XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods
Reply
Old 03-25-2009, 09:01 PM   #1
rakesh_sharma23
rakesh_sharma23's Avatar
DIY VGA Waterblock for HD4850
I have made the waterblock for my HD4850 GFX Card.
Have a look. 100% passed leak test.
Will test it on sunday... Hope to give you performance report soon.
rakesh_sharma23 is offline   Reply With Quote
Old 03-25-2009, 09:38 PM   #2
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
isn't the hottest looking thing but as long as it cools better than stock, then it's a job well done
__________________
WhiteFireDragon is offline   Reply With Quote
Old 03-25-2009, 10:10 PM   #3
Coldon
Coldon's Avatar
Send a message via MSN to Coldon
i'm gonna assume that mini heatsink inside is made from aluminum... nuff said...
__________________
Inside: i5 750 @ 4.1ghz 1.36v 24/7, ASUS P7P55D Deluxe, 8GB G.Skill Ripjaws DDR3 2000, INNO3D GTX480, 3x1TB Seagate 7200.12 HDDs
Case & Cooling: CM ATCS 840, Corsair HX620 PSU, Swiftech Apogee GTZ, Koolance Vid-NX480 FC, Swiftech MCR320 Rad + XSPC RS240 rad, DDC 3.2 with XSPC Bay Res One.
My tech blog (Game Dev, AI and Graphics Programming) - http://takinginitiative.net
Coldon is offline   Reply With Quote
Old 03-25-2009, 10:29 PM   #4
rakesh_sharma23
Thanks Guys.
Try it on sunday.....Hope it will work great.
Yes inside is a small Aluminium heatsink.
Old 03-26-2009, 01:27 AM   #5
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Galvanic corrosion could be an issue. Otherwise, very nice job, 10/10!
tiborrr is offline   Reply With Quote
Old 03-26-2009, 01:34 AM   #6
rakesh_sharma23
Galvanic corrosion will kill this block in about period of more then 30 years....(according to Galvanic corrosion Calulations between Copper and Aluminium considering the thickness of both metals)
30Years is long time ..may be till then we may have Cpu with speed like 2.4THz... How cares..
So dont worry about Galvanic corrosion..
Old 04-23-2009, 03:24 AM   #7
rakesh_sharma23
All SET up Ready to go....
Old 04-23-2009, 09:11 AM   #8
Slibri
interesting hard drive mountage how'd ya do it?
Slibri is offline   Reply With Quote
Old 04-23-2009, 11:18 AM   #9
JamesBong420
JamesBong420's Avatar
looks like he drilled holes in the side of the plexiglass and mounted it...
__________________
Revolution OS
JamesBong420 is offline   Reply With Quote
Old 04-23-2009, 12:55 PM   #10
Nanometer
Xtreme Mentor
Nanometer's Avatar
Send a message via AIM to Nanometer
great effort, but you get 7/10 for using aluminum
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Enermax Liberty 620
Nanometer is offline   Reply With Quote
Old 04-24-2009, 12:32 AM   #11
rakesh_sharma23
Thanks Every one .. Yes Mr. JamesBong420 you are right about HDD mounting.
Old 04-28-2009, 09:14 AM   #12
rakesh_sharma23
With request from many members about galvanic reaction in my VGA block. I have removed my GFX block and now working on full copper block , till then
Some New updates
1.
New PUMP gift from a DIY fan from Goa, India ...Cool AC 220V Pump. New tubes and a drain outlet tube added with a T- joint . SMPS also modded with a relay base switch for pump, so pump starts and shut down automatically with PC.
2.
Two Seagate 500 GB 32MB buffer Sata HDD in RAID0..
A recognizable difference in system Speed. Now i believe that RAID do works.
SYSTEM
Old 04-30-2009, 04:22 PM   #13
Slibri
interesting tube job... the block looks really good too and how did you attatch the acrylic to the copper
Old 04-30-2009, 10:15 PM   #14
rakesh_sharma23
Industrial Epoxi Glue. Rock Solid
Old 05-06-2009, 11:41 AM   #15
=ACID RAIN=
=ACID RAIN='s Avatar
Good for a first-time home design. I would fill in some gaps and have inlet and outlet set up across a straight-finned heatsink though.
__________________
Gamer: Q6600 G0 3.6 1.4v . Abit IP35 Pro . 2GB Ballistix 800 . eVGA 8800GT . 560w SS Zeus . 320GB SATA . 36GB 10k SATA
Wife's: E6300 . Asus P5B . 2GB G.Skill 800 . eVGA 7900GT . 500w OCZ . 2 x 120GB PATA
File Server: E6600@3GHz . GA-G31M-S2L . 1GB Adata 800 . 500w . 4x400GB RAID5 on S150 SX4 . 120GB SATA
HTPC: Opteron 146 . K8n Neo-2 Plat . 2GB PC3200 . 9800 Pro . 480w . 80GB IDE
Laptop: Dell Vostro 1700 . T7300 2GHz . 2GB DDR2 667 . 8600M GT 600G/500M/1200S . 160GB SATA
Heatware
=ACID RAIN= is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
