XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 03-17-2009, 05:46 PM   #51
sjg0
sjg0's Avatar
Originally Posted by supercoolin View Post
yep $19.95 ea shipped x 3, everything else was hand built (i.e. oil sep, accum, receiver, condensers, de-heaters). The Freeze Pack controller represents the big bucks on this build.
You hand built those condensers?
__________________
#1
Pentium D805 @ 3.4Ghz on GA-945P-S3
2Gb OCZ Gold 800 with XP Professional SP3
Ati X1800XT
550W Antec TruPower in Antec Sonata II
#2
Core 2 Quad Q9550 on GA-EP45-UD3P
4Gb Corsair Dominator 1066 with Vista Ultimate SP1
Asus 4850 TOP
750W PC Power & Cooling in ????
There is not enough electrical oulets in my room.
Best TF2 Quote:
"tomtom92 : wtf the enemy has a base IN our base"
sjg0 is offline   Reply With Quote
Old 03-18-2009, 09:55 AM   #52
supercoolin
supercoolin's Avatar
I believe you understand the point I was trying to make. I found old pieces of condenser coil and cut out the sizes that I needed and re-built them. Free except for the Silvaloy brazing rods to braze up the relocated 180 bends. Shrouds and end caps were made out of sheet metal and plate aluminum scraps laying around the garage, $5.00 vs $200.00 if bought off the shelf.
__________________
Asus M3A79-T
AMD Phenom II @ 4.42Ghz
Diamond 4870X2OC QuadFireX
4GB G.Skill DDR2 PC1200
Danger Den 4870x2 GPU Coolers
Cascade Phase Change
Koolance HD & Memory Liquid Cooling
Danger Den Pumps & Radiator
Modified Kooloance PC4 1036SL Case
Antec 1000W Power Supply
http://valid.canardpc.com/show_oc.php?id=467727_______________________________________________
supercoolin is offline   Reply With Quote
Old 03-18-2009, 09:59 AM   #53
supercoolin
Originally Posted by Jor3lBR View Post
You said you were in California?
Las Vegas, Nevada
__________________
Asus M3A79-T
Old 03-18-2009, 02:53 PM   #54
tiborrr
-100c Club
tiborrr's Avatar
Send a message via ICQ to tiborrr Send a message via MSN to tiborrr
Keep up the good work, supercoolin, and don't be afraid to show more progress! We are waiting!
tiborrr is offline   Reply With Quote
Old 03-18-2009, 04:36 PM   #55
supercoolin
1st stage condenser
Well as I wait impatiently for the second case I bought off eBay, I went ahead and started the condenser for the 1st stage. I took and old 3KW unit with 3/8" rifled tubes and cut it down to 6.5" x 18" x 3". This will go in the top of the case with 4 115cfm 120mm fans pulling air through it. Cost for this, 2 hrs labor, 25cents with of acid and two sticks of Silvaloy brazing rod @ $1.15 ea. Oh and 2.00 worth of 24ga sheet metal for the shroud. I post another pic of it mounted in the case when its done.
Also when I evac'd the 2nd stage, I decided to run a little freon through it and then change out the filter before final charge to make sure everything was mostly clean. Since R-134a is pretty good at picking up about any and all types of residue or residuals, I charged it with full 15oz. can full. It pulled down to -31C in less than 30 sec with 13" vac low side and 110PSI high side. As the accumultator began to chill down to -10C, the evaporator went to -45. When it hit -45 on R-134a, I had to conclude that mounting the spun filter/drier inside the accumulator and having the cap tube completely enclosed within the suction line was acting as a sub-cooler or even as far as the system was acting as an autocascade. This could end up pretty interesting once it is all put together, heck it might even end up being a autocascade on top of a full cascade (say 3 stage?) This is turning to be pretty damn fun.
BTW the oil seperator is working like a champ, oil level has stayed within 25cc's of the initial pre-charge and there has been no flucuation of the low side pressure that would occurs if the oil level drops below the auto re-feed port. I am pumped!!!
__________________
Asus M3A79-T
Old 03-18-2009, 06:33 PM   #56
sjg0
sjg0's Avatar
Omg no actually I didnt realize that. Thats amazing bro! I said that because the pics of the condensers you posted looked like you bought them, upon closer inspection i can see now they have been made by you, lol mucho props! They look really great!
__________________
#1
Ati X1800XT
#2
Asus 4850 TOP
Best TF2 Quote:
Old 03-19-2009, 10:15 PM   #57
supercoolin
Progress Update
Well as I impatiently wait for the second V2000a case, I went ahead and finished up the 1st stage condenser and started to fit up the piping so I can just braze it up once I mount everything in the case.
2nd stage is running with R134a and a 75W load and staying at -42. I have been running it a couple of days and have been pulling it down to check oil seperator flow and then recycling the charge. So far after about 40 hrs of run time, it looks like my guess on cap tube size for the return was dead bang on, staying at proper level and no added oil. Absolutely pure damn luck.
Looks like everything will fit pretty tightly, but fit it will. Coolant is actually runner through the HX to test the systme and oil sperator operation. Full sight glass of R134a at 95PSI high side..
__________________
Asus M3A79-T
Old 03-19-2009, 10:16 PM   #58
teyber
Xtreme Mentor
teyber's Avatar
AHAHA how low of a vacuum is your second stage in?
looks great, i really love it!
teyber is offline   Reply With Quote
Old 03-19-2009, 10:39 PM   #59
supercoolin
THANX.....
12.6 in.Hg. I would have never believed I could pull those kinds of temps with R134a, I will have another tank of HC502a on Tuesday, so I will have see what that will do before I final charge it with R1150.
__________________
Asus M3A79-T
Old 03-20-2009, 01:24 AM   #60
Odium
Send a message via AIM to Odium
Very impressive!
Odium is offline   Reply With Quote
Old 03-23-2009, 07:13 PM   #61
supercoolin
not much happening until case arrives
been fitting up the plumbing waiting for the new case to arrive. It's on the UPS truck and scheduled for delivery tomorrow. Hopefully we will be making frost with the 1st stage this weekend (have a little right now on the 2nd stage piping..hehe)
__________________
Asus M3A79-T
Old 04-20-2009, 11:05 AM   #62
supercoolin
Missing Posts?
Well not sure if I should post the pictures and progress that has been deleted during this last "Outage" but have been doing testing and tune and she seems to be pretty healthy. While I am waiting for the ethylene to arrive I charged the second stage with R507. Three separate start up and she holds -83 with the R507 and no insulation on all the piping. Looking forward to see what happens with it charged with the R1150. Hope I will get into the -100 club.
__________________
Asus M3A79-T
Old 04-20-2009, 11:39 AM   #63
teyber
Xtreme Mentor
teyber's Avatar
wow nice! and you got tons of room for a third sta.... haha just playing. it looks seriously sweet!
Old 04-20-2009, 12:00 PM   #64
sdumper
-100c club
sdumper's Avatar
Amazing how compact and clean everything is!!!
Great work!!!!!!
__________________
http://valid.canardpc.com/show_oc.php?id=606830
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
sdumper is offline   Reply With Quote
Old 04-21-2009, 07:59 PM   #65
supercoolin
Next one will be a real 3 stage...this was my 1st attempt at a cascade to see if I could even build one and just get a stable -60 under load. It works much better than I had hoped so now I think I can tackle a real system.
__________________
Asus M3A79-T
Old 04-21-2009, 08:00 PM   #66
supercoolin
Great work!!!!!!
thanks for the kind words but it was a lot of compromises to make things fit and sacrific clean lines.
__________________
Asus M3A79-T
Old 04-21-2009, 11:43 PM   #67
bazx
-100c Club Member
bazx's Avatar
working to a set size is very difficult if not the hardest way to build
and you have carried it off very well
i think that you will enjoy a bigger build with more room to work
3 stage cascade is a great deal of fun to build good luck
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
bazx is offline   Reply With Quote
Old 04-22-2009, 07:00 AM   #68
supercoolin
It was a challenge build and the most exciting part is the oil separator. I couldn't find anything small enough to work in my tight spaces so it was "Build-your-own" time. It is working flawlessly without any floats or valves, it is fully automatic and actually works!!! Everything else is so basic in design (Accum, Reciever, cond., evap.) that I wasn't worried about function, the oil separator was the real challenge on this project. And I have achieved my -60 loaded cpu target with only 52db.
__________________
Asus M3A79-T
Old 04-22-2009, 08:11 PM   #69
supercoolin
A little update
When I joined this forum and started looking through some of the incredible projects here, I never dream I would be able to take three $20.00 compressors I bought off ebay and throw together a bunch of home-made parts and get -90 on straight R507. After a little adjustment of the gases in both stages and a 20min run with 50watts load, she held -88 with a low of -90. This stuff is totally cool...............Thanks guys for all the systems you have shared on this forum and the inspiration I have gotten readin about them, to even attempt anything like this.
__________________
Asus M3A79-T
Old 04-22-2009, 08:33 PM   #70
supercoolin
forgot the picture
Using R507 on the 1st stage 0psi low 260psi high 8K superheat
R507 on the 2nd stage -28inHg low +0psi high 5K-11K superheat (moves around over 5 minutes, need smaller fan @ super de-heater coil
HX temps
at the expansion valve -55, out of the HX -44 @bulb
2nd stage condsensor coil in 23, liquid out -35
2nd stage accum/sub-cooler combo -68
cpu evap with 50Watts -88
friggin can't wait for the R1150
all three little rotary's are running about 45-50, considering adding water coils around each to add a little compressor cooling.
__________________
Asus M3A79-T
Old 04-23-2009, 04:22 AM   #71
Jack
Jack's Avatar
Looking really nice and compact! What load are you aiming for with the R1150?
And why water coils? Those compressor donīt run hot at all... well, not yet anyway (the ethylene will make the compressors work harder).
__________________
Intel Core2Duo E6600 ES | Asus P5WDH Deluxe | 4x 1GB TeamGroup PC5300 | Asus ATI X300SE | OCZ PowerStream 520
Intel Pentium 2160 | Gigabyte GA-P35-DS3P | 2x 1GB Crucial PC5300 | Diamond S3 Virge | Corsair 520HX
Jack is offline   Reply With Quote
Old 04-23-2009, 10:25 PM   #72
supercoolin
I am shooting at -60C with a 130W load (Phenom II at 4.8Ghz)
I am going to try and add a little water cooling to the compressors because I believe if I can drop the compressor temps 10-15C, it should add 200-300W of capacity to the 1st satge.
__________________
Asus M3A79-T
Old 05-16-2009, 03:04 PM   #73
fitseries3
Send a message via MSN to fitseries3 Send a message via Yahoo to fitseries3
i love this build. very nice.
are you using the 2 compressors in the 1st stage and a 3rd in the second stage? so thats ~10k btu in the 1st stage and 5200btu in the second?
(sorry for the noobness, still learning here)
__________________
My Heatware
Xeon w3520 w/ EK Supreme LT Acetal
3x2gb Mushkin Redline Ascent (Elpida BBSE)
EVGA 760 w/EK FC Acetal
3 EVGA gtx295's
Enermax Galaxy EVO 1250watt
SST Ultradrive GX 64gb
MountainMods Ascension Crystal Ship CYO
2 HWlabs 560GTX's + HWlabs 280GTX + Iwaki rd30 + 10 delta FFB1424SHG's
fitseries3 is offline   Reply With Quote
Old 06-05-2009, 05:08 PM   #74
supercoolin
Here is the money shot - I just joined the -100C club
Well the tune is done and the mix works. I still have a bunch more on the controls but she starts with a single button, full auto startup including the mobo with full Windows shutdown. This is with a 175W load.
Ambient Temp 28.5C
1st Stage R-507
245 PSI Static
-48C at the HX
3psi low / 235psi high
2nd Stage R1150 92%/ Propylene 8%
295psi Static
-29.3C out of the HX
-116C at the temp plate (1/4" plate between evap and load cell)
-8inHg Low/275psi high
1523W load reading on the Kill-a-Watt so i'm curious how it compares to the power used by other cascades (is it efficient or crappy)
THANX GUYS FOR ALL THE HELP!!!!!!!!!!!!!!!!
__________________
Asus M3A79-T
Old 06-06-2009, 01:31 PM   #75
paul_
I am Xtreme
Send a message via AIM to paul_ Send a message via Skype™ to paul_
Wow I want one!
__________________
New College rig, WIP - See my Worklog
CM HAF 932
Gigabyte EP45-UD3R
Xeon X3370 (AKA Q9650) @ 4.2
EVGA GTX 285 Hydro Copper
OCZ Reaper 2x2GB
Intel X-25-M 80GB SSD
WD 1TB Black
Changing every day...
paul_ is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
