XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 02-15-2009, 03:09 AM   #1
PcCI2iminal
Xtreme Family
PcCI2iminal's Avatar
Mojo Family playing AMD and 6GHz done with Biostar TA790GX3 A2+
After years we had a chance to play AMD once again.
Asus M4A79 Deluxe and Biostar TA790GX3 A2+
2 x Phenom II
A full Chilly1 POT
But we had some problems before the action,the MA479 wont boot with some good sticks of DDR2
Crucial BallistX 6400(D9G)/AxeRAM 1200(D9G)/Corsair XMS2(Unknow ic) = no boot
I used Team 1066MHZ (D9G) but 2,2v is needed to ran dual channel,anything less than 2,2v (single works fine) is a no boot but i have no stability at 1180MHz or greater.... but all these sticks runs great on Biostar and i dont need to push the vddr to 2,2v to boot with dual channel ,so its an Asus bios issues maybe
anyway ,here is the first scores with AMD plataform
Asus with Phenom2 940 BE (0849APBW) - few days ago
into windows at 5400MHz with all cores
the Magic6 is possible but with one core only...
single channel (6027MHz)
http://valid.canardpc.com/show_oc.php?id=496699
dual channel seems to be the same(6025MHz)
http://valid.canardpc.com/show_oc.php?id=496704
Ive tried several times but with all cores I only can reach 5850MHz(1,78v) and max vcore didnt help ...
http://valid.canardpc.com/show_oc.php?id=495680
Pi1m at 5800MHz
Biostar A790GX3 A2+ and Phenom2 940 BE(0852GPGW) - yesterday
I did a quick test and i reached 6Ghz+ but with no validation ,yesterday the cpuz was updated to 1.50 and i was tryin with old version hahahah
anyway the max screen with all cores is 5978MHz (1,8v)^^
and we maked a new session of benching a few hours later with the properly validation tools but with no luck , the best validation is 5939MHz with one core
http://valid.canardpc.com/show_oc.php?id=507402
Well,We are totaly AMD noobs and I dont know how really good are these cpus,with the old one (week 49) we can not reach more than 4Ghz on air and with the new(week 52) 4GHz is possible but only good for Pi1m and nothing more but it needs more than 1,6v.
anyway ,we are looking for big numbers and not air stability and next week i will re-run everything again and i will use Biostar + new F1-EE from Vince ^^
Thx Biostar TW for the great TA790GX3 A2+
__________________
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar X58A - 920~Gulf - G.SKILL2000CL8 - GTS250 - Hitachi 40gb 7200 - Giga-EZ 1000w
Kids
P4GD1 - Pentium M 740 - XMS Xpert400 - Gladiac 7900GTX - Raptor 36GB - Aopen 560w
PcCI2iminal is offline   Reply With Quote
Old 02-15-2009, 03:32 AM   #2
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
very nicely done damn soooo close to 6ghz with all 4 cores too.. well you know what you need to do... KEEP PUSHING IT
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 02-15-2009, 03:54 AM   #3
PcCI2iminal
Xtreme Family
thx my friend,
well, i need to learn how to use AMD again and some luck is welcome
__________________
Mojo
Family
Criminal
Kids
Old 02-15-2009, 06:02 AM   #4
ZoLKoRn
Xtreme X.I.P.
ZoLKoRn's Avatar
Send a message via MSN to ZoLKoRn
Congrats for 6GHz done ! and looking forward to next benching
__________________
Sorry For My English
OverclockZone Team
THAILAND
Originally Posted by hipro5 View Post
Actually there is NO NEED for 164 phases that companies put in nowadays mobos....
FOUR (4) are enough with nowadays materials and maybe SIX (6) with the upcoming Gulftowns....
The 1024 phases is a "marketing trick" nowadays....
You will buy MY mobo because I put 2048 phases in my motherboard....
ZoLKoRn is offline   Reply With Quote
Old 02-15-2009, 06:05 AM   #5
blind_ripper
blind_ripper's Avatar
Send a message via MSN to blind_ripper
nice work PcCI2iminal
__________________
blind_ripper is offline   Reply With Quote
Old 02-15-2009, 06:59 AM   #6
rbuass
Champion
rbuass's Avatar
Good work again
Let s see AMD growing...will be good
Hugs from Brazil
rbuass is offline   Reply With Quote
Old 02-15-2009, 10:31 AM   #7
Lightman
Xtreme News
Lightman's Avatar
Nice clocking on both samples
I'm really amazed by the Biostar, they seems to be doing what DFI was couple of years ago!
__________________
RiG1: Phenom II 940BE 0850BPEW (45nm@3850MHz 64bit), Gigabyte MA790FX-DQ6 (RD790FX), 2x2GB OCZ Reaper PC8500@1145MHz 5-5-5, HD5870 1GB, 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 400GB Samsung T133 + 30GB OCZ Solid SSD, Hiper 4M880
RiG2: HTPC AMD Athlon II 250, 2GB Crucial Ballistix D9, ASUS M3A78-EM, ASUS HD4670 512MB, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
SmartPhone T-Mobile Compact V
XBOX360 Elite paired with 52'' Samsung LCD TV
Lightman is offline   Reply With Quote
Old 02-15-2009, 10:51 AM   #8
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Great clocks!
Maybe you should give bios 0903 a whirl, it might play nice with your ram.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 02-15-2009, 11:44 AM   #9
George_o/c
George_o/c's Avatar
Send a message via MSN to George_o/c Send a message via Yahoo to George_o/c Send a message via Skype™ to George_o/c
Nice job Mojo Family
Where is the other girl ? I think she was Yoko's sister, am I right ?
George_o/c is offline   Reply With Quote
Old 02-15-2009, 12:40 PM   #10
Bullet92
Bullet92's Avatar
Send a message via MSN to Bullet92
Very nice job Mojo family
__________________
MBO Gigabyte MA790FXT-UD5P // CPU Phenom II 955 BE //
GPU 8800GT 512MB // PSU CoolerMaster Real Power 450W - fan moded //
RAM 2*1GB Ballistix 1800MHz // HDD 160GB Hitachi + Seagate 250GB (410AS)
Bullet92 is offline   Reply With Quote
Old 02-15-2009, 02:57 PM   #11
PcCI2iminal
Xtreme Family
thx guys
thx my friend ,i will play again on Tue or Wed
Originally Posted by rbuass View Post
Good work again
Hugs from Brazil
and AM3 will be funny to play
hugs from JP
yeah ,they are on the right way ,the Biostar is cheap and clocks like hell and I can use my AxeRAM
Originally Posted by Zeus View Post
Great clocks!
many thanks but i sent the Asus back to my friend but i will share it with him
yes you rite George,she is Yoko's sister but she is very busy these days and can not play with us hehehe
__________________
Mojo
Family
Criminal
Kids
Old 02-15-2009, 03:37 PM   #12
runmc
Admin
runmc's Avatar
Hooray for Mojo family and AMD comeback Competition is good
__________________
Worthy is the Lamb
runmc is offline   Reply With Quote
Old 02-16-2009, 08:22 PM   #13
x-powerx800pro
Champion
x-powerx800pro's Avatar
Biostar 790GX 128MB limit of the overclocking strengthened.
x-powerx800pro is offline   Reply With Quote
Old 02-17-2009, 06:16 AM   #14
OverDozeD
OverDozeD's Avatar
Great clocking
Only 1 question
Why did you use such powerful GPU only for 2D benches?
__________________
Core i7 920 <|> DFI LANPARTY UT X58 T3eH8 <|> OCZ Platinium 3GB DDR3 CL7 1600Mhz <|> ZOTAC GTX260 c216 <|> Ultra120 2X Noctua 1300RPM <|> Gigabyte ODIN PRO 800W <|> Samsung 275T 27" PVA
OverDozeD is offline   Reply With Quote
Old 02-17-2009, 06:51 AM   #15
PcCI2iminal
Xtreme Family
well ,competition is always good Ron...Phenom2 is funny ,we play with full pot all the time and LN2 take ages to gone
but Mojo Family still on the blue side of the force hehehehe
Originally Posted by OverDozeD View Post
Great clocking
Only 1 question
3d benching soon my friend ,very soon
__________________
Mojo
Family
Criminal
Kids
Old 02-17-2009, 07:01 AM   #16
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
Cannot believe i missed this one, nice results my friend. Looking forward to 3D
__________________
loc.o is offline   Reply With Quote
Old 02-17-2009, 07:15 AM   #17
PcCI2iminal
Xtreme Family
6GHz
max htt
and thx for Biostar TW for the new bios beta with good improvement on stability and for all support
__________________
Mojo
Family
Criminal
Kids
Old 02-17-2009, 07:20 AM   #18
PcCI2iminal
Xtreme Family
thx Bart,i dont think that cpu is any good for 3d benching ,4.9GHz - 5.2GHz range but of course i will try with my new toy ^^T
__________________
Mojo
Family
Criminal
Kids
Old 02-17-2009, 07:26 AM   #19
loc.o
Xtremely Addicted
loc.o's Avatar
Good choice, youll love it
__________________
Old 02-17-2009, 07:34 AM   #20
PcCI2iminal
Xtreme Family
the best
__________________
Mojo
Family
Criminal
Kids
Old 02-17-2009, 07:55 AM   #21
giraffen
giraffen's Avatar
Send a message via MSN to giraffen
Great chip And congrats with your new toy You will love it
__________________
OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
giraffen is offline   Reply With Quote
Old 02-17-2009, 10:21 AM   #22
over@locker886
Champion
over@locker886's Avatar
Send a message via MSN to over@locker886
Congrats to 6Ghz on AMD! Very good playing Mojo Family!
__________________
"AMD gives me back the old/real overclocking feeling"
over@locker886 is offline   Reply With Quote
Old 02-18-2009, 12:03 AM   #23
OverDozeD
OverDozeD's Avatar
Actually, I mean you could reach better clocks with lower GPU power IMHO
__________________
Old 02-18-2009, 12:45 AM   #24
PcCI2iminal
Xtreme Family
thx guys
yes i c the point and thx for advice but i have a "little problem" here,no pci card in hands or any card with tdp lower than GTX285 to use now
my choices are
Asus 8800GTX
Zotac GTX295
and that Galaxy GTX285
i havent tried the integrad grafic but i dont think it will work in these conditions
__________________
Mojo
Family
Criminal
Kids
Old 02-18-2009, 02:09 AM   #25
Fr3ak
OC Jedi
Fr3ak's Avatar
Send a message via ICQ to Fr3ak Send a message via MSN to Fr3ak
Very nice results! Max HTT is a little low =/
Did you try lower CPU mutliplicators?
I only tested y 940's so far and they could booth do 350-360 MHz HTT on air and 417 with dry ice, but using the Gigabyte board (http://www.xtremesystems.org/forums/...d.php?t=213991).
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
Fr3ak is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
