I have just tried to crossflash my board but afudos just reports a fail.
Im using afudos version 207 and the dos command im using i afudos /i0006.ROM is that the right command for flashing the bios or what?
Edit:
Nevermind it works now
Had to use another version af afudos and i found the right command. Flashet the board with the 0006 bios and the two settings im was missing is in the bios now
boot 234 bclk
http://www.youtube.com/watch?v=6Kv1QbOyQ0o
If you don't like what I have to say, please feel free to ignore it. I do!
Core i7 920 (D0) @ 4.0Ghz, P6T Deluxe V2 (0901), 12GB Corsair CM3X2G1600C7 @ 1600 7.7.7.20 2T, ATCS 840, Antec TPQ 850, Radeon 4850, TMS-200 + TMS-EB200, EK Supreme HF, EK-D5 dual top, 2x MCP-655-B, MCR-420, 7X Skythe D1225C12B5AP-15, Durelene tubing. Obviously not a gamer as you can tell by the low end video card.
P6T boot 236...
That video was rather low resolution, but on the screen it appeared to read 234 X 17 = 3.978 GHz. If so, then why not just do 200 X 20 = 4.0 GHz, which is what I run 24/7, nothing special.
Now, 5.078 GHz, that is impressive. What's being used for cooling and how long is the chip being run at that speed?Originally Posted by road-runner
Hello friends .... back from the "dead" ..... how is the sceene on P6T v2 ?
Thanks,
J
EDIT: Cross-flash ???! WOOWWWW what are you guys "cooking" men !!!
Can some one give me a short resume please ?
My System
» ASUS P6T Deluxe V2 (CF w/0006 bios) | Core i7 930 3002A879 @ 4.20GHz (21x200) | Corsair Dominator DDR3 6GB TR3X6G1600C8D @ 1603MHz 8-8-8-21-1N
» ASUS ENGTX460 TOP 1GB @ 900/4000MHz | SB X-Fi Titanium PCI-E | C:\Intel SSD X25-M G2 80GB | D:\Samsung F3 HD103SJ 1TB | E:\Plextor PX-716SA
» Corsair HX620W Modular | CoolerMaster Stacker custom "All Black" | Samsung LED XL2370 23" Full HD
» WC 3/8": Apogee GTZ + BI GT Xtreme 240 + Koolance Nozzles + Station 600 + Silver KillCoil
I'm running 4200mhz now, 21*200 @ 1,33v HT on (1,33v qpi, 1,14v nb), and it's rock stable.
Tested 50 passes linx and 8h Prime95.
But I want to go higher, 4,4 would be nice but its hard to get stable.
I tryed with cpu voltage up to 1,43, qpi 1,375, NB 1,22 and it fails after ~20min linx.
I have the memory on 9-9-9-25 @ ~1680mhz and it is specced for 8-8-8-24 @ 1600mhz so I don't think they are the problem.
I'm using i7 920 D0, P6T Deluxe v2 and Corsair dominator.
Anyone have any suggestions?
Or should I just up the cpu voltage more and see if it passes?
How much qpi voltage is considered "safe" for a 24/7 clock?
Im running 4600 mhz right now on h2o
220*21 vith 1,45 vcore, 1,35 qpi/vtt, 1,24 nb stable for benching 3dmark and superpi.
Bios 1611
ftp://ftp.asus.com.tw/pub/asus/mb/lg...ELUXE-1611.zip
[ 1611 ]
Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us
new features on 1611 ?
My System
P6t Deluxe V2
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...XE-V2-0606.zip
Intel Core i7 LGA1366 - 3.60GHz (20x 180 BCLK) / 4 Cores / 8 Threads / 1.26v / UCLK 3067MHz / QPI 6.47 GTs
Crucial, Micron D9JNM ICs, 12GB DDR3 - 1440MHz, 8-8-8-20 1T, 1.6v, Tri-Channel
Palit NVIDA GeForce GTX 460 1GB DDR5 16x 2.0 - GPU 750MHz / Shader 1500Hz / DDR5 3625MHz
2x Intel X25-M G2, 80GB SSD, ICH10R RAID 0 / Windows 7 Professional 64-bit
....... System Runs 24/7....... system_01
Anyone OCing better using the 0006 bios on a P6T v2 then with the oficial V2 bios ? using the same vcore ?
My System
Thanks angelreaper.
I asked because in the future if ASUS stop support for P6T Deluxe to know if I can put BIOS from P6T Deluxe v2 or P6TD Deluxe.
Elsewhere I'm not saw someone being cross flash v1 in v2.
I know to the contrary from you.
For now 0007 works fine for me.
