XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 11-09-2008, 02:59 PM   #1
short114
Short’s Black & Red Cosmos S [Worklog] LOT OF PICS -=Updated 15 Nov 2008=-
Hi and welcome to my first Liquid built and also my first work log. This built will consist of transferring all my current hardware to my new Coolermaster Cosmos S and install a liquid loop for my CPU, here a list of the hardware:
CPU
Core 2 Quad Q6700 G0 @ 3.60GHz
Motherboard
Asus P5E Deluxe (X48)
Memory
Corsair Dominator DDR2 4GB (2x2GB) 1066 MHz (PC2 8500)
Graphics Card
Sapphire HD 4870 OC@790/1100
Hard Drive
2x Raptors 74GB RAID0 (OS) + 1x Seagate 1TB + 1x Seagate 500GB + 1x WD 250GB
Sound Card
SoundBlaster X-Fi Titanium Fatal1ty
Power Supply
OCZ GameX Stream 700W
Optical Drive
LG DVD+/-RW 22/22 SATA
Case
OS
Vista Ultimate 64Bit
Monitor
ViewSonic VX2835wm 28" Widescreen
TV Tuner
Asus My Cinema PE9400 Combo
And now the W/C components (1 Loop CPU):
Radiator:
Black Ice GTX 360
CPU Water Block:
Swiftech Apogee™ GTZ
Liquid Tank:
Swiftech MCRES-Micro Rev 2
Pump:
Swiftech DDC-3.2 MCP355
Pump Top:
XSPC Laing DDC Top
Pump Bracket:
Designs Absolute Pump Bracket Rev. 2
Tubing:
20Ft. PrimoFlex Pro LRT UV Red Tubing - 1/2in. ID X 3/4in. OD
Compression Barbs:
8 X Danger Den Compression Fitting 1/2" ID 3/4" OD
Biocide:
Petra'sTech PT_Nuke
Push Fans:
3 X Scythe 120x25mm SlipStream - 110 CFM
Pull Fans:
3 X SCYTHE "ULTRA KAZE" 120 x 38 mm 2000 rpm Quiet Case Fan
Extra Fans:
2 X Scythe 120x25mm SlipStream - 110 CFM
RAM Fans:
3 X ACE 40 X 20mm LED Fan Red
UV Lightning:
3 X Lazer Led - 6 Led - UV Led
And a lot of other small goodies needed, like sleeving materials, Acrylic windows, custom flat black paint, etc. These items came from my workplace, I am the IT technician in a company that built high-end flight simulator training systems.
I will try to update this built as often as I can, but I am a father and I work 40h/week, so please be patient, also please excuse my bad English and will try my best.
Here some pics of my AIR system in my old Antec Nine Hundred, + some pics from my new Cosmos S.
And now some really early picture form the new Cosmos S.
Updates coming soon.
Last edited by short114; 11-15-2008 at 11:58 AM. Reason: Change title to add last update!
short114 is offline   Reply With Quote
Old 11-09-2008, 03:06 PM   #2
TedShred
don't taze me bro
TedShred's Avatar
nice!
would look great with all-black bay drive button things like Coolmeister snagged for his latest Cosmos. dunno if they're generally available tho
GL on the rest of the build
__________________
Time is an illusion. Lunchtime, doubly so. Douglas Adams
QX9650 @ 3825mhz CoolIT FZone
2x HD3870X2 @ 845/946mhz air
Asus Maximus Formula 0907
2x2048mb OCZ Reaper 8500
2x Raptor 150G Raid0; 'Cuda 1000G
1200W Thermaltake
xFi Extreme Gamer/ Z-5500
Vista Ult. 64
Cosmos 1000
30" NEC
TedShred is offline   Reply With Quote
Old 11-09-2008, 03:08 PM   #3
MomijiTMO
Banned
Send a message via MSN to MomijiTMO
Nice pain job mate.
MomijiTMO is offline   Reply With Quote
Old 11-09-2008, 03:10 PM   #4
shoopdawoopa
shoopdawoopa's Avatar
Red and black is the way to go m8!
__________________
Whats up?
shoopdawoopa is offline   Reply With Quote
Old 11-09-2008, 03:33 PM   #5
anubis_is_evil
anubis_is_evil's Avatar
wow, came up really different from the original one...love the black paint job , its really perfect
anubis_is_evil is offline   Reply With Quote
Old 11-09-2008, 04:34 PM   #6
MINIz guy
That looks like a great paint job! Did you drill out the rivets and paint each part individually or did you paint the chassis as a whole?
MINIz guy is offline   Reply With Quote
Old 11-09-2008, 04:48 PM   #7
short114
At my work we have a professional paint shop, I bring it at 9h am in the morning and at 12h30 pm she was already dry, people are really amazing there, it save me money and a lot of time. And no I did not even touch the rivets, they paint it as a whole.
Old 11-09-2008, 06:39 PM   #8
short114
First Order Arrived + Sleeving!!
I start this project 3 weeks ago at a really slow pace, I will update this work log and try to cover the last 3 weeks ASAP, I will post picture per subject and try to cover them quickly.
These pictures are from the first order I received from Jab-tech.
Now I will show you a lot of picture from the sleeving I did, I start with the 24 pins an 8 pins Power that came with the Cosmos S case, following with pump cables, fans cable and also I sleeve cables from the power module of the Cosmos S.
Update coming really soon, keep commenting it's really appreciated, and if you have any advise or sugestion they are also really appreciated.
Old 11-09-2008, 06:52 PM   #9
short114
When I came back home with my new flat black Cosmos S I was really happy with the result until I put the back door in place, I notice that you can see aluminum through the cable management hole, I decide to get some flat black paint for my work and fix this small problem.
Here some picture from before and after.
Old 11-09-2008, 07:00 PM   #10
short114
Since I and going Liquid for the first time, I don't need the huge side window fan. So I install a side window instead. This is my first any only mistake as of now, the window is awesome but when I use the screw to fix the window I put a little to much force and make little mark on the outside. If they after time annoyed me too much I will certainly buy a new door.
Old 11-09-2008, 07:09 PM   #11
short114
Second order arrived, slowly coming in, only 3 fans this time.
Third order arrived the day after, a little bit more this time, Compression fittings, Tubing and UV lighting.
Old 11-09-2008, 07:23 PM   #12
short114
Since one of the first parts I receive was the 3 X SCYTHE "ULTRA KAZE" 120 x 38 mm 2000 rpm I decide to install them in the top of the Cosmos, I was aware of the modifications needed but I was not expecting that much work.
Here some pics of the work that I done to make them fit.
Old 11-09-2008, 07:27 PM   #13
MomijiTMO
Banned
lol that's a lot of effort dude. Damn fans
Old 11-09-2008, 07:27 PM   #14
RCG_Bex
#1 UK Female OC'er?
RCG_Bex's Avatar
Send a message via MSN to RCG_Bex
Lol looking pretty badass! Loving the modding and look forward to it being finished!
~Bex
__________________
PERSONAL BESTS : E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.4GHz I7 920 @ 4.6GHz
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
- - - : ASUS RMA'S - A TOTAL JOKE - DON'T SUPPORT THEIR CRIMES : - - -
RCG_Bex is offline   Reply With Quote
Old 11-09-2008, 07:32 PM   #15
short114
~Bex
Thanks Bex, It's funny I was just looking at you built and I was thinking the same thing!
Old 11-09-2008, 07:43 PM   #16
RCG_Bex
#1 UK Female OC'er?
RCG_Bex's Avatar
Lol good minds and tastes think alike
~Bex
__________________
Old 11-09-2008, 10:10 PM   #17
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
good work with the fans, My exhaust kaze looks exactly the same with the edges on one side cut off
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 11-09-2008, 10:24 PM   #18
bianco
nice work on that top mod.
sub'd
__________________
bianco is online now   Reply With Quote
Old 11-10-2008, 01:00 AM   #19
pcaddict
pcaddict's Avatar
Looking good! I wanna see MOAAAR!!!
__________________
EVGA E760 - 74Gb & 80Gb - Mushkin 6Gb - NVS295 - W3550 @ stock
pcaddict is offline   Reply With Quote
Old 11-10-2008, 03:48 PM   #20
short114
I am in the process of sleeving my PSU cables, the only ones remaning are the SATA's. I need to decide my HDD configurations. I got 2 X 74Gig Raptors + 3 drives for storage 1 X 1TB, 1 X 500GB and 1 X 250GB.
The way I was planing it is like shown in the next picture, use the drive cage for my two Raptors and leave some space between for air flow.
But I only have two 3.5" to 2.5" bracket at hand, I was finally thinking about placing 4 HDD in the cage, do you think it will really hurt temp to compare to having only the two Raptors like shown in the picture?
Old 11-10-2008, 04:02 PM   #21
Spankyfart
Spankyfart's Avatar
What did you use to paint the inside?
And, looking good.
__________________
Spankyfart is offline   Reply With Quote
Old 11-10-2008, 04:19 PM   #22
armeniandave
armeniandave's Avatar
Looking good! Kinda looks like the one I built for Absoluteczech. Where are you planning on putting the pump?
__________________
i7 920 4Ghz 1.25v // Asus P6X58D Premium // Windows 7 Ultimate 64bit // 6gb Corsair Dominators // 9800 GX2 // 9600 GSO //128Gb Corsair SSD //300GB VelociRaptor (Storage) // Custom Wall Mount Case // Corsair 1000W // SyncMaster 2433BW & 226BW & 226BW // Dual loops 2-laing 355's each with XSPC dual top // (UN) 3G Brackets & X-Brackets // Swiftech Apogee XT // EK 9800GX2 Full cover Block // 2 x 120.3 & 2 x 120.2 Swiftech Rads//
Wall Mount Build Log: http://www.xtremesystems.org/forums/...d.php?t=242186
MM Extended Ascension Build Log:http://www.xtremesystems.org/forums/...d.php?t=212236[/size][/size][/size]
armeniandave is offline   Reply With Quote
Old 11-10-2008, 05:36 PM   #23
RCG_Bex
#1 UK Female OC'er?
RCG_Bex's Avatar
Should be OK so long as they can still get some air. HDD's prefer a bit of warmth anyway (helps the mechs or something if I recall...)
~Bex
__________________
Old 11-10-2008, 06:09 PM   #24
short114
And, looking good.
I don't know.. It was professionally painted flat black at my work place.
Old 11-10-2008, 06:12 PM   #25
Spankyfart
Spankyfart's Avatar
That was the reason I asked, if you did that yourself and it came out that nice.
It was worth investigating
Looks spiffy.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
