Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 87
Thread: Antec Nine Hundred Two (902) Case and modding
  1. #51
    Apr 2008
    Cooler Master Sniper or Antec 902?
  2. #52
    Nov 2008
    Serbia
    Antec 902
  3. #53
    Apr 2008
    Down Under
    NEITHER. Grab a Lian Li or Coolermaster.
    2700K+H80 - EVGA GTX680 2GB - GIGABYTE G.1 SNIPER M3 Z77 - CORSAIR F3 120GB SSD - CORSAIR AX-850+MMOD BLUE/BLK - CORSAIR VENGENCE BLUE 1600MHZ -
    LIAN LI PC-60FNWX - CORSAIR SP2500S - DELL U2711 - CORSAIR M60 - FILCO MJ2 TKL BROWN
  4. #54
    Feb 2009
    Quote Originally Posted by Bertross View Post
    Sniper is also Coolermaster's
  5. #55
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    lol, nice one
    Team XS: xs4s.org
  6. #56
    Feb 2009
    Leicester,UK
    Hi all just about to put together my Antec 902 has anybody got any pics of there hardrives turned round?
  7. #57
    Xtreme Guru
    Aug 2005
    Burbank, CA
    I just got this case and it is the best looking case i have ever owned. The first thing i notcied is the build quality, it is top notch, side panels are very thick and sturdy, everything is in place, black interior is amazing. Not a bad thing i can say about this case.
  8. #58
    Nov 2008
    Quote Originally Posted by GAR View Post
    Pics?
  9. #59
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by Odyssey96 View Post
    Pics?
    Pics will be posted later on when i get home from my office oh and for the people that think this case is ugly, please go take a look in person and i think your judgment will change
  10. #60
    Xtreme Guru
    Aug 2005
    Burbank, CA
  11. #61
    Aug 2004
    Prokuplje, Serbia
    @GAR my respect for your first sistem and case!
    Intel E6500@3,3GHz, Asus P5K Premium Black Pearl 18th Anniversary Edition, Geil 2x1GB & OCZ Titanium 2x1GB XTC 4-4-4-12 800MHz, Asus ENGTX560 DCII OC/2DI/1GD5, Kingston SSDNow HyperX 3K-SH103S3/120G+WD Scorpio Black 750GB, Corsair HX520W, Samsung 961BF, noname open case, MGE UPS PC500, Win7+SP1 Ultimate x64 lite, Sony P200
  12. #62
    Nov 2008
    Gar, that looks nice, but why would you go from a HAF932 to that? Cable management is FAR inferior, no?
  13. #63
    Xtreme Guru
    Aug 2005
    Burbank, CA
    I loved the antec 900, so when this came out, i saw it in person and fell in love with it, i own a PC shop as well, so i get many toys to play with and i sell my old cases to customers who want to build pc's, so it works out good for me.
    cable management is very good on the 902, they have holes in all the right places this time around. Much thicker and better build quality all around compared to the 900, good job on antecs part.
  14. #64
    Mar 2008
    I have a quick question, I have an A900 and plan to run the Corsair HX1000 or another equally long PSU. Are you still able to use the lower cutout that is meant to run all of the PSU cables on to the other side of the MB tray? It looks like you can without issue, but I was wondering if the PSU was so long that it blocked part of the cutout? I just want to make sure I will have enough room to cut a hole in front of the PSU for all the cables to run though. Not many people are using an HX1000 in the A900 thread because it came out a while after the case did.
  15. #65
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by Smithdogg1 View Post
    The PSU and this case work great together, all the functions including cable management holes align perfectly, you can use the bottom slots to put HD's as well
  16. #66
    Dec 2008
    You didn't have to drill any holes at all? I think I would need a small one on the top left.
  17. #67
    May 2007
    Richmond (GVA), BC, Canada
    Quote Originally Posted by DizzleDazzle View Post
    Yep, i guess they could have designed that better but its not like you need to do it everyday, or even every week, so i can live with it.
    As promised here are some pics of the cable management, im still not so happy with it, i really want it to be "perfect" all thanks to some of the builds on here!
    I really want to reverse mount the hard drives as that would eliminate alot of the mess at the bottom.
    And finally, i have mounted my cpu fan the correct way around!
    Question: Are you able to install a 120mm fan on the side with your TRUE headsink installed in this case without modding? From the spec I see this 2nd generation width is about ~1cm wider than the previous but I'm not sure if it's gonna help clearing the side fan distance. I'm asking this becouse I've the first generation Antec 900 case with TRUE and it's not possible to install a side fan without cutting one of the angle of the fan that you want to install it as side fan.
    Xtreme Air-Cooled OC System:
    Mobo: Asus Rampage Formula (X38 Edition) Rev 1.03G (BIOS: 0803)
    CPU: C2Q Q6600 "G0" L723A765, VID 1.2625, 3720mhz, FSB 465*8, Vcore: 1.464, Idle/load temp: 31c/64c
    CPU Heatsink: Thermalright Ultra120 Xtreme lapped (2* Scythe S-Flex SFF21F S-FDB 120mm Push-Pull configuration)
    RAM: Kingston HyperX T1 2x2GB PC2-8500 (DDR2-1116)(5-5-5-15-3-52-6-3-8-3-5-4-6-4-6-14-5-1-5-5)(2.264 Vdimm)(Rated @ 2.3v default clock)
    HDD: Western Digital Caviar Black 640GB WD6401AALS-00L3B (AHCI)
    Video Card: XFX 8800GTS 320mb Xtreme, Core 612 Shader 1420 Mem 900 (Stock cooling)
    Sound Card: Auzentech Meridian 7.1 (8788 chipset)
    DVD: Pioneer 212D SATA DVD-RW
    PSU: Corsair HX620W Modular
    Xtreme Air Cooled Case: Antec 900 case | 3*120mm intake | 1*120mm & 1*200mm exhuast
    OS: Vista Ultimate x64 SP1 Build 6001
  18. #68
    May 2007
    since you've started posting a few pics only at the front, why not show us some more pics of your cable management and a good view of the interior?
    Thanks!
  19. #69
    May 2008
    I think Cooler Master Sniper got better then this,the side panel got room to hide plenty of wire management.
  20. #70
    Sep 2008
    Quote Originally Posted by XtremeTiramisu View Post
    Looking at it, id say no, it could just be done, but it would be touching!
    Case Antec 902 with Scythe Kama 120mm LED fans
    PSU Zalman ZM750HP
    CPU Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz
    CPU cooler TRUE 120 Black + Scythe Kama 120mm LED fan
    Motherboard Asus Maximus II Formula
    RAM 4gb Corsair Dominator 8500C5D CL5-5-5-15-2T
    Graphics Sapphire Radeon HD 4870 1GB GDDR5
  21. #71
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by SabreSword View Post
    It has a hole on the top for the 8pin cpu, top and rear fans
  22. #72
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Thanks!
    Soon, after i install my 3rd GTX 285!!
  23. #73
    Nov 2005
    Just as with the Antec 900, you still have to cut one corner off the fan for it to clear a TRUE. I had to cut my fan for it to clear my Noctua cooler as well. Then, because of the new fan filter which slides into the side window, the plastic panel is thicker so the fan wouldn't clear my HR-03 GTX.
    I was able to solve that one without major surgery by swapping out the plastic panel from my old Antec 900, which bolted right into the 902 side panel
    i5 750@3800
    Noctua NH-U12P/120x38mm Panaflow M1
    GSkill 4G DDR3-2000 Ripjaws
    EVGA P55 FTW 200
    EVGA GTX 480/Zalman VF3000F &
    Zotac GTX 480 AMP Edition/Zalman OEM VF3000F SLI@800/2000
    Seasonic M12D 750
    WD Caviar 500
    Coolermaster HAF 932 Black Edition
    W7 64 Pro
  24. #74
    May 2007
    hmm thanks for the replies guys....so for me, I already see there are 2 issues with the case....the side fan option is preety much handicap unless you do some custom work to mount the fan without overlapping with certain cpu headsinks...and there is no cpu power management hole...these 2 are biggies for me....maybe i'm just looking for excuses to get the 1200 and all problem solved...lol
  25. #75
    Nov 2005
    The 1200 is a nice case, they are about 60 bucks more at NCIX than the 902 at regular pricing, sometimes they have either case in the weekly sale.
    I got the 902 over the 1200 because I don't have enough room at my desk for a full tower case to be practical. I had a Stacker for a few months, awesome case, but it was just too damn big
    Really not a problem cutting the corner off a 120mm fan to clear a TRUE though, if you mean the top 8-pin cable for the cpu, I just slipped mine behind the back panel and back through the slot in the top of the case directly to the plug in the mobo.
    i5 750@3800
    EVGA P55 FTW 200
    Seasonic M12D 750
    WD Caviar 500
    W7 64 Pro
