can stick through.
- 2 Tubings directly to the CPU, 2 Tubing directly to the GPU (Clean look)
CPU will have blue UV tubing, GPU will have green UV tubing.
-Case will have new sidepanel with Windows.
-Most important, project has to be CHEAP, as much recycling as possible
-Pump and Res have to go in the 5,25inch bays (tight fit, really tight.
-Fan controller on the top front panel (Plastic panel with USB ports and power button etc)
I will post pictures laterz!
