06-08-2009, 09:53 PM
#226
Xtremely unstable
It looks cold
__________________
dx58so
w3520@4100
4x1gb corsair ddr3-1333
gtx 295
TR ultra-x, 2 scythe ultrakaze push/pull
xclio stablepower 1000
vista ultimate
would you crunch if you thought it would save her life?
maybe it will!
06-09-2009, 12:40 PM
#227
Diablo 3! Who's Excited?
Tuning with R1150 right now.. going well. Hopefully mounting this to a Phenom II X4 955 tonight to dump a little heat into the system and prep it for Core i7 tuning later this week.
Going to need to put a 120mm fan to cool the 2nd stage compressor. It doesn't receive enough refrigerant or airflow and after 30 minutes it was at 95 Celsius at the top, 87 Celsius at the bottom. Now time to figure out how to fit that fan in here..
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
06-09-2009, 04:34 PM
#228
Harder than expected with such tiny compressors. To hold an appreciable load it's going to be low, evap around -65C to -70C  I tried a straight R1150 charge and got the evap down to -90C but it'd crash with more than 1 core on the Phenom II @ 4500MHz. Slowly dumping R1150 and adding R290 into the 2nd stage, trying to find an appropriate blend.
__________________
06-09-2009, 08:36 PM
#229
Added another 1/2" of insulation on the HX and 1/4" of insulation on the 1st stage suction line. I think I'm losing a lot of HX capacity due to the amount of air flowing over the HX due to the massive condenser fan. The suction line stays around -20C and the HX near the 2nd stage inlet hovers around -15C while loaded, idles at -31C. Right now I've got a full R290 charge on the 2nd stage with no R1150 and it holes through 06 at 4500MHz with a evap temp of -56C and an IHS temp of -42C. I need to drop another 20 Celsius before I'm happy. Going to start feeding it small quantities of R1150 and monitor the HX temps. Would really like a larger 1st stage compressor to pull the HX down to -40C and go from there :-S
__________________
06-09-2009, 11:04 PM
#230
Xtremely unstable
Isn't this -60 or so range you're looking at pretty good for the i7? I've seen comments about poor scaling past that, as well as some folks having issues with booting colder temps?
__________________
dx58so
w3520@4100
gtx 295
vista ultimate
maybe it will!
06-09-2009, 11:14 PM
#231
I am Xtreme
From the picture you posted I don't see a fan on the Desuperheater ? If not it will lower 2nd stage pressures and more importantly is your 2nd stage head temperatures.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????  I forgot "you must"
06-10-2009, 07:29 AM
#232
There's a 38mm thick panaflo on the DSH, just wasn't in the picture. Going to stuff a 38mm 120vac fan in there before shipping that'll come on with the 2nd stage. Refrigerant going into the HX isn't much higher than ambient
Yeah, -60C isn't bad, it'll get you up to ~5GHz. There are some i7 with horrible cold boot temps, you've got a hot gas bypass to dump hot gas into the evap to warm it up for boot though  Just pray your i7 doesn't have a coldbug at -50C
__________________
06-10-2009, 04:26 PM
#233
k, done tuning on PHII. Idles at -78 Celsius with no load on the evap due to the R1150 in the charge. With PHII @ 4500/1.55v it was looping 3D06 CPU test with the evap at -61C. HX temps near the 2nd stage inlet sit at -21C and the 1st stage compressor runs around 65C. 2nd stage compressor still runs warmer than I'd like around 80C shell temps with the DSH fan running. 1st stage is running 180psi dicharge and 7psi suction when fully loaded. 2nd stage is running 145psi discharge and 3psi suction with the evap loaded. Loading it up with Core i7 around 1.55v will be interesting, just waiting on my incredibly delayed Classified to arrive. Hopefully I won't have to tweak the charge much more, might have to remove a little R1150 and add some R290 on the 2nd stage.
edit: I tested the hot-gas bypass and it sort of works. Adam used too narrow of a bore capillary tubing so with the bypass enabled the evap would only drop down to -45C or so.
__________________
06-10-2009, 05:07 PM
#234
...you two characters
if you can hold a big load at -70C you can max out most i7s  dont sweat it
__________________
Team.AU
Got tube?
Originally Posted by Gautam
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
06-10-2009, 05:31 PM
#235
Xtremely unstable
Yeah dinos, that's kind of what I thought too. This thing should be a lot of fun for playing with the i7s.
__________________
dx58so
w3520@4100
gtx 295
vista ultimate
maybe it will!
06-11-2009, 06:58 AM
#236
-100c club
Chris, I will be out of town this weekend so wont be using my load tester. Its adjustable up to 400 watts.
I can drop it off tomorrow on the way back from work just say the word.
06-11-2009, 07:23 AM
#237
Could you drop it off, will use it to maintain a continuous load once I can figure out what is necessary to hold the i7 975 stable
__________________
06-11-2009, 01:15 PM
#238
-100c club
Absolutely and im bringing the other item we discussed...
06-11-2009, 04:04 PM
#239
I am Xtreme
Gomeler check your running amps on the second stage compressor.
adding: Check to be sure your using the correct size run capacitor also.
A bunch of little issues can add up to one big PITA.
But looks like noob already schooled you in that.
__________________
Register today .
06-12-2009, 01:18 PM
#240
I was thinking about this. I know NoL uses 25 uF caps on these Rechi's but the spec sheet states 15uF and I'm pretty certain I was using 20uF caps the last time I doodled with them. Just so happens I have a 15uF and 20uF cap, so I'm going to measure the running amps with NoL's 25uF cap and then drop in the 20uF, and again with the 15uF. Not sure if I'll have a chance to do this testing tonight, dinner with the girlfriend in 2 hours.
__________________
06-12-2009, 03:44 PM
#241
Goms Girl Friend
06-12-2009, 05:00 PM
#242
Xtreme I am
Originally Posted by Ozzfest05
Goms Girl Friend
Foreigners song "Cold as Ice" comes to mind.....she sure is cute though!!!!!
__________________
____________________________________________
More & more very expensive, quickly obsolete parts!!
06-13-2009, 08:25 AM
#243
Xtremely unstable
Just bring her back there for KFC, beers, and phase tuning. What's the problem?
__________________
dx58so
w3520@4100
gtx 295
vista ultimate
maybe it will!
06-13-2009, 10:22 AM
#244
Admin
What more could a gal asked for?
06-13-2009, 10:38 AM
#245
Morning chores/cleaning/email out of the way, time to get to work. Just fired up the 1st stage. First I'm going to test the 2nd stage with 25/20/15uF capacitors and record the power draw with each option. I've also got SDumper's load tester hooked up to the evap, so once I figure out if I can really use a 15uF cap then I'll re-test the evap.
SDumpers(DetroitAC designed) load tester makes me want to rebuild mine and case it up. Mine is all dangerous with the bare variac although my variac is huge
Sadly my girlfriend is vegan and doesn't like beer, so when I suggested that she just rolled her eyes
edit:
Initial numbers of 2nd stage @ idle
420-425w powerdraw with the 25uF cap
350-355w powerdraw with the 20uF cap
295-300w powerdraw with the 15uF cap
Thanks for the prod in the right direction Walt. Dropping compressor power consumption by ~33% should help the 1st stage cope a little better. For the record the 1st stage pulls 375w with the 2nd stage running. Now I'm slowly ramping up the evap load tester, going to jump in 25w increments and record the temps.
__________________
06-13-2009, 12:06 PM
#246
Banned
once you get evap tuned "a stiffy" like an old man puts his in the freezer b4 gal comes over.......J/K
looks 15uF works best. how it sound on start-up? laboured or snappy ?
question using cap as run or start cap?
06-13-2009, 12:16 PM
#247
I am Xtreme
Sadly my girlfriend is vegan and doesn't like beer, so when I suggested that she just rolled her eyes.
Thanks,removing 125 watts x 3.412 you just removed 426.5 Btu's the condensor doesn't need to reject  ...........want some more good advice?
Find a new Girlfriend.
__________________
Register today .
06-13-2009, 12:28 PM
#248
It's a 15uF run capacitor. Startup is "normal", spins up quickly and powerdraw looks normal.
lol
Here is the initial testing. The 1st stage crashed on me at 225w so I need to play with the 1st stage charge a little more. I've also got the suction line on the 2nd stage running with just 1/2" of insulation, it is thoroughly wet so I have more performance to gain with better insulation. My original 3/4" thick insulation job was a few inches too short in length, need to pick up another section of insulation on Monday. I need to get the 1st stage HX to hold -15C to -20C with the 2nd stage fully loaded and then work on the 2nd stage a little more to try and balance out the temps a little more. Less R1150 and more R290 is in order I believe.
-80.4 idle
-74.4C 25w
-68.3c 50w
-64.4c 75w
-60.1c 100w
-57.0c 125w
-54.6C 150w
-52.4C 175w
-50.5c 200w
-48.9c 225w
__________________
06-13-2009, 02:39 PM
#249
I am Xtreme
What gas in in the first stage? & whats the low side pressure? do you know the superheat? Anyone have a P/T chart for R1150 handy?
__________________
Register today .
06-13-2009, 03:35 PM
#250
With the 2nd stage idling the 1st stage(R290) has 4psi suction and 165psi discharge with -21C near the top of the HX between the 2nd stage inlet and the 1st stage outlet and the suction line at -24 Celsius. With the 2nd stage loaded to 200w the 1st stage climbs to 7psi suction 175psi discharge and the HX drops to a stable -7 Celsius while the suction line hovers around -17 Celsius.
Should I measure the HX from the lowest point, directly in the middle, or the top? I think I chose a bad spot to measure as I'm more or less getting a measurement of where the warmer suction gases are mixing with the hot inlet gases. On reflection I should probably have measured nearer the 2nd stage outlet.
While posting this I dumped a little more r290 into the 1st stage, 10psi suction and 200psi discharge, -11C HX temps. Evap temps dropped 4 degrees at 200w to -54.7 Celsius, testing 225w right now.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
