congrats Pt1t!
congrats Pt1t!
thanks pvhk
Not as impressive as all these D0 stepping results we are now seeing, but my old 3836A756 batch i7 920 is doing quite well moving from TRUE120 air to water cooling - easily improved on HT enabled max 32M pi from 4473mhz to 4618Mhz http://i4memory.com/showthread.php?t=17002/ !
Amazing what a water cooling can do for max stable bclk too. On air 228 bclk was max for 32M pi, but on H20 straight boot from bios 32M done at 230blck with ease!
229bclk boot from bios
230bclk boot from bios
231bclk 32M Passed
232bclk 1M
setfsb bump from 230bclk to 233bclk
hey eva did you try if raising the pcie frequency helps at all in stabilizing your system and maybe help to push your cpu even further ? i keep mine on around 110mhz :thump:
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Nice work Eva... Impressive stuff. I reckon you can still get some more though out of that DFI baby lol
Q6700 @ 3.75Ghz
Asus Striker Extreme *Saving for evga X58*
G.Skill 1066mhz HZ 4-4-4-5
2 x 150gb WD Raptor RAID 0
XFX GTX260+ 896MB xXx Ed
Thermalright Ultima-90
CoolerMaster Stacker 830 Nvidia
SilverStone 1200w psu
, woow impresive clocking George , congrats
Chispy.
hoping so since max 32m ht disabled only improved from 4652mhz to 4680mhz from air to water hehe - was hoping for at least 4700+ 32m pi heh
thanks
for 230-233bclk ?
vcore = 1.25v + 100.23%
cpu vtt = 1.53v + 0.0875v
vdimm = 1.65v
ioh/ich = 1.29v
ioh analog = 1.25v
pci-e = 110mhz
nice speeds there eva...I'll have to start working with memory timings now that Im happy with cpu clocks
interessing thread , many thank georges
You have help with your setting before and me for screen at 235.8 x 21 with my 920 C0 3836Bxxx under DOD (-43°)
I search the good setting for up at 240mhz maybe , i need test after 2 965XE for see if my 920 is limited or the motherboard , wait & see
awesome stuff.. I forgot to update i'm 230bclk 32m stable now with new 4/28 bios along with new PB for 235bclk all on water cooling
Been playing with DFI's latest 4/28 pre-public beta bios and it seems to have improved memory clocking stability for Elpida IC modules as well as improved my max H20 cooled bclk validation from 233 on 3/28 pre-public beta bios to 235bclk on 4/28 bios. 4/28 is pre-public beta so flash at your own risk from here.
Max BCLK
Super Pi 1M to 32M
- 1M = 9.328s
- 2M = 21.000s
- 4M = 46.422s
- 8M = 1min 42.750s
- 16M = 3min 45.782s
- 32M = 8min 11.859s
System:
- i7 920 3836A756
- EK Supreme LT 1366 / FESER 480 / MCP655
- DFI UT X58-T3EH8 04/28 beta
- 512MB Inno3D 8800GT OC Edition
- 6GB Corsair Dominator GT DDR3-2000Mhz 7-8-7-20
- 750GB Samsung SATAII
- Silverstone OP1200 PSU
- Dual boot - WinXP Pro SP3 / Vista Ultimate 64Bit SP2
Bios settings used.
Code:Genie BIOS Setting CPU Feature Set VR Current Limit Max: Disabled Thermal Management Control: Disabled EIST Function: Disabled CxE Function: Disabled Execute Disable Bit: Disabled Virtualization Technology: Disabled ***** Logical Processor Setting ***** Intel HT Technology: Enabled Active Processor Cores: All DRAM Timing Channel Interleave Setting: AUTO Rank Interleave Setting: AUTO Memory LowGap: 1792M DRAM Command Rate: AUTO CAS Latency Time (tCL): 6 RAS# to CAS# Delay (tRCD): 7 RAS# Precharge (tRP): 6 Precharge Delay (tRAS): 20 REF to ACT Delay (tRFC): AUTO Write to PRE Delay (tWR): AUTO Rank Write to Read (tWTR): AUTO ACT to ACT Delay (tRRD): AUTO Row Cycle Time (tRC): 31 Read CAS# Precharge (tRTP): AUTO Four ACT WIN Time (tFAW): 31 Ch1 Round trip latency: AUTO (-15 to +16) Ch2 Round trip latency: AUTO (-15 to +16) Ch3 Round trip latency: AUTO (-15 to +16) tREFI: AUTO Voltage Setting O.C. Shut Down Free: Enable O.C.S.D.F CPU VID Control: 1.4500v CPU VID Special Add Limit: Disabled CPU VID Special Add: 103.30% Vcore Droop Control: Disabled DRAM Bus Voltage: 1.71v DRAM PWM Switch Frequency: Nominal DRAM PWM Phase Control: 2 Phase Operation CPU VTT Special Add: 0.0875v CPU VTT Voltage: 1.53v VTT PWM Switch Frequency: Nominal VTT PWM Phase Control: 2 Phase Operation CPU PLL Voltage: 1.80v IOH/ICH 1.1V Voltage: 1.29v IOH Analog Voltage: 1.20v ICH 1.5 Voltage: 1.5v ICH 1.05V Voltage: 1.05v DIMM 1/2 DQ/DQSTB Bus VREF: -00.0% DIMM 3/4 DQ/DQSTB Bus VREF: -00.0% DIMM 5/6 DQ/DQSTB Bus VREF: -00.0% ADDR/CMD VREF Control: Disabled x DIMM 1/2 ADDR/CMD Bus VREF: 110 x DIMM 3/4 ADDR/CMD Bus VREF: 110 x DIMM 5/6 ADDR/CMD Bus VREF: 110 CPU QPI Drive Strength: Normal IOH QPI Drive Strength: Normal Exit Setup Shut down: Mode 2 O.C. Fail Retry Counter: Enabled O.C. Fail CMOS Reload: Disabled PPM Function: Enabled Turbo Mode Function: Disabled 1 core Max Turbo Ratio: 22x 2 core Max Turbo Ratio: 21x 3 core Max Turbo Ratio: 21x 4 core Max Turbo Ratio: 21x CPU Non-Turbo Clock Ratio: 19x * BCLK/UCLK/QPI Controller Settings * QPI Control Settings: Enabled QPI Link Fast Mode: Enabled QPI Frequency: AUTO CPU Base Clock (BCLK): 230 Mhz Boot Up CPU Base Clock: AUTO PCIE Clock: 110 Mhz DRAM Frequency: 8xx Memory multipliers UnCore Frequency: 16x Uncore multipliers CPU Spread Spectrum: Disabled PCIE Spread Spectrum: Disabled
nice bclk eva Any plans to see if subzero could get 235x21 32M stable?
Do have plans but long way off as I need to get Kayl to do a new 1366 evap mount for my 1/4HP SS as it was made back in day for s939/lga775 hehe
next big plans are for Corsair DHX TEC memory cooling and Dominator GT review
sweet... all these D0 are tempting me... but I still like my C0 hehe.. might wait to see what 950 cpus bring to the table heh.
Nice work eva2000
My DFI MAX BCLK (Air)
looks like you're really having fun with this setup again eva
Great work
GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
thanks sure am.. nice oc_windforce D0 seem to have potentially higher bclk!
Good baseclock, your cpu pushing up on VTT termination table as same my D0 3847A891. When I have tested this cpu I have find this fact, only depend on scalability of IMC versus VTT, if your cpu is hot and ambient temperature you have more possibilty to gain fsb if you cooling it.
For example my cpu on classified take 239 on base clock with 1,55VTT with chiller, cpu temp is around 25°Celsius with real temp monitoring. Same cpu on bloodrage, without pciex 110, take 229 on base clock at 1,50Vtt more vtt on blood not give any difference why it not have fixed the pciex in bios option.
On Asus Gene my cpu give 231mhz on baseclock with pciex 110mhz and vtt 1,55V. On Asus my cpu lowering base clock why Asus maonboard have many problem to menage correctly the VTT line amplitude, this mainboard needs more vtt voltage respect DFI, classified and bloodrage at same frequency of base clock.
Third fact to limit the max.fsb is memory module you use, example with kingston 3x1 giga elpida hyper single side my cpu take max. 225mhz on bloodrage and with kingston t1 3x2Giga ever elpida hyper, but this model is double side chip, my cpu take 229mhz on baseclock with this. I supposed that this depend only on the Vref. Voltage set the minboard on imc memory controller of i7, because this module is more stable with lower Vdimm voltage respect the module 3x1, and vref change in base at Vdimm Voltage you apply in the bios.
Good testing guys.....
hehehe, i just came into the Xtreme OC'ing section and the top 8 or 9 threads are all Classified, Classified, Classified...then there is your thread George. keeping the DFI name alive
great work with this board, keep it up
Is DFI LanParty UT X58-T3eH8 worth the extra money, or does DFI LanParty DK X58-T3eH6 do the job?
Have read almost everything Eva2000 have written and the T3eH8 looks like a damn good mobo with lot of power.
So what do the XS-gang here say?
T3eH8 or T3eH6.............
1.pc: Evga 4way, 980X, 3x5870, 3x2 1600mhz GT
Storage: 3xOcz Vertex 1, Vertex 2 64gb and 2x150gb Raptor. -Updating-
Thanks eva, i get my board today i hope=)
I love my Dfi X48, hope i love this to
And one thing more, Dfi is one of the few that understand that we need to use pci lanes to.
Almost every board you put 4870 in crossfire on, they block every lane
