XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 02-17-2009, 03:52 PM   #1
stingush
Gigabyte EP45-UD3P 675fsb nb on stock air.
with a lame E8400 and single stage.
The-Byter&stingeR gives you :
http://valid.canardpc.com/show_oc.php?id=510458
and 2nd place for Q9450
http://valid.canardpc.com/show_oc.php?id=510389
__________________
Q9450 @ 4ghz 24/7
Gigabyte EP45-UD3P
Hynix Value 2GB x 4 @ PC8500 15-5-5-5
Sapphire HD 5850 - Unlocked MSI bios @ 1000/1300 1.2Vgpu
4x250GB Seagate 7200.10 @ RAID 0 + SAMSUNG HD103SJ 1TB
stingush is offline   Reply With Quote
Old 02-17-2009, 04:32 PM   #2
chuchnit
chuchnit's Avatar
Send a message via MSN to chuchnit
675fsb? I take it this was with air cooled NB?
chuchnit is offline   Reply With Quote
Old 02-17-2009, 09:32 PM   #3
stingush
indeed.
no mods, aircooled.
simple as that.
__________________
Q9450 @ 4ghz 24/7
Gigabyte EP45-UD3P
Old 02-17-2009, 09:38 PM   #4
fatguy1992
Did you need to change the clock skews and clock drive settings? Also what VTT?
Awesome
fatguy1992 is online now   Reply With Quote
Old 02-17-2009, 09:46 PM   #5
Solid Snake
Solid Snake's Avatar
Send a message via MSN to Solid Snake
nice FSB, What Voltage do you use?
Good Work
__________________
"We Overclock and Crunch you to the Ground" - DDTUNG
Solid Snake is offline   Reply With Quote
Old 02-18-2009, 12:10 AM   #6
Pedropc
With that bios?
__________________
QX9650 | EVGA 790i Ultra SLi | CELL SHOCK PC3-14400 "D9GTR" | XFX 9800 GX2 | CM Real Power M1000
Pedropc is offline   Reply With Quote
Old 02-18-2009, 04:58 AM   #7
overcrash
overcrash's Avatar
Send a message via ICQ to overcrash Send a message via Skype™ to overcrash
Originally Posted by Pedropc View Post
With that bios?
I'd like to know that as well
__________________
24/7 Gigabyte EP45-UD3R|E8400 @ 4302 Mhz @1.344v|Corsair 2 x 1GB DHX @ 940 Mhz 2.06v|PNY 9800GX2 700/1750/1100|Cooler Master 690 + 3 x 140mm + 2 x 120mm|TRUE + 2 x 120mm|Chieftec 750-14C 750W
AMD makes it first, Intel makes it better
overcrash is offline   Reply With Quote
Old 02-18-2009, 06:08 AM   #8
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
Amazing. What a nice sample you got there.
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is offline   Reply With Quote
Old 02-18-2009, 08:22 AM   #9
stingush
what do you mean by sample man? everything here is retail out of the original box.
no change in clock skew's and other things... almost everything on auto except
cpu voltage/mch/ddr and memory timings...
everything else on auto and STOCK cooling.
2nd place for the Q9450 on HWBOT.
__________________
Q9450 @ 4ghz 24/7
Gigabyte EP45-UD3P
Old 02-18-2009, 10:42 AM   #10
loopy83
loopy83's Avatar
Send a message via ICQ to loopy83
All settings on AUTO and this amazing FSB... speechless...
Try to tweak some settings und go for a better NB cooling to show us the next 700MHz Board
__________________
loopy83 is offline   Reply With Quote
Old 02-18-2009, 11:22 AM   #11
WhiteFireDragon
Xtreme Cruncher
WhiteFireDragon's Avatar
Send a message via AIM to WhiteFireDragon
saying you did no tweaks at all is admitting either you just got lucky or it's a damn great board
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
WhiteFireDragon is offline   Reply With Quote
Old 02-18-2009, 11:35 AM   #12
stingush
isn't everyone getting lucky in OC? sure you need to do alot and test..
but still, the main thing here is LUCK.
just for the record... thats an AWSOME board. thats all i can say..
and i think i can get more than that.. almost sure
__________________
Q9450 @ 4ghz 24/7
Gigabyte EP45-UD3P
Old 02-18-2009, 11:39 AM   #13
Hondacity
congrats with the world record
how did those cpu perform on your dfi?
Hondacity is online now   Reply With Quote
Old 02-18-2009, 11:50 AM   #14
dany74q
dany74q's Avatar
Very impressive results youv`e got there .
Amazing numbers for an air cooled board,any luck to reach 700FSB?
__________________
i7 920@4.2GHz with custom water cooling
EX58-UD3R (Temporary)
G.Skill 3GB 1600MHz NQ (Temporary)
Sapphire 3870X2 (Temporary)
Seagate barracuda 7200.11 500GB 32MB X2
Samsung HD103UJ X3
WD 74GB Raptor
Hec Zephyr 650W
Antec P182
dany74q is offline   Reply With Quote
Old 02-18-2009, 12:00 PM   #15
WhiteFireDragon
Xtreme Cruncher
yeah, in a sense you're right. but i wouldn't imaging giving a nice CPU/board/memory with ln2 to a random person on the street and show him how to jack up the fsb will result in WR's. it does take some level of experience in the settings with the right hardware.
but i do applaud you for those number though
__________________
e8600 @ 4.5ghz
rampage extreme
hd4650 512mb
2x1gb tracers
audigy 2zs
120gb vertex
HX520w
Old 02-18-2009, 12:43 PM   #16
stingush
believe me, the fact that the board volts are on auto is also cause i tought he knows how much to give to each device on the board...
thats the exact same settings i'll run if i'll need to decide which to choose.
i tried alot of combinations and this one was the best..
sure i did hard work for this score, but most of it was the board itself.
__________________
Q9450 @ 4ghz 24/7
Gigabyte EP45-UD3P
Old 02-18-2009, 12:52 PM   #17
nikk
nikk's Avatar
sick oc grats which teamgroups are those mate? and at what voltage?
nikk is offline   Reply With Quote
Old 02-18-2009, 12:53 PM   #18
Mean Machine
Mean Machine's Avatar
Send a message via ICQ to Mean Machine
I just sold mine, didn't go past 552MHz FSB no matter how I raped it. Hugely impressive FSB on that board though!
__________________
I beat ME4ME in the 2009 Swedish GOOC Qualifiers!
I was equally bad as ME4ME at the ROG OC Showdown!
Mean Machine is offline   Reply With Quote
Old 02-18-2009, 03:39 PM   #19
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Motherboard (retail) sample? Sample is a sample, ES or engineering sample is a engineering sample, simple as that.
Anyways congrats.
__________________
Old 02-19-2009, 08:32 AM   #20
Bullet92
Bullet92's Avatar
Send a message via MSN to Bullet92
544MHz with Quad core cpu is very nice to see but the 675MHz result is also really impressive and yeah, that's all on stock cooling.
Congrats mate!
__________________
MBO Gigabyte MA790FXT-UD5P // CPU Phenom II 955 BE //
GPU 8800GT 512MB // PSU CoolerMaster Real Power 450W - fan moded //
RAM 2*1GB Ballistix 1800MHz // HDD 160GB Hitachi + Seagate 250GB (410AS)
Bullet92 is offline   Reply With Quote
Old 02-19-2009, 06:55 PM   #21
clo007
I am Xtreme
clo007's Avatar
Pretty nice. I hit 525 on my Q9550:
__________________
Gaming/Rendering rig:
Gigabyte EP45-UD3R
Q9550 GO OC'd 4ghz(471x8.5) with tuniq tower
8gigs G-Skill PI 8800s
eVGA 8800Ultra Vanilla w/backplate--700core/1127mem/1654shader
(1) 74gig Raptor 10k OS drive
(1)500gig seagate 7200.10 main storage
(2)320gig seagate 7200.10 sata extra storage
lite on 20x dvd-burner sata
corsair hx750 psu
antec 1200 case
clo007 is offline   Reply With Quote
Old 02-22-2009, 02:20 AM   #22
simone18
simone18's Avatar
i hit 520 with my xeon quad. this ud3 serie really rocks. obviously all air cooled :P
simone18 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
